我现在用了4个通道进行ADC处理,但在进行DMA传输时却得不到后面的那个AD的数据,为什么?程序配置如下: /******************** (C) COPYRIGHT 2008 STMicroelectronics ******************** * File Name : adc_main.c * Author : MCD Application Team * Version : V2.0.1 * Date : 06/13/2008 * Description : Main program body ******************************************************************************** * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT, * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. *******************************************************************************/ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x_lib.h" #include "platform_config.h" #include #include "lcd.h" #define ADC1_DR_ADDRESS ((u32)0x4001244c) /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ ADC_InitTypeDef ADC_InitStructure; vu32 ADC_ConvertedValue[4]; extern volatile ErrorStatus HSEStartUpStatus; extern void Delay(int data); /* Private function prototypes -----------------------------------------------*/ void ADC_RCC_Configuration(void); void ADC_GPIO_Configuration(void); void ADC_NVIC_Configuration(void); /* Private functions ---------------------------------------------------------*/ /************************************************* 函数: void DMA_Config(void) 功能: DMA配置 参数: 无 返回: 无 **************************************************/ void DMA_Config(void) { DMA_InitTypeDef DMA_InitStructure;//定义DMA初始化结构体 DMA_DeInit(DMA1_Channel1);//复位DMA通道1 DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDRESS; //定义 DMA通道外设基地址=ADC1_DR_Address DMA_InitStructure.DMA_MemoryBaseAddr =(u32)ADC_ConvertedValue; //定义DMA通道存储器地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//指定外设为源地址 DMA_InitStructure.DMA_BufferSize = 4;//定义DMA缓冲区大小1 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//当前外设寄存器地址不变 DMA_InitStructure.DMA_MemoryInc = DMA_PeripheralInc_Enable;//当前存储器地址变 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//定义外设数据宽度16位 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //定义存储器数据宽度16位 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA通道操作模式位环形缓冲模式 DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA通道优先级高 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//禁止DMA通道存储器到存储器传输 DMA_Init(DMA1_Channel1, &DMA_InitStructure);//初始化DMA通道1 DMA_Cmd(DMA1_Channel1, ENABLE); //使能DMA通道1 } /******************************************************************************* * Function Name : main * Description : Main program * Input : None * Output : None * Return : None *******************************************************************************/ int adc_main(void) { #ifdef DEBUG debug(); #endif /* System clocks configuration ---------------------------------------------*/ ADC_RCC_Configuration(); /* NVIC configuration ------------------------------------------------------*/ ADC_NVIC_Configuration(); /* GPIO configuration ------------------------------------------------------*/ ADC_GPIO_Configuration(); /* ADC1 Configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;// ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 4; ADC_Init(ADC1, &ADC_InitStructure); DMA_Config(); /* ADC1 regular channel10--13 configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_239Cycles5); printf("please watch the led1,if it light on and off ,adc ok!\n"); /* ADC1 regular channel8 configuration */ // ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_13Cycles5); /* Configure high and low analog watchdog thresholds */ // ADC_AnalogWatchdogThresholdsConfig(ADC1, 0x0B00, 0x0300); /* Configure channel8 as the single analog watchdog guarded channel */ // ADC_AnalogWatchdogSingleChannelConfig(ADC1, ADC_Channel_8); /* Enable analog watchdog on one regular channel */ // ADC_AnalogWatchdogCmd(ADC1, ADC_AnalogWatchdog_SingleRegEnable); /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* Enable AWD interupt */ // ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE); /* Enable DMA Channel1 complete transfer interrupt */ // DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Enable ADC1 reset calibaration register */ ADC_ResetCalibration(ADC1); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibaration */ ADC_StartCalibration(ADC1); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); /* Start ADC1 Software Conversion */ ADC_SoftwareStartConvCmd(ADC1, ENABLE); // ADC1->CR2 |= 0X00400000; while(!DMA_GetFlagStatus(DMA1_FLAG_TC1)); /* Clear Channel 1 DMA_FLAG_TC flag */ DMA_ClearFlag(DMA1_FLAG_TC1); while (1) { Delay(1000); // printf("%d,%d,%d,%d\n",ADC_ConvertedValue[0],ADC_ConvertedValue[1],ADC_ConvertedValue[2],ADC_ConvertedValue[3]); } } /******************************************************************************* * Function Name : ADC_RCC_Configuration * Description : Configures the different system clocks. * Input : None * Output : None * Return : None *******************************************************************************/ void ADC_RCC_Configuration(void) { /* RCC system reset(for debug purpose) */ RCC_DeInit(); /* Enable HSE */ RCC_HSEConfig(RCC_HSE_ON); /* Wait till HSE is ready */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) { /* Enable Prefetch Buffer */ FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /* Flash 2 wait state */ FLASH_SetLatency(FLASH_Latency_2); /* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK2 = HCLK */ RCC_PCLK2Config(RCC_HCLK_Div1); /* PCLK1 = HCLK/2 */ RCC_PCLK1Config(RCC_HCLK_Div2); /* ADCCLK = PCLK2/4 */ RCC_ADCCLKConfig(RCC_PCLK2_Div4); /* PLLCLK = 8MHz * 9 = 72 MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /* Enable PLL */ RCC_PLLCmd(ENABLE); /* Wait till PLL is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } /* Select PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08) { } } /* Enable peripheral clocks --------------------------------------------------*/ /* Enable ADC1 and GPIO_LED clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIO_LED, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); } /******************************************************************************* * Function Name : ADC_GPIO_Configuration * Description : Configures the different GPIO ports. * Input : None * Output : None * Return : None *******************************************************************************/ void ADC_GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Configure GOIO_LED pin 6 as output push-pull ----------------------------*/ // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // GPIO_Init(GPIO_LED, &GPIO_InitStructure); /* Configure PC.00---PC0.03 (ADC Channel8) as analog input -------------------------*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); } /******************************************************************************* * Function Name : NVIC_Configuration * Description : Configures NVIC and Vector Table base location. * Input : None * Output : None * Return : None *******************************************************************************/ void ADC_NVIC_Configuration(void) { // NVIC_InitTypeDef NVIC_InitStructure; #ifdef VECT_TAB_RAM /* Set the Vector Table base location at 0x20000000 */ NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else /* VECT_TAB_FLASH */ /* Set the Vector Table base location at 0x08000000 */ NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif /* Configure and enable ADC interrupt */ // NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQChannel; // NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; // NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; // NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // NVIC_Init(&NVIC_InitStructure); } 每次在ADC_ConvertedValue里只有一个数据?其它的数据为0,请大家分析下?谢谢! |
RE:stm32 ADC多通道用DMA传输问题
*****可能应修改存储器数据宽度宽度为32*****
