STM32 串口配置
废鱼 提问时间:2010-4-21 13:46 /
#include "stm32f10x_lib.h"
u16 RecDateBuffer[100];
u16 RecLen;
u8 SendDateBuffer[100];
* Function Name  : Uart_Ini
* Description    : 串口初始化
* Input          :
* Output         : None
* Return         :
void USART_Ini(USART_TypeDef* USARTx,u16 buad)
   USART_ClockInitTypeDef USART_ClockIni;
   /* Configure USART1 Tx (PA.09) as alternate function push-pull */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
   GPIO_Init(GPIOD, &GPIO_InitStructure);
   /* Configure USART1 Rx (PA.10) as input floating */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
   USART_InitStructure.USART_BaudRate = 9600;      //串口波特率
   USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //串口数据长度
   USART_InitStructure.USART_StopBits = USART_StopBits_1;   //串口停止位
   USART_InitStructure.USART_Parity = USART_Parity_No;    //串口奇偶效验位
   USART_InitStructure.USART_Mode = USART_Mode_Rx|USART_Mode_Tx; //串口模式,开始起发送和接收
   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //串口硬件流
   USART_ClockIni.USART_Clock = USART_Clock_Disable;
   USART_ClockIni.USART_CPOL = USART_CPOL_Low;
   USART_ClockIni.USART_CPHA = USART_CPHA_2Edge;
   USART_ClockIni.USART_LastBit = USART_LastBit_Disable;
   USART_Init(USARTx,&USART_InitStructure);
   USART_ClockInit(USARTx,&USART_ClockIni);
   /* Enable USART1 */
  USART_Cmd(USARTx, ENABLE);  //开启串口X
* Function Name  : Getch
* Description    : 串口中断开启或关闭
* Input          : USARTx:x=串口号
                   NewState: ENABLE开启中断,DISABLE关闭中断
* Output         : None
* Return         :
void USART_IT(USART_TypeDef* USARTx,FunctionalState NewState)
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 5;
   if(NewState==ENABLE)
     USART_ITConfig(USARTx,USART_IT_RXNE | USART_IT_TXE,ENABLE);
   else
     USART_ITConfig(USARTx,USART_IT_RXNE | USART_IT_TXE,DISABLE);
* Description    : 串口接收字符
* Output         : None
* Return         :
u16 Getch(USART_TypeDef* USARTx)
   u16 ch;
   if (USART_GetFlagStatus(USARTx,USART_FLAG_RXNE)==SET)
     ch=USART_ReceiveData(USARTx);
  //return(ch);
   return(ch);
* Description    : 接收字符串
       buffer:接收字符串数组
* Output         : None
* Return         :
void GetStr(USART_TypeDef* USARTx)
    //u16 i;
 while(USART_GetFlagStatus(USARTx,USART_FLAG_RXNE)==SET)
   if(USART_GetFlagStatus(USARTx,USART_FLAG_ORE)==RESET)
      if(RecLen
赞 收藏 评论5 发布时间:2010-4-21 13:46
5个回答
lf8013 回答时间:2010-10-8 22:25:15
RE:STM32 串口配置
在学校串口,谢谢了
zzz80675@sohu.c 回答时间:2010-11-14 09:57:11
RE:STM32 串口配置
谢谢了
wdooy 回答时间:2010-11-17 17:42:01
RE:STM32 串口配置
谢谢了 我遇到的问题很多,唉,我也无语了对川口来说!!!
瘦猪呆兔 回答时间:2011-4-21 15:22:45
RE:STM32 串口配置
RCC不配置好像不行的吧!?
uniqueeefocus34 回答时间:2013-2-8 15:03:12
RE:STM32 串口配置
对啊,要先配置GPIO和串口的RCC
