stm32N6在使用stm32ai-modelzoo-services训练模型的时候,配置好路径,最后运行脚本的时候报错,显示【调用了两个同名文件,出现错误了】,请问有人直到要怎么解决吗? LOAD ERROR: WindowsPath('E:/07_Stm32/stm32N657/stm32ai-modelzoo-main/stm32ai-modelzoo-services-main/stm32ai-modelzoo-services/image_classification/src/deployment_outputs/2025_05_16_13_00_27/network.h') and WindowsPath('E:/07_Stm32/stm32N657/stm32ai-modelzoo-main/stm32ai-modelzoo-services-main/stm32ai-modelzoo-services/image_classification/src/deployment_outputs/2025_05_16_13_00_27/network.h') are the same file Error executing job with overrides: [] Traceback (most recent call last): File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src\stm32ai_main.py", line 421, in <module> main() File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra\main.py", line 94, in decorated_main _run_hydra( File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 394, in _run_hydra _run_app( File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 457, in _run_app run_and_report( File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 223, in run_and_report raise ex File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 220, in run_and_report return func() File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra_internal\utils.py", line 458, in <lambda> lambda: hydra.run( File "D:\26_anaconda3\envs\n61\lib\site-packages\clearml\binding\hydra_bind.py", line 91, in _patched_hydra_run return PatchHydra._original_hydra_run(self, config_name, task_function, overrides, *args, *kwargs) File "D:\26anaconda3\envs\n61\lib\site-packages\hydra_internal\hydra.py", line 132, in run = ret.return_value File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra\core\utils.py", line 260, in return_value raise self._return_value File "D:\26_anaconda3\envs\n61\lib\site-packages\hydra\core\utils.py", line 186, in run_job ret.return_value = task_function(task_cfg) File "D:\26_anaconda3\envs\n61\lib\site-packages\clearml\binding\hydra_bind.py", line 230, in _patched_task_function return task_function(a_config, a_args, **a_kwargs) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src\stm32ai_main.py", line 407, in main process_mode(mode=mode, configs=cfg, train_ds=train_ds, valid_ds=valid_ds, quantization_ds=quantization_ds, File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src\stm32ai_main.py", line 302, in process_mode deploy(cfg=configs) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../deployment\deploy.py", line 90, in deploy stm32ai_deploy_stm32n6(target=board, stlink_serial_number=stlink_serial_number, stm32ai_version=stm32ai_version, c_project_path=c_project_path, File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../../common/deployment\common_deploy.py", line 469, in stm32ai_deploy_stm32n6 stmaic_local_call(session) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../../common/deployment\common_deploy.py", line 443, in stmaic_local_call stmaic.compile(session=session, options=opt, target=session._board_config) File "E:\07_Stm32\stm32N657\stm32ai-modelzoo-main\stm32ai-modelzoo-services-main\stm32ai-modelzoo-services\image_classification\src../../common\stm32ai_local\compile.py", line 208, in cmd_compile raise Exception('Error during compilation') Exception: Error during compilation |
STM32N6的摄像头下采样是怎么实现的
在STM32N6570-DK上部署图像分类模型卡住了,求助。
STM32N6570-DK开发板,哪里还有卖的?
STM32N6570-DK RTSP 示例:网线接入路由器后 VLC 能看到画面但非常模糊且帧率很低,是什么原因?
请问STM32N6目前还可以申请Dk开发板用于测试和评测吗
STM32N6570-DK自带的摄像头运行AI demo,画质特别差
为什么我的STM32N657-DK外部烧写一直出错
STM32N6烧录程序进行签名时提示系统找不到指定路径,签名失败怎么解决?
STM32N6 cubeAI部署时用的内存是在内部还是外部?
stm32N657上部署cubeAI生成代码,编译出错
