Primer2 的SD文件例程
废鱼 发布时间:2010-3-22 16:29
 这个工程主要是简单的显示SD卡的文件目录。
- [" `1 d) i9 UThis project implements a simple file explorer that displays the directory structure on the SD card.The included CircleOs binary include a SDIO driver and a Fat12/16/32 implementation based on DosFS. This a demo project to show usage of the SD card.
6 B" d6 V  d  S' h: F' O9 OThis project is aimed to be a demo project about how to use the CircleOS filesystem. It can display PRM (converted BMP, JPG, etc) images with a sample viewer.; e" q: p4 T/ w& `+ C- `* s
Included in this project an application to convert BMP, JPG, etc files to PRM with the functionality to scale the image to a desired resolution.) n1 s# D' W. D4 F9 \
 Current layout of PRM image file:& @( Y( W* I3 B3 j5 G9 }1 D  V* a
 8byte header:! v! v$ l3 j6 c0 ]7 w& d
- byte 0: height
" r+ P" k* W" Z9 P- byte 1: width
* v* {( `/ }* ]+ q! Z% e9 y; V& }- 6 bytes for future use) f, N4 }& z  y0 q& S" U( ^1 Y
- pixel data (2 bytes per pixel)6 [; e0 S, S: q- w3 K* P
 FS interface functions:
9 ]' g1 V+ `( `( N- _8 du32 FS_Mount(enum STORAGE_device device);6 z) ~! r8 x6 O$ `2 f( S+ Z" K
u32 FS_Unmount(enum STORAGE_device device);
4 f6 N# G( _7 z1 `- C' Ou32 FS_OpenFile(PVOLINFO volinfo, u8 *path, u8 mode, PFILEINFO fileinfo);
: ?- `0 q) i  p! Y, \) ]+ J" Xu32 FS_ReadFile(PFILEINFO fileinfo,  u8 *buffer, u32 *successcount, u32 len);1 B6 [8 E  ]4 P3 K/ x' H
u32 FS_WriteFile(PFILEINFO fileinfo,  u8 *buffer, u32 *successcount, u32 len);% ^+ v  j4 Y. ~; i* J
u32 FS_Close(PFILEINFO fileinfo);
! r' A$ K6 V, j. ]. `, gvoid FS_Seek(PFILEINFO fileinfo, u32 offset);) [1 `  q* S2 K8 Y7 H) E/ d& A
u32 FS_Delete(PVOLINFO volinfo, u8 *path);
" r, ?* }0 [9 fu32 FS_GetNextEntry(PVOLINFO volinfo, PDIRINFO dirinfo, PDIRENT dirent);
2 `' [& |* n  t8 `- {4 uu32 FS_OpenDirectory(PVOLINFO volinfo,u8 *dirname, PDIRINFO dirinfo);
' p/ [5 O; U' U4 nu32 FS_GetVolumeInfo(u8 unit,  u32 startsector, PVOLINFO volinfo);
1 e% Z9 I  s- w4 _  b; y4 O 7 |( x+ k) h2 s$ P
 0 j) @' k4 q* k. L0 s. G
This is a snapshot of my current work in progress with partially integrated jpg decompressor
0 U  k5 B% u% m& c: }( r6 a9 r2 ~. q+ I# a$ B, c7 z0 c
赞 收藏 评论0 发布时间:2010-3-22 16:29
