求助:STM32F103C8T6的TIM2:为什么是0.5s,不是1s?
zhenjun_qi 提问时间:2012-8-3 06:40 /
请教:LED应该为什么不是“灭1s,亮1s”,而是“灭0.5s,亮0.5s”?
背景:
(1)芯片:STM32F103C8T6;外部晶振8M;
(2)代码如下:
#define Led1_Toggle GPIO_WriteBit(GPIOB, GPIO_Pin_14, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_14)))
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 35999;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* TIM IT enable */
  TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
  while (1);
void RCC_Configuration(void)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOC clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);
void TIM2_IRQHandler(void)
 if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
  TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
  Led1_Toggle;
(3)问题描述:我计算的Led1应该是“灭1s,亮1s”循环,为什么下载到板子上的现象是“灭0.5s,亮0.5s”循环?
我的计算方法:APB1的频率是72MHz/2=36M
((1+prescaler)/36MHz)*(1+period)=1s
为什么不是0.5s?哪里有错?谢谢!
赞 收藏 评论2 发布时间:2012-8-3 06:40
废鱼 回答时间:2012-8-3 09:43:03
RE:求助:STM32F103C8T6的TIM2:为什么是0.5s,不是1s?
这里应该是72Mhz的。我的程序里面写的也是按72Mhz算的。
银洋电子 回答时间:2012-8-3 10:34:23
很好的帖子!帮你把帖子顶起来!
