库函数与寄存器操作
飞儿 提问时间:2014-12-10 14:08 /
#define SDA_read      GPIOE->IDR  & GPIO_Pin_3 //GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_3)
我用库函数的GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_3)这个来读IO口,做了几天发现 居然有的时候会读不到。但是只要改成GPIOE->IDR  & GPIO_Pin_3
它就能正常读到了 。
调试进去一看
uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
  uint8_t bitstatus = 0x00;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
  assert_param(IS_GET_GPIO_PIN(GPIO_Pin));
  if ((GPIOx->IDR & GPIO_Pin) != (uint32_t)Bit_RESET)
    bitstatus = (uint8_t)Bit_SET;
  else
    bitstatus = (uint8_t)Bit_RESET;
  return bitstatus;
就没差别 ,可是死活读不到 只要一换成 GPIOE->IDR  & GPIO_Pin_3就成功读取了
赞 收藏 评论28 发布时间:2014-12-10 14:08
28个回答
飞儿 回答时间:2014-12-15 08:24:08
奔跑小蜗牛 发表于 2014-12-14 12:16
官方库的bug,很明显 GPIOx->IDR & GPIO_Pin,在GPIO_Pin = 0 的时候,这句话读出来的值永远都是0.   (xxxxx  ...
#define GPIO_Pin_0                 ((uint16_t)0x0001)  /* Pin 0 selected */
#define GPIO_Pin_1                 ((uint16_t)0x0002)  /* Pin 1 selected */
#define GPIO_Pin_2                 ((uint16_t)0x0004)  /* Pin 2 selected */
#define GPIO_Pin_3                 ((uint16_t)0x0008)  /* Pin 3 selected */
#define GPIO_Pin_4                 ((uint16_t)0x0010)  /* Pin 4 selected */
#define GPIO_Pin_5                 ((uint16_t)0x0020)  /* Pin 5 selected */
#define GPIO_Pin_6                 ((uint16_t)0x0040)  /* Pin 6 selected */
#define GPIO_Pin_7                 ((uint16_t)0x0080)  /* Pin 7 selected */
#define GPIO_Pin_8                 ((uint16_t)0x0100)  /* Pin 8 selected */
#define GPIO_Pin_9                 ((uint16_t)0x0200)  /* Pin 9 selected */
#define GPIO_Pin_10                ((uint16_t)0x0400)  /* Pin 10 selected */
#define GPIO_Pin_11                ((uint16_t)0x0800)  /* Pin 11 selected */
#define GPIO_Pin_12                ((uint16_t)0x1000)  /* Pin 12 selected */
#define GPIO_Pin_13                ((uint16_t)0x2000)  /* Pin 13 selected */
#define GPIO_Pin_14                ((uint16_t)0x4000)  /* Pin 14 selected */
#define GPIO_Pin_15                ((uint16_t)0x8000)  /* Pin 15 selected */
#define GPIO_Pin_All               ((uint16_t)0xFFFF)  /* All pins selected */
哪里来的 0 ?
飞儿 回答时间:2014-12-10 14:12:22
   //I2C  SDA(PE3) SCL(PE2)
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_2 | GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//
    GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; //
    GPIO_InitStructure.GPIO_PuPd =  GPIO_PuPd_UP;  //
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;  /
                GPIO_Init(GPIOE, &GPIO_InitStructure);
奔跑小蜗牛 回答时间:2014-12-14 12:16:17
官方库的bug,很明显 GPIOx->IDR & GPIO_Pin,在GPIO_Pin = 0 的时候,这句话读出来的值永远都是0.   (xxxxx & 0) == 0,这是&计算的基本常识.
改为如下测试:
if (((GPIOx->IDR >> GPIO_Pin) & 0x01) != (uint32_t)Bit_RESET)
飞儿 回答时间:2014-12-10 14:12:38
上了配置
巅峰残狼 回答时间:2014-12-10 16:19:09
确实感觉莫名其妙的。。。帮顶
那片清茶 回答时间:2014-12-10 17:25:02
我记得IIC的引脚不能拿来直接用的,内部上拉是没用的,如果要用,还是外部 上拉
废鱼 回答时间:2014-12-11 10:14:48
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
只设置这2个试试。
飞儿 回答时间:2014-12-11 13:59:37
哥,我要是没接上拉 ,我能读的到应答信号吗?我肯定是接了外部上拉的
飞儿 回答时间:2014-12-11 14:02:39
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;  ...
试过了,可能电池没电的时候,用库函数读不出来吧 用寄存器就可以
废鱼 回答时间:2014-12-11 16:03:00
库也是读取的寄存器,理论是一样的。这样只能是仿真一下,看看他走到函数里面执行到哪儿跳出了。
飞儿 回答时间:2014-12-11 17:27:58
安 发表于 2014-12-11 16:03
库也是读取的寄存器,理论是一样的。这样只能是仿真一下,看看他走到函数里面执行到哪儿跳出了。 ...
我死死用万用表量着它的 3.3V 它硬是读出为0 换了寄存器就读出为1  纠结的我。。。
小贾-370388 回答时间:2014-12-12 15:20:08
时不时你那里配置的出了问题程序没有执行配置就返回了啊?
wenyangzeng 回答时间:2014-12-12 19:57:36
你好像把PE2,PE3设置成输出了:
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; ;
废鱼 回答时间:2014-12-13 09:35:08
wenyangzeng 发表于 2014-12-12 19:57
你好像把PE2,PE3设置成输出了:
楼主说按我改的也不行。我的模拟I2C就这样配置的。前面留贴有。
wamcncn 回答时间:2014-12-14 11:27:27
那就是你的库函数的问题了
12下一页
