【MCU实战经验】STM32F407使用位绑定区操作IO引脚
scotthsl 发布时间:2014-4-21 10:03
 参考正点原子F103系列的代码,对F407进行了适配,同时代码也兼容F1系列的$ u1 P3 p: R, k* ~( t) C/ V
 0 w. k$ y: c! ~
代码在F4Discovery上验证通过,使用位绑定别名区来操作板子上的四个用户LED
( ]% h0 y* S5 y+ h
9 T1 P* q6 q2 C3 T* X4 f
9 ~) C5 \/ I- e' O// Header        :
5 P  k/ B1 [3 `; |, k  g) l1 d9 _// File Name:bit_banding.h
: V, |: W& Q# i// Author        :***$ Y% ]% f6 k) ~- U# ^6 a" C9 c0 M0 |
// Date                :2014/04/04
) X8 V6 ]/ `: W// Explain        :        1 c- y) ^' }6 k9 q6 J
#ifndef __BIT_BANDING_H__
; N9 a% K( _- D) q# l, i! k5 G5 I#define __BIT_BANDING_H__% ]4 y" z& z# `- Z/ p  A. P- b5 g
 1 ?( a  [( Q6 H. G8 y9 N
 3 |- f- ]2 a. z3 Y- K+ h% h8 h5 Y
//M4内核的GPIO寄存器基地址等3 u. d, w0 y, _8 {: B
#if defined (STM32F40_41xxx) || defined (STM32F427_437xx) || defined (STM32F429_439xx) || defined (STM32F401xx) || defined (STM32F40XX) || defined (STM32F427X); P# u1 o, {3 ^: Z/ y. n- K
//这些宏定义在使用最新库函数时,都会有定义
% _8 n. {  l2 a , s; q. A# A5 |9 e
#include "stm32f4xx.h". o- z/ M6 C* S- x6 R
 4 P5 w0 j% E$ S* F
#define GPIO_REG_ADDR_BASE                0x40020000ul
# E* D" R, Z- `- U4 F" {6 K# Z- r; k* i#define GPIO_REG_ADDR_OFFSET        0x400ul
- Z2 k0 D6 x) T% T% [ - _/ o' P' t2 D
#define GPIO_ODR_OFFSET                        0x14ul8 k8 d' ]% |9 R
#define GPIO_IDR_OFFSET                        0x10ul3 Z2 L# y- r/ x; c, S- t0 g
 ; M3 n9 G6 g$ z( y  \. r
#endif5 K. P, I8 n2 T8 r" ?- {
- F+ d# i8 B2 C* g//M3内核的GPIO寄存器基地址
0 k5 Z0 d* Y; M7 e5 X#if defined (STM32F10X_LD) || defined (STM32F10X_LD_VL) || defined (STM32F10X_MD) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD) || defined (STM32F10X_HD_VL) || defined (STM32F10X_XL) || defined (STM32F10X_CL) - L2 Z$ [+ X4 n8 M. C
1 C& A" E- ]0 [6 M# S$ e0 M#include "stm32f10x.h"
* x0 R- L* _7 U' v! \  q
  p0 T: n8 `) V& h! K( z#define GPIO_REG_ADDR_BASE                0x40010800ul3 Z" o5 z1 ?! t: ]9 O
#define GPIO_REG_ADDR_OFFSET        0x400ul/ q1 o7 g+ q) h7 t
: X& i7 E6 u9 O) i#define GPIO_ODR_OFFSET                        0x0Cul
  s% u# u$ S! f  z3 D#define GPIO_IDR_OFFSET                        0x08ul/ |5 e/ ^: `' d- c: I6 z0 }
 , b0 u  x1 a$ D7 Z/ K9 b8 K% M$ P
#endif
0 v1 @7 |! T: ? * s1 J* A4 P2 V$ K9 a0 y6 A9 Z
; M  S+ m9 g0 W- [7 `  d//别名区的基地址的末地址,在M3和M4中是一样的,位地址的计算公式也是一样的
1 g1 V) z* ^' B7 p' J& V# H ; f5 }( g8 o$ r+ w
//外设别名区的基地址
6 w# O$ e6 ^  g" c# y5 |9 T- `; J#define BIT_BAND_ALIAS_PERIPHERAL_BASE        0x42000000ul
/ [4 }& w7 C7 I4 g ! W) I+ p0 [4 @8 s. r. X! Z
#define BIT_BAND_ALIAS_PERIPHERAL_END        0x43FFFFFFul
& U4 z7 w8 b! z0 [( I! n1 H
. B9 E1 d6 `9 e: s! d" ~% _//SRAM别名区基地址8 s! Q2 W3 [" W) y( d' e( g5 P
#define BIT_BAND_ALIAS_SRAM_BASE                0x22000000ul
; j( S5 l( x1 z$ r' C+ q. T# J! D. X5 |//
3 f7 `/ K2 Q5 m7 K6 U, N' [" b: @( d#define BIT_BAND_ALIAS_SRAM_END                        0x23FFFFFFul
9 ]+ I1 _# ?0 K9 F) k5 j
3 {/ C, z3 ]% X& U- P* O2 N( l5 z
1 a. ?8 e& W- x/ y//在bitband区中 位地址的计算公式
* u/ u2 M, @% y9 h& n' k8 r" e#define BIT_WORD_ADDR(ByteAddr, BitNumber)        ((ByteAddr&0xF0000000) + 0x2000000 + (ByteAddr&0x000FFFFF)*32 + (BitNumber&0x0000000F)*4)2 D- ?" ^- I- ~. g* [
; A; @; s3 f+ _# O 5 y6 t/ a$ v% V( V, H: }9 N1 q- k
//将地址转换成指针,这样才能读写地址中的值; [4 Q0 n& F2 M6 `
#define CONVERT_TO_PTR(BitWordAddr)                ( *( (volatile unsigned long *)BitWordAddr ) )
$ `. l3 B/ a7 i  R' S
4 l: i0 K* }' U5 g5 m& N  _6 C
5 d$ M! q7 F5 x( ?, b, Y9 z% b//BitNumber
STM32F40xTemplate.rar
686.02 KB, 下载次数: 18
赞 收藏 评论0 发布时间:2014-4-21 10:03
