STM32F107VCT6串口通信,选用的是查询方式遇到的问题
question0303 提问时间:2013-3-28 21:58 /
一开始用中断通信,能够成功,但是用每次复位下,才能发送数据,所以想选择查询方式,就去掉了中断配置,其他的串口通信的配置留下,然后
TxCounter=0;
    while(TxCounter < sendBufferSize)
     /* Send one byte from USART1 */
     USART_SendData(USARTy, sendBuffer[TxCounter++]);
     /* Loop until USART1 DR register is empty */
     while(USART_GetFlagStatus(USARTy, USART_FLAG_TXE) == RESET);
发送过去,但是PC就是无法接收数据……
/* Includes ------------------------------------------------------------------*/
#include "config.h"
#include "collector.h"
#include "button.h"
#include "led.h"
#include "platform_config.h"
#include "stm32f10x.h"
#include "stm3210c_eval_lcd.h"
#include "stm32_eval.h"
#include
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private Variables -----------------------------------------------------------------*/
#define BUFFER_SIZE                 64
#define EMVIEW_FRAME_SIZE           3
#define EMVIEW_START_OF_NODE_ID     1
#define EMVIEW_START_OF_TEMP        2
#define REPORT_INTERVAL 0xfffff  //0x1 ~ 0xffff ffff, and 0xfffff is about 3 second
//#define REPORT_INTERVAL 0xfff
#define REPORT_LEN  6
#define REPORT_NODEID_INDEX   0
#define REPORT_TEMP_INDEX     2
#define REPORT_HUM_INDEX      4
int32u  readyToSendCoordInfo = REPORT_INTERVAL;
uint8_t TxCounter = 0;
uint8_t sendBuffer[EMVIEW_FRAME_SIZE];
static EmberNetworkStatus networkState = EMBER_NO_NETWORK;
EmberNetworkParameters networkParams;
EmberNodeType nodeType;
//extern ButtonStatus K3Status;
boolean button3Press = FALSE;  // for button push (see halButtonIsr)
int8u tmpBuffer[EMVIEW_FRAME_SIZE]=
  0xaa,//start
  0x00, 0x00//data
/* Private function prototypes -----------------------------------------------*/
static void applicationTick(void);
USART_ClockInitTypeDef USART_ClockInitStructure;
/* Variables -----------------------------------------------------------------*/
/* Define the endpoint (number + description) required for the ezspUtilInit()
 function */
int8u emberEndpointCount = 1;
EmberEndpointDescription endpointDescription = { PROFILE_ID, 0, };
EmberEndpoint emberEndpoints[] = {
  { ENDPOINT, &endpointDescription },
int8u extendedPanId[EXTENDED_PAN_ID_SIZE] = APP_EXTENDED_PANID;
void sendFrame(uint8_t nodeId, uint8_t temperature);
void RCC_Configuration(void);
void GPIO_Configuration(void);
/* Functions -----------------------------------------------------------------*/
/* light application main function */
int main()
   EmberStatus status;
   EzspStatus stat;
#ifdef DEBUG
   debug();
#endif
   /* configure system clocks (when needed) */
   CLK_Configuration();
   /* Init the interrupt */
   Interrupt_Init();
   /* init the buttons */
   halInternalInitButton();
   /* init leds */
   halInternalInitLed();
   /* Initialize the serial protocol interface SPI */
   hal260SerialInit();
   /* Enable external interrupt */
   Interrupt_Enable_EXT_INT(ENABLE);
   /* Enable Interrupt */
   Interrupt_Enable(ENABLE);
    /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  //NVIC_Configuration();
   STM3210C_LCD_Init();
    /* Clear the LCD */
   LCD_Clear(White);
    /* Set the LCD Text Color */
   LCD_SetTextColor(Black);
   printf("   light-switch  \n");
   stat = ezspInit();
   status = ezspUtilInit(APP_SERIAL, RESET_UNKNOWN);
   // Bring the network up.
   networkParams.panId = APP_PANID;
   networkParams.radioTxPower = APP_POWER;
   networkParams.radioChannel = APP_CHANNEL;
   MEMCOPY(networkParams.extendedPanId,
           extendedPanId,
           EXTENDED_PAN_ID_SIZE);
   status = emberFormNetwork(&networkParams);
 /* USARTy and USARTz configuration ------------------------------------------------------*/
  /* USARTy and USARTz configured as follow:
        - BaudRate = 9600 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
  /* Configure USARTy */
  USART_Init(USARTy, &USART_InitStructure);
   /* Configure the GPIO ports */
  GPIO_Configuration();
  /* Enable the USARTy */
  USART_Cmd(USARTy, ENABLE);//启动串口
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
  /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
     initialize the PLL and update the SystemFrequency variable. */
  SystemInit();
  /* Enable GPIO clock */
  RCC_APB2PeriphClockCmd(USARTy_GPIO_CLK | RCC_APB2Periph_AFIO, ENABLE);
#ifndef USE_STM3210C_EVAL
  /* Enable USARTy Clock */
  RCC_APB1PeriphClockCmd(USARTy_CLK, ENABLE);
#else
#endif
  * @brief  Configures the different GPIO ports.
  * @param  None
  * @retval None
#ifdef USE_STM3210C_EVAL
  /* Enable the USART2 Pins Software Remapping */   //重映射管脚
  GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
#elif defined USE_STM3210B_EVAL
#endif
  /* Configure USARTy Rx as input floating */
  GPIO_InitStructure.GPIO_Pin = USARTy_RxPin;//指定初始化的引脚位
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//设置GPIO模式 普通输入模式(浮空)
  GPIO_Init(USARTy_GPIO, &GPIO_InitStructure); //利用PIO_InitStructure来初始化GPIO
  /* Configure USARTy Tx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = USARTy_TxPin;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用功能的开漏输出模式 值为0x1C
   USART_HalfDuplexCmd(USARTy, ENABLE); //半双工模式
   while(1)
     emberTick();
    if( --readyToSendCoordInfo == 0)
   sendFrame(0x02,0x23);
   if (button3Press) {
      /* turn allow join on */
      emberPermitJoining(0xff);
      //turn on the lED_LD2 to show permit_join now
      halSetLed(LED_LD2);
   printf("permit node join \n");}
} // end main()
void ezspIncomingMessageHandler(EmberIncomingMessageType type,
                                EmberApsFrame *apsFrame,
                                int8u lastHopLqi,
                                int8s lastHopRssi,
                                EmberNodeId sender,
                                int8u bindingTableIndex,
                                int8u addressTableIndex,
                                int8u length,
                                int8u *message)
{ uint8_t i,sendBufferSize;
  sendBuffer[0] = tmpBuffer[0];
 tmpBuffer[EMVIEW_START_OF_NODE_ID] = nodeId;
 tmpBuffer[EMVIEW_START_OF_TEMP] = temperature;
  {for(i = 1, sendBufferSize = 1; i < EMVIEW_FRAME_SIZE ; i++)
   sendBuffer[sendBufferSize++] = tmpBuffer;
TxCounter=0;
收藏 评论0 发布时间:2013-3-28 21:58
