【探索发现STM32 F3系列】在移植uCOS-II+uCGUI时出现的错误,求解决!
xiaoyu-398191 提问时间:2012-12-27 11:01 /
在移植uCOS-II+uCGUI时出现的错误,求解决。
compiling App.c...
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(23): error:  #256: invalid redeclaration of type name "s32" (declared at line 487 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef signed long  s32;
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:                        ^
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(27): error:  #256: invalid redeclaration of type name "sc32" (declared at line 491 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef signed long  const sc32;  /* Read Only */
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(31): error:  #256: invalid redeclaration of type name "vs32" (declared at line 495 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef volatile signed long  vs32;
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(35): error:  #256: invalid redeclaration of type name "vsc32" (declared at line 499 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef volatile signed long  const vsc32;  /* Read Only */
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(39): error:  #256: invalid redeclaration of type name "u32" (declared at line 503 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef unsigned long  u32;
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(43): error:  #256: invalid redeclaration of type name "uc32" (declared at line 507 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef unsigned long  const uc32;  /* Read Only */
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(47): error:  #256: invalid redeclaration of type name "vu32" (declared at line 511 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef volatile unsigned long  vu32;
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(51): error:  #256: invalid redeclaration of type name "vuc32" (declared at line 515 of "..\Libraries\CM3\stm32f10x.h")
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef volatile unsigned long  const vuc32;  /* Read Only */
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(57): error:  #101: "RESET" has already been declared in the current scope
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h:   typedef enum {RESET = 0, SET = !RESET} FlagStatus, ITStatus;
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(57): error:  #101: "SET" has already been declared in the current scope
C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(57): error:  #256: invalid redeclaration of type name "FlagStatus" (declared at line 519 of "..\Libraries\CM3\stm32f10x.h")
出现这么多错误,我知道是新的st库跟keil安装的老版本的库之间的冲突,新的st库是用3.50的
求大侠搭救                              ^
赞 收藏 评论1 发布时间:2012-12-27 11:01
代码小呆瓜 回答时间:2013-3-26 10:36:43
回复:【探索发现STM32 F3系列】在移植uCOS-II+uCGUI时出现的错误,求解决!
stm32f10x_type.h 中有很多的变量在stm32f10x.h中已经声明了,只要把stm32f10x_type.h声明处屏蔽就行了
