STM32F103CB----I2C读取错误
bei_ji 提问时间:2014-2-8 10:37 /
刚入手STM32的开发板,最近调试I2C时碰到难点,在读取0-8个字节时正常,在读取大于8个字节的数据时,实际读出的数据是第九个和之后的字节会将前面的数据覆盖,然后补齐0xff,比如"STM32F103CB",直接读取11个字节的结果是字符“03CB2F10”+“0xff,0xff,0xff,0xff”,这是怎么回事?
读取函数是使用的固件库函数
I2C_Result  I2C_Comm_MasterReceive(I2C_TypeDef* I2Cx, uint16_t slaveaddr, uint8_t offset, uint8_t* pBuffer, uint32_t length)
  /* wait 5us max for bus free time limitation for later transaction */
  *(uint32_t *)0xe000e014 = one_us_unit*5;
  *(uint32_t *)0xe000e018 = 0;
  *(uint32_t *)0xe000e010 |= 1;
  while(!I2C_OT);
  *(uint32_t *)0xe000e010 &= 0xfffffffe;
  I2C_OT = FALSE;
  /* wait bus free */
  *(uint32_t *)0xe000e014 = BUS_BUSY_TIMEOUT;
  while((I2C_GetFlagStatus(I2Cx, I2C_FLAG_BUSY))&&(!I2C_OT));
  if (I2C_OT)
    I2C_OT = FALSE;
    return BUS_BUSY;
  /* send start and wait */
  I2C_GenerateSTART(I2Cx, ENABLE);
  *(uint32_t *)0xe000e014 = SEND_START_TIMEOUT;
  while(!(I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_MODE_SELECT) || I2C_OT));
  if (I2C_OT)
    I2C_OT = FALSE;
    return SEND_START_ERR;
  if offset needed:
  (1) slave address with write direction
  (2) offset
  (3) re-start
  if (offset!=0xff)
    /* (1) */
    I2C_Send7bitAddress(I2Cx, (uint8_t)(slaveaddr & 0xFF), I2C_Direction_Transmitter);
    *(uint32_t *)0xe000e014 = SEND_ADDR7_TIMEOUT;
    while(!(I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED) || I2C_OT));
    *(u32 *)0xe000e010 &= 0xfffffffe;
    if (I2C_OT)
      I2C_OT = FALSE;
      I2C_GenerateSTOP(I2Cx, ENABLE);
      while ((I2Cx->CR1 & 0x200) == 0x200);
      if(I2C_GetFlagStatus(I2Cx, I2C_FLAG_AF))
        I2C_ClearFlag(I2Cx, I2C_FLAG_AF);
      return ADDR_MATCH_ERR;
    /* (2) */
    I2C_SendData(I2Cx, offset);
    *(uint32_t *)0xe000e014 = SEND_DATA_TIMEOUT;
    while(!(I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED) || I2C_OT));
    if (I2C_OT)
      I2C_OT = FALSE;
      return DATA_TIMEOUT;
    /* (3) */
    if (I2C_OT)
      I2C_OT = FALSE;
  /* send addr with read direction */
  I2C_Send7bitAddress(I2Cx, (uint8_t)(slaveaddr & 0xFF), I2C_Direction_Receiver);
  different implementation of receive data
  depends on communication length
  (1) length >=3
  (2) length = 2
  (3) length = 1
  if (length >=3)
    while(!(I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED) || I2C_OT));
    if (I2C_OT)
      I2C_OT = FALSE;
    /* receive data */
    /* use another safe procedure to receive data */
    while(length)
      if (length !=3)
        *(uint32_t *)0xe000e014 = RECEIVE_DATA_TIMEOUT;
        while(((I2C_GetLastEvent(I2Cx)&0x04) != 0x04)&& !I2C_OT); // poll on BTF
        if (I2C_OT)
          I2C_OT = FALSE;
        *pBuffer++ = I2C_ReceiveData(I2Cx);
        length--;
      if (length == 3)
        /* D(n-2) in DR; D(n-1) in shift register */
        if (I2C_OT)
          I2C_OT = FALSE;
        /* clear ACK */
        I2C_AcknowledgeConfig(I2Cx, DISABLE);
        __disable_irq();       //NVIC_SETPRIMASK();
        /* read D(n-2) */
        /* program stop */
        /* read D(n-1) */
        __enable_irq();      //NVIC_RESETPRIMASK();
        while(((I2C_GetLastEvent(I2Cx)&0x40) != 0x40)&& !I2C_OT); // poll on RxNE
        if (I2C_OT)
          I2C_OT = FALSE;
        *pBuffer = I2Cx->DR;
        length = 0;
    while (((I2Cx->CR1 & 0x200) == 0x200)&&(!I2C_OT));
    if (I2C_OT)
      I2C_OT = FALSE;
      return SEND_STOP_ERR;
    I2C_AcknowledgeConfig(I2Cx, ENABLE);
  else if (length == 2)
    vu32 tmp;
    /* ACK=1,POS=1 */
    I2Cx->CR1 = 0xc01;
    while((!I2C_GetFlagStatus(I2Cx,I2C_FLAG_ADDR))&& !I2C_OT); //wait for ADDR event
    if (I2C_OT)
        I2C_OT = FALSE;
    /* clear ADDR */
    tmp = I2Cx->SR2;
    /* disable ACK */
    while(((I2C_GetLastEvent(I2Cx)&0x0004) != 0x0004)&& !I2C_OT); // poll on BTF
    if (I2C_OT)
        I2C_OT = FALSE;
    *pBuffer++ = I2Cx->DR;
    length = 0;
    /* POS=0; ACK=PE=1 */
    I2Cx->CR1 = 0x0401;
  else if (length == 1)
    __IO uint32_t tmp;
    if (I2C_OT)
        I2C_OT = FALSE;
    /* disable ACK */
    /* clear ADDR */
    tmp = I2Cx->SR2;
    if (I2C_OT)
        I2C_OT = FALSE;
    length = 0;
  return NO_ERR;
赞 收藏 评论2 发布时间:2014-2-8 10:37
bei_ji 回答时间:2014-2-8 11:16:28
RE:STM32F103CB----I2C读取错误
STM32的I2C总线通过硬件I2C的方式一次数据传输是不是最大只支持8个字节????
废鱼 回答时间:2014-2-10 10:16:54
length你赋值是多少?
