有关ADC-DMA配置问题
jerryh 提问时间:2013-12-31 10:44 /
以下是配置部分:
 ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* Enable ADC3, DMA2 and GPIO clocks ****************************************/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  /* DMA2 Stream0 channel2 configuration **************************************/
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_DMA1, ENABLE);
    __nop();                    //等待 DMA2 时钟稳定
  __nop();                    //经测试最少 2 个 nop
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    DMA_Cmd(DMA2_Stream0, ENABLE);
    /* DMA中断开 */
//   DMA_ITConfig(DMA2_Stream0,DMA_IT_TC,ENABLE);
    /* Configure ADC1 Channel7 pin as analog input ******************************/
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  /* ADC3 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_10b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
//   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
    /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
//     ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE); //使能ADC转换结束中断
//   ADC_ITConfig(ADC1, ADC_IT_OVR, ENABLE);
//     /*********************ADC看门狗配置***************************/
// ADC_AnalogWatchdogCmd(ADC3, ADC_AnalogWatchdog_SingleRegEnable);
// ADC_AnalogWatchdogThresholdsConfig(ADC3, 0x0E8B, 0x0555);  //阈值设置。高:3V 低:1V
// ADC_AnalogWatchdogSingleChannelConfig(ADC3, ADC_Channel_7);
  /* ADC3 regular channel7 configuration *************************************/
  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 1, ADC_SampleTime_144Cycles);
  /* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  /* Enable ADC3 DMA */
  ADC_DMACmd(ADC1, ENABLE);
//     ADC_ContinuousModeCmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
问题:直接读取ADC1ConvertedValue值,始终为0,结果不随AD输入改变。而用ADC_GetConversionValue(ADC1)函数读取采样值,结果又是对的,能说明AD转换这块没错吧,DMA传输不正确,到底哪错了???求大神赐教!谢谢
赞 收藏 评论16 发布时间:2013-12-31 10:44
16个回答
fengye5340 回答时间:2013-12-31 14:14:30
RE:有关ADC-DMA配置问题
1、检查 ADC1_DR_ADDRESS的地址是否正确
2、你是否设置了DMA的中断优先级呢?
3、你的DMA中断函数代码贴上看看
勒布朗 回答时间:2013-12-31 19:49:36
RE:有关ADC-DMA配置问题
单独运行AD部分没问题,说明AD部分配置正确,DMA传输有问题,那就仿真呗
有缘于你 回答时间:2013-12-31 20:40:35
RE:有关ADC-DMA配置问题
中断优先级设置了?
wkuang 回答时间:2013-12-31 22:54:58
RE:有关ADC-DMA配置问题
可以断定ADC肯定没有问题
1、时钟是否正确;??
2、DMA与AD的映射是否正确;
3、DMA中断是否有触发,有没有打过点;
看起来很黑 回答时间:2014-1-1 12:45:20
RE:有关ADC-DMA配置问题
中断优先级貌似没有设置NVIC
feiante-155820 回答时间:2014-1-2 09:27:31
回复:有关ADC-DMA配置问题
 给你看看这个能用的。
DMA.txt
1.92 KB, 下载次数: 15
DMA_h.txt
164 Bytes, 下载次数: 6
jerryh 回答时间:2014-1-2 10:28:00
回复:有关ADC-DMA配置问题
回复第 2 楼 于2013-12-31 14:14:30发表:
2、你是否设置了DMA的中断优先级呢?
3、你的DMA中断函数代码贴上看看
ADC1_DR_ADDRESS的地址为0X4001244C,没错吧。
中断优先级函数如下:
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/* ADC中断配置 */
  NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQn;           //嵌套通道为ADC_IRQn
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 7;    //响应优先级为 2
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;     //通道中断使能
    /* Enable the DMA7 Interrupt*/
  NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 8;
DMA中断函数如下:
void DMA2_Stream0_IRQHandler(void)
  if (DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0) != RESET)
    DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
需要哪些处理,在这里不懂诶???求指教!谢谢
jerryh 回答时间:2014-1-2 10:28:55
回复:有关ADC-DMA配置问题
回复第 7 楼 于2014-01-02 09:27:31发表:
 给你看看这个能用的。
好的,谢谢
jerryh 回答时间:2014-1-2 10:33:06
回复:有关ADC-DMA配置问题
回复第 5 楼 于2013-12-31 22:54:58发表:
可以断定ADC肯定没有问题
1、时钟是否正确;??
2、DMA与AD的映射是否正确;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);这条语句时能了时钟就可以了吗???
映射我查过了,ADC1映射到DMA的Stream0的第0通道,代码也没错的。
 DMA_ITConfig(DMA2_Stream0,DMA_IT_TC,ENABLE);这条语句我时能了传输完成中断,调试的时候确实能进中断的。
//         DMA_Cmd(DMA2_Stream0, DISABLE);
        printf("!! \r\n");
是用printf("!! \r\n");语句用串口显示判断的。
jerryh 回答时间:2014-1-2 10:33:47
回复:有关ADC-DMA配置问题
回复第 3 楼 于2013-12-31 19:49:36发表:
你说得是keil在线仿真吗???
jerryh 回答时间:2014-1-2 10:35:31
回复:有关ADC-DMA配置问题
回复第 4 楼 于2013-12-31 20:40:35发表:
中断优先级设置了?
中断优先级函数如下:
/* ADC中断配置 */
这样可以吗???
jerryh 回答时间:2014-1-2 10:36:15
回复:有关ADC-DMA配置问题
回复第 6 楼 于2014-01-01 12:45:20发表:
中断优先级貌似没有设置NVIC
中断优先级函数如下:
/* ADC中断配置 */
这样设置的,不懂问题出在哪???
dzc2001 回答时间:2014-1-2 23:16:49
RE:有关ADC-DMA配置问题
你这是哪个片子?ADC1的DMA通道是?
jerryh 回答时间:2014-1-3 09:55:29
回复:有关ADC-DMA配置问题
回复第 14 楼 于2014-01-02 23:16:49发表:
STM32F407,ADC1映射到DMA2的Stream0的channel_0通道
12下一页
