| 刚装了IAR5.4 EV版,在编译ucos-ii的os_cpu_a.asm文件时出错:Error[412]: Branch to unaligned address E:\irobot\uCOS-II\Ports\ARM-Cortex-M3\Generic\IAR\os_cpu_a.asm 201 Error while running Assembler 。用5.3时并没有这个问题啊 |
回复:ucos-ii在IAR5.4下编译通不过
我试了是可以的。
这个问题只是在IAR ARM5.4中才有,5.2的就没有。
OS_CPU_PendSVHandler
CPSID I ; Prevent interruption during context switch
MRS R0, PSP ; PSP is process stack pointer
CBZ R0, OS_CPU_PendSVHandler_nosave ; Skip register save the first time
SUBS R0, R0, #0x20 ; Save remaining regs r4-11 on process stack
STM R0, {R4-R11}
LDR R1, =OSTCBCur ; OSTCBCur->OSTCBStkPtr = SP;
LDR R1, [R1]
STR R0, [R1] ; R0 is SP of process being switched out
;加入下面的这个"THUMB"就可以了
THUMB
; At this point, entire context of process has been saved
PUSH {R14} ; Save LR exc_return value
LDR R0, =OSTaskSwHook ; OSTaskSwHook();
BLX R0
POP {R14}
LDR R0, =OSPrioCur ; OSPrioCur = OSPrioHighRdy;
LDR R1, =OSPrioHighRdy
LDRB R2, [R1]
STRB R2, [R0]
LDR R0, =OSTCBCur ; OSTCBCur = OSTCBHighRdy;
LDR R1, =OSTCBHighRdy
LDR R2, [R1]
STR R2, [R0]
LDR R0, [R2] ; R0 is new process SP; SP = OSTCBHighRdy->OSTCBStkPtr;
LDM R0, {R4-R11} ; Restore r4-11 from new process stack
ADDS R0, R0, #0x20
MSR PSP, R0 ; Load PSP with new process SP
ORR LR, LR, #0x04 ; Ensure exception return uses process stack
CPSIE I
BX LR ; Exception return will restore remaining context
END
RE:ucos-ii在IAR5.4下编译通不过
