STM8/128-MCKIT
# S+ ^! R" |4 ~, UDescription
$ l) P& C- R M+ c0 L) \/ R, P) f% ?/ T4 c, I
1 y9 f' ]% l0 h. h/ A- a
+ y; r( y: p) p8 s( {
1 Z* h2 v$ ^" R8 v2 C' v* F0 l
$ \- j( h' l6 C5 t& ]* f2 V, {* |
The STM8/128-MCKIT starter kit is an integrated system designed to provide a complete, ready-to-use motor control application developed around the STMicroelectronics STM8 microcontroller.
0 \6 L4 s1 }1 y) v9 D0 d w- k3 g& B5 j2 j
This starter kit is particularly suited to drive 3-phase brushless motors (either AC induction or permanent magnet types) and demonstrates how effectively the STM8 microcontrollers can be used in real-world motor control applications.
& j5 L( @1 Q, Y) S2 ^
2 f B( U6 m7 W, i# h6 X8 BHowever, the main advantage of the STM8/128-MCKIT is that you can use it to create your own applications and re-program the STM8 microcontroller. You can develop your own applications using the dedicated software libraries provided in the starter kit in conjunction with a third-party IDE and C compiler.8 F( X$ T5 p7 c. o6 W
Key Features
$ k/ b+ j# r5 G f4 b# e! O0 r
( ]2 ]# Y, d2 H7 C$ S }
; O. _$ l) ?5 \+ F: s; }+ x5 V$ y6 b6 b# c* m8 a: _
( J6 q" A( H. P J# `& ^
- s( `! A2 b7 U* r
. _- _. d% G; ?! T! B+ _3 l W; w3 f 6 S5 |! @( @3 R- S( T
- Motor drive based on scalar control (BLDC or ACIM) for three-phase motors
& D, h, x. n" x2 ~5 n: Y) O - Position and/or speed measurement is implemented using Hall sensors or a tachometer.
$ i: }% @# c9 v, ] - Sensorless control
d/ c% [4 i7 m- C: `& z$ H# U# m - The inverter is driven using the PWM modulation technique.
) {9 E5 X/ |, I- o* m0 H$ T1 E$ C, K - Acts as a plug-and play demo, out of the box, with the provided BLDC motor, in sensorless speed control mode
0 a& r4 @$ y1 Q; w1 Z5 @% B4 b! o) Z - Operates with an AC induction motor, after reprogramming the microcontroller, in open loop or in speed control mode% R4 i& Y6 Z @# E4 U
. C7 {* K9 y' |7 `& D0 x% z- k0 L$ K4 u6 V9 m
多谢楼主资料进行学习。
RE:STM8S 直流电机例程及相关资料
回复:STM8S 直流电机例程及相关资料
