请教关于STM32F103USART串口接收的问题,附代码
alex-417263 提问时间:2013-3-20 17:21 /
各位我用查询方式接收串口数据,结果接收不到:期待高人指点。
串口配置如下:
/* USART1 config 9600 8-N-1 */
  /* config USART1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
  /* USART1 GPIO config */
  /* Configure USART1 Rx PA10 input floating */
  /* Configure USART1 Tx (PA9) as alternate push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
/* USART1 mode config */
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_Init(USART1, &USART_InitStructure);
  USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
//  USART_ITConfig(USART1,USART_IT_TXE,ENABLE);
  USART_Cmd(USART1, ENABLE);
代码如下:
void Commun_232_Receive(void)
    static   uint16_t Data_Rec[4]={0,0,0,0};
    static   uint16_t FrameHead=0;
    static   uint16_t Data_Num=0;
    static   uint16_t i=0,j=0,k=0;
    uint16_t crc=0,crc1=0;
//    Receive_Status= USART_GetITStatus(USART1, USART_IT_RXNE);
    Receive_Status= USART_GetFlagStatus(USART1, USART_FLAG_RXNE);
//    if(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) = 1)
    if(Receive_Status==1)//有数据
        Data_receive = USART_ReceiveData(USART1);//接收数据
        Data_receive&=0xFF;
//        USART_ClearFlag(USART1,USART_FLAG_RXNE);//清除接收非空标志位
        if(FrameHead==0&&Data_receive==0x35)//找帧头
            FrameHead=1;   //找到帧头
        else if(FrameHead==1)
            Data_Rec[Data_Num]=Data_receive;
            Data_Num++;
            if(Data_Num>4)
                Data_Num=0;
                FrameHead=0;
                Data_Rec[2] = Data_Rec[2] BSRR = 0x00000008;
                                /* Set PA3 */
                         Switch_Status.bit.TA0=1;
                            else if(Data_Rec[1]==1)
                                GPIOA->BRR = 0x00000008;
                                /* Reset PA3 */
                         Switch_Status.bit.TA1=1;
                            break;
                        case 2:
                            if(Data_Rec[1]==0)
                                GPIOA->BSRR = 0x00000010;
                                /* Set PA4 */
                         Switch_Status.bit.TA2=1;
                                GPIOA->BRR = 0x00000010;
                                /* Reset PA4 */
                         Switch_Status.bit.TA3=1;
                            break;
                        case 3:
                            if(Data_Rec[1]==0)
                                GPIOA->BSRR = 0x00000020;
                                /* Set PA5 */
                         Switch_Status.bit.TA4=1;
                                GPIOA->BRR = 0x00000020;
                                /* Reset PA5 */
                         Switch_Status.bit.TA5=1;
                            break;
                        case 4:
                            if(Data_Rec[1]==0)
                                GPIOA->BSRR = 0x00000040;
                                /* Set PA6 */
                         Switch_Status.bit.TA6=1;
                                GPIOA->BRR = 0x00000040;
                                /* Reset PA6 */
                         Switch_Status.bit.TA7=1;
                            break;
                        case 5:
                            if(Data_Rec[1]==0)
                                GPIOA->BSRR = 0x00000080;
                                /* Set PA7 */
                         Switch_Status.bit.TA8=1;
                                GPIOA->BRR = 0x00000080;
                                /* Reset PA7 */
                         Switch_Status.bit.TA9=1;
                            break;
赞 收藏 评论2 发布时间:2013-3-20 17:21
zykzyk-93033 回答时间:2013-3-20 21:12:14
RE:请教关于STM32F103USART串口接收的问题,附代码
已经到中断里面了吧。他就有这个毛病。txe标志。你看看
alex-417263 回答时间:2013-4-10 11:24:48
问题已解决,将GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
改为下拉输入模式就好了。
