Nikon Remote 程序代码
废鱼 提问时间:2009-12-21 15:18 /
这个工程设计将正确的同步信号发送到GPIO。这个信号连接一个IR二极管传输照相机信号。
This project will send the correct timed signal to an GPIO defined in the program.
This signal must be connected to an IR diode to transmit the signal to the camera.
(either an external or the extra pin in the IRDA device)
This has been tested working on D40.
The project is not completely finished but is published "as it is"...
Kasper
Nikon-Remote-1[1].00.zip
68.39 KB, 下载次数: 12, 下载积分: ST金币 -1
赞 收藏 评论0 发布时间:2009-12-21 15:18
