我用的是IAR 4.41 写的程序,通过JLINK下到FLASH中,下不了求原因(但是下到RAM中没有问题)
twm19870918 提问时间:2010-4-25 01:44 /
错误代码如下:Sun Apr 25 01:20:44 2010: DLL version: V3.72a, compiled Jun 18 2007 18:58:11Sun Apr 25 01:20:44 2010: Firmware: J-Link ARM V7 compiled Jun 30 2009 11:05:27Sun Apr 25 01:20:44 2010: JTAG speed is initially set to: 32 kHzSun Apr 25 01:20:44 2010: Found Cortex-M3, Little endian.Sun Apr 25 01:20:44 2010: TPIU fitted.Sun Apr 25 01:20:44 2010: ETM fitted.Sun Apr 25 01:20:44 2010:   FPUnit: 6 code (BP) slots and 2 literal slotsSun Apr 25 01:20:44 2010: Software reset was performedSun Apr 25 01:20:44 2010: Initial reset was performedSun Apr 25 01:20:44 2010: J-Link found 2 JTAG devices. ARM core Id: 3BA00477(Cortex M3), ARM core Id: 00000000(ARM9)Sun Apr 25 01:20:44 2010: Device at TAP0 selectedSun Apr 25 01:20:45 2010: 3518 bytes downloaded and verified (5.23 Kbytes/sec)Sun Apr 25 01:20:45 2010: Warning: Verify error at address 0x200000C0, target byte: 0x54, byte in file: 0x53Sun Apr 25 01:20:45 2010: Warning: Verify error at address 0x200000C1, target byte: 0x05, byte in file: 0xF0Sun Apr 25 01:20:45 2010: There were warnings during download of FLASH loader, see Log WindowSun Apr 25 01:20:49 2010: Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 4.0 Evaluation\arm\config\flashloader\ST\FlashSTM32F10xxE.d79谢谢高手帮忙。。
赞 收藏 评论1 发布时间:2010-4-25 01:44
废鱼 回答时间:2010-4-26 11:49:02
RE:我用的是IAR 4.41 写的程序,通过JLINK下到FLASH中,下不了求原因(但是下到RAM中没有问题)
这个可能是你的JLINK设置问题,建议你联系一下JLINK的卖家,是否需要将DLL文件更换。
