NRF905 RF903 CC1100 CC2500 CC1020 NRF2401 NRF24L01 无线数传芯片/模块性能汇总及应用指南
RE:主流无线汇总,值得收藏,无线项目选型必备
lv bags for sale
http://smartrf.taobao.com/view_page-9023479.htm
=============串口透传系列====================
RF1212无线透传模块(¥70)
https://item.taobao.com/item.htm?id=8208914830
=============2.4GHZ频段系列==================
NRF24L01+无线数传模块(¥15)
https://item.taobao.com/item.htm?id=1032089428
A7105无线数传模块(¥20)
https://item.taobao.com/item.htm?id=8283932112
CC2500无线数传模块(¥25)
https://item.taobao.com/item.htm?id=4483187508
NRF2401A无线数传模块(¥35)
https://item.taobao.com/item.htm?id=17599640
BK2411无线数传模块(¥15)
https://item.taobao.com/item.htm?id=3357769428
=============433MHZ频段系列==================
CC1101无线数传模块(¥24)
https://item.taobao.com/item.htm?id=734103148
NRF905无线数传模块(¥33)
https://item.taobao.com/item.htm?id=734183536
A7102无线数传模块(¥35)
https://item.taobao.com/item.htm?id=2264659046
SI4432无线数传模块(¥55)
https://item.taobao.com/item.htm?id=3357644114
CC1020无线数传模块(¥65)
https://item.taobao.com/item.htm?id=2730899708
ADF7021无线模块(¥68)
https://item.taobao.com/item.htm?id=4073723866
=============无线USB系列=====================
RF24L01USB数传模块(¥90)
https://item.taobao.com/item.htm?id=1993121052
RF2401USB数传模块(¥90)
https://item.taobao.com/item.htm?id=27318516
RF1101USB数传模块(¥120)
https://item.taobao.com/item.htm?id=18966640
RF905USB数传模块(¥120)
https://item.taobao.com/item.htm?id=739348384
RF7102USB数传模块(¥130)
https://item.taobao.com/item.htm?id=2921628732
=============ZIGBEE系列======================
ZIGBEE系列-CC2420数传模块(¥65)
https://item.taobao.com/item.htm?id=3462334072
ZIGBEE系列-CC2520无线模块(¥70)
https://item.taobao.com/item.htm?id=5473856328
=============有源RFID系列====================
RFID有源模块 (¥50)
https://item.taobao.com/item.htm?id=8274101190
=============ARM9系列========================
ARM9系列-AT91SAM9260(¥480)
https://item.taobao.com/item.htm?id=5536149456
ARM9系列-AT91SAM9261(¥660)
https://item.taobao.com/item.htm?id=4867678084
ARM9系列-AT91SAM9263(¥730)
https://item.taobao.com/item.htm?id=5676012398
ARM9系列-S3C2440(¥520)
https://item.taobao.com/item.htm?id=4739441972
51系列无线评估(¥320)
https://item.taobao.com/item.htm?id=275030646
AVR系列无线评估(¥420)
https://item.taobao.com/item.htm?id=1213057118
430系列无线评估(¥480)
https://item.taobao.com/item.htm?id=2883025694
LPC系列无线评估(¥490)
https://item.taobao.com/item.htm?id=5874889392
(1) 3.3V电压下,最大有效发射功率10dbm(约合10mw);
(2) 工作频率390-470MHz可设置,适合多节点的跳频通信;
(3) UART/TTL串行接口(只需连接TXD RXD GND VCC就收发通信)支持
(4) 1200/2400/4800/9600/19200/38400/57600bps波特率;
(5) 低功耗,休眠状态仅为1.5uA,可满足低功耗设备的要求;
(6) 通信速率、发射功率可软件设置(免费提供上位机配置软件);
(7) FSK调制,采用高效纠错编码,抗干扰能力强,接收灵敏度高;
(8) 数据缓冲,支持一次收发数据包长达高达256字节;
(9) 模块采用DIP-2.54mm间距接口,即插即用,便于嵌入式应用;
配2.5dbi增益棒状天线,实测500米以内稳定传输,700米仍有信号,如配更高增益(一般5dbi以上,但体积大)天线可达1000米以上,而普通NRF905、CC1101的通信距离在200米左右,而且接收电流都在20mA 左右!\
详细介绍http://www.rfinchina.com/product.aspx?pid=89
回复:主流无线汇总,值得收藏,无线项目选型必备
UTC1212无线模块功能简介视频:https://v.youku.com/v_show/id_XMzA5NTcyMzcy.html
UTC1212无线模块通信演示视频:https://v.youku.com/v_show/id_XMzA5NjQyNjQ4.html
UTC1212参数设置演视频:https://v.youku.com/v_show/id_XMzA5NjEyMDI4.html
网购连接:
上位机(电脑)配套无线模块:https://item.taobao.com/item.htm?id=9399851548
下位机(MCU) 配套无线模块:
STM8+SX1212+5.2CM天线:https://item.taobao.com/item.htm?id=8998806322
STM8+SX1212+8.5CM天线:https://item.taobao.com/item.htm?id=8208914830
STM8+SX1212+2.5CM天线:https://item.taobao.com/item.htm?id=8999297932
参数设置及测试功能模块:https://item.taobao.com/item.htm?id=8545545256
大功率超远距离1212模块:https://item.taobao.com/item.htm?id=14595310568&
行业应用
物流跟踪、仓库巡检、电子标签等
替代232、485进行无线数据通信
工业仪器仪表无线数据采集和控制
AMR(水、电、煤气)三表自动抄表
住宅与建筑物(智能家居)控制
机器人控制、电子消费类产品无线遥控
生物信号采集、水文气象监控、无线传感器网络
备注
1、天线周围一定要开阔,远离电池、金属等,天线周围PCB禁止敷铜,必要的时候,PCB和天线重叠的部分要挖空或者打孔。
2、当设计的产品放在金属外壳、金属机柜时,必须用馈线把信号从天线引出来外接SMA头的橡胶天线或者吸盘天线,否则信号被金属外壳屏蔽而使距离大打折扣,要求距离远的,可使用高增益天线。
3、电源设计。电源是整个系统的心脏,设计时应重点考虑。无线模块推荐工作电压3.3V,瞬态电流能提供200mA以上。
4、采用DCDC、LDO降压,还要考虑纹波和浪涌电流的冲击。纹波可以在接入模块电源的地方用LC网络处理;浪涌电流可以接大电容处理。
5、如果采用电池供电,应考虑电池的瞬态电流是否足够,推荐用锂电池 镍氢电池不推荐用干电池。
6、软件设计时,应尽量使用数据包通信,通信设置速率越低,距离越远。
7、当使用DEMO程序以外的通信速率通信时,应用参数计算工具,重新计算通信参数。并根据自己产品通信要求,适当调整。
8、做批量生产的产品时,如考虑产品的可测试性、可维修性、可替换性,应尽量采用DIP接口。
UTC1212模块是高度集成超低功耗半双工微功率无线数据传输模块,片上集成嵌入低功耗STM8,采用最新一代高性能射频芯片SX1212。其中SX1212创新的采用高效的循环交织纠检错编码,使抗干扰和灵敏度都大大提高,模块提供了多个频道的选择,可在线修改串口速率,发射功率,射频速率等各种参数,二次开发简单方便,当然也可以通过MCU来设置常规参数,模块电压范围为2.1-3.6V,适合电池供电,和手持设备应用开发,在接收状态仅仅消耗5.5mA,有四种工作模式。在1SEC周期轮询唤醒省电模式(Polling mode)下,接收仅仅消耗不到20uA,理论上一节3.6V/3.6A时的锂亚电池可工作10年以上
基本工作原理:
模块平时处于接收状态,一旦收到数据,就把收到的数据通过UART输出,这时你可以用单片机来个中断接收函数啊,把数据读取存储,
发送数据的时候把要发的数据通过UART送给1212模块,他就自动发送,发送完毕,自动切换到接收模式
功能特点
(4) 1200/2400/4800/9600/19200/38400/57600bps波特率; A
配我们公司的8.5cm(2.5dbi增益)棒状天线,实测500米以内稳定传输,700米仍有信号,如配更高增益(一般5dbi以上,但体积大)天线可达1000米以上,而普通NRF905、CC1101的通信距离在200米左右,而且接收电流都在20mA 左右!
