STM32F072 按键中断方式控制LED 频率由慢到快
yceast 发布时间:2015-1-7 09:18
/**& ]/ [1 W3 F/ b& ]9 `+ v: W
- M0 k) D: y. T: R9 N2 z; D8 U  * File Name          : main.c+ I2 w  Q9 L. c' b
  * Date               : 30/12/2014 14:33:58, Y1 ~/ y$ f6 t1 X4 n
  * Description        : Main program body
- z# r5 K! }' `' c' Y; w9 E  ******************************************************************************( q8 l- H6 a/ ]& `
( v4 {( v0 z' P$ C" Y  * COPYRIGHT(c) 2014 STMicroelectronics# ^5 N# ~; i7 ]" f- I  }: I
  *# }8 m: e3 V! r- ]3 J) {. s
  * Redistribution and use in source and binary forms, with or without modification,
, g' k- u7 ^4 ^  * are permitted provided that the following conditions are met:
7 W6 b5 A' ]) p. o& {. G5 y  *   1. Redistributions of source code must retain the above copyright notice,
6 P- ^$ y- T) |  `" E# w  *      this list of conditions and the following disclaimer.
7 K4 b0 c9 T' D3 }  *   2. Redistributions in binary form must reproduce the above copyright notice,) {+ @1 f( U5 X
  *      this list of conditions and the following disclaimer in the documentation
) m$ w1 a# P: |2 N. H1 d  *      and/or other materials provided with the distribution.
: U7 [" n2 t4 \. u1 n/ e  *   3. Neither the name of STMicroelectronics nor the names of its contributors0 T  W1 F1 h% |0 P4 \' ~
  *      may be used to endorse or promote products derived from this software
3 C# e) _! z9 N" R* x; _9 ~. T. n! p* }  *      without specific prior written permission.
/ l% D6 T" f, d4 C. V- \  *+ w8 [6 S& _* Z# y/ ?
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"/ |" T  ]0 p/ h5 {( ?8 O) M% `: z: B
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE) a2 I% e$ d' g' x5 v- z
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ D4 T% m8 e1 E# K  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE+ K2 s+ `! j/ T6 Y, g
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL/ ~) T0 Q2 b0 i- }0 C4 N& c
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR4 B2 j8 J( t: C; h! z
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER5 M7 [$ z$ \, v+ e, h
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,+ e$ M( N# ?1 d, I
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE1 I' t) f  F9 w3 R, w
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.+ e$ A1 I3 ?' F6 g! g1 P# F
/ c: v/ _5 s4 Z/ {2 Z# ^, A  ******************************************************************************$ {' c. h3 D% n: z, k
: K' Q  \% E9 ~
2 Q" s& l$ k6 X6 g4 d7 N/* Includes ------------------------------------------------------------------*/& E+ ^9 ]5 y- Y& @1 c9 J9 V3 I% h
#include "stm32f0xx_hal.h"7 V7 ~3 J" @: q" b
6 ]/ \' G! s! @6 Z; x, w
/* USER CODE BEGIN Includes */
$ ^5 p5 V. s- p) V0 T  o1 Z! P2 a' D2 T- S2 n7 I/ U
/* USER CODE END Includes */( @, s5 f# g: ~7 `
% F  P0 T$ G9 b& \" B! F/* Private variables ---------------------------------------------------------*/  {) a, i+ w: m: \. |! @2 a
4 S7 `* B0 D$ n7 N! {+ x/* USER CODE BEGIN PV */1 d# a' A( z& V! {9 l
' K2 N3 X1 f& z1 C- O) O9 V
/* USER CODE END PV */
$ w$ J( M" R5 i9 a( T! V
% V$ z. M+ J" v) ?9 t) d$ z0 v/* Private function prototypes -----------------------------------------------*/3 O0 ~! g" E+ G# K8 z/ L, f
void SystemClock_Config(void);8 S, A& q% S' X9 C. w0 h! z% q4 ]
static void MX_GPIO_Init(void);
% v  ^8 p6 Y- p, q6 nuint16_t nDelay = 500;
! r9 H; g  o& t0 B2 c/* USER CODE BEGIN PFP */3 l! ]! @5 h6 x7 u8 P$ t! M
, u6 c5 g( B6 F
/* USER CODE END PFP */  F9 G  ~6 ^' j( z
3 v& l  P7 `' r$ ?/* USER CODE BEGIN 0 */
# J% V3 U( v! c$ z
- C( P6 e  y1 b$ {; r, Z+ [' ^& A3 H/* USER CODE END 0 */$ h3 H  Q4 k0 k, H/ l4 X
# }( F5 f% I: ]- a
int main(void)
- ?, C* I& T# a1 Z{
" P1 {5 C7 O, R0 ^
. J, G# m8 d' _7 p5 Y7 p3 g" `  /* USER CODE BEGIN 1 */
$ m, O- v/ b* F1 ]) ^
6 T7 r, @! _3 f  /* USER CODE END 1 */; x/ E1 S- C1 q7 {  H! M2 w
  k* T; o. P/ Z6 W# z  /* MCU Configuration----------------------------------------------------------*/- ~/ U0 O5 q4 g! F$ ]5 X2 w! J* \4 x
6 u' ]7 c# l7 H( x, W  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */* ~3 r& K" r4 ~" d/ Y. J
  HAL_Init();
! ^) f1 [# d: l3 l# F: \7 l! X
4 h$ J3 ]; t; h$ v: b  \1 t( {  /* Configure the system clock */
! m( r/ k8 A8 M+ Z8 n  SystemClock_Config();0 h$ S" M  x/ ~
2 @9 f8 l/ m4 K9 b, a3 c+ L  /* Initialize all configured peripherals */( Y9 H: [' Q- |4 V1 }/ N
  MX_GPIO_Init();
- V/ x. t$ [$ ?$ l  ^. v
( d9 j( x" A# \: |; s: M, g  \: V  /* USER CODE BEGIN 2 */
) g6 c5 W* [5 o* K: {. u6 m8 L4 U! C
  /* USER CODE END 2 */* p* U* ~- k  b% t1 J
8 ~9 {9 q. A& c" ?7 c6 S; m" M- ^6 V
  /* USER CODE BEGIN 3 */
, @; c( O) {& Z! R) Y2 t! ?8 u  /* Infinite loop */0 L  \% z0 h" t. `
  while (1)
5 u1 t' r9 j* f( j, _+ V  {% \$ `" r' `' H' H
   HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET);8 L& K  }8 E: O/ c
     HAL_Delay(nDelay );
# Z8 Y. K+ V! l- x     HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_RESET);+ M+ u( H& ]2 E. t  G2 N" R4 P
     HAL_Delay(nDelay );# I: T& W, W; ^3 ?
$ K9 N/ `: q2 E+ k% B  /* USER CODE END 3 */, W- e+ @: R$ i" x
" T! Z' I0 U+ a
" t; p1 q" I# [2 I
8 z. [; U0 M! j* `2 _9 ]" o& |$ G/** System Clock Configuration
- c8 P8 _1 V* E- q3 l! M0 S*/. X4 [9 r+ K4 z" d8 {2 ]; w
void SystemClock_Config(void)/ Y8 O1 J& q# E% C7 Y% G
% m8 e2 x. y2 ]; N2 F( K9 a( J- |: L; }$ ^* k9 Z
  RCC_OscInitTypeDef RCC_OscInitStruct;; B/ _  n5 M3 \- ~: S! i- [
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
1 L" f9 k* @! k# x! y! C
+ i; H3 R! {7 V; }7 o* x  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;; l, P. N- U6 j
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;- q; l2 n, s) u" s/ u( o3 Q/ Q) n
  RCC_OscInitStruct.HSICalibrationValue = 16;; J9 _, O6 p- m- }9 n1 j- E
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
! t: N  m7 u( U2 K1 O* S  HAL_RCC_OscConfig(&RCC_OscInitStruct);6 O' n  E* [# C6 K# G
8 Q% f& P( E0 e# R; V/ ^: h) `$ j
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
( L& |0 N" K8 L0 o4 K* w  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
! N6 V+ D3 ]' a7 |& T! O3 y  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
% i% Q& _. Y/ O+ X  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
# ?- A) }$ A1 L9 K0 V8 z9 U" ?  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);0 c4 f6 r& v( g' ~3 U
! Z, l1 R5 O7 F: l
  __SYSCFG_CLK_ENABLE();0 ^. B9 z2 H5 }7 m
( l. h  F  U$ R, W6 b( Z}! j; c9 W9 S$ N! ?3 v1 R
0 T$ l* e; i) i% V4 S/** Configure pins as $ ~- h4 F2 s1 @  g
        * Analog ' ?1 j! l( A- _
        * Input
/ c. w& N8 j: P0 Q1 ?  W        * Output
% T! d9 {# v5 d& ~1 u0 R4 \0 D        * EVENT_OUT
; ~0 Z: `" B) S. |1 T        * EXTI
, ?2 w5 q  `, y2 `*/
5 ^& z+ {, V0 o9 n0 T5 pvoid MX_GPIO_Init(void)
# J7 M' o/ e, Z% P{# r, a6 c4 q9 H9 e# T
: D6 L8 `$ \  A% M* S! F! ]4 g  GPIO_InitTypeDef GPIO_InitStruct;/ ]; T# F/ s4 J: d8 m  B
* `) @- s, F0 v/ E$ [
  /* GPIO Ports Clock Enable */
+ F/ f( G* q) ?  __GPIOC_CLK_ENABLE();( J, e3 }: c6 d5 W" j& f
  __GPIOA_CLK_ENABLE();5 ?$ c# h. z5 T7 |
. c2 b8 H: [* {: w1 u* K* @
  /*Configure GPIO pin : PC13 */* z8 ^9 F4 P/ n
  GPIO_InitStruct.Pin = GPIO_PIN_13;) R1 q# H' }9 [, ?+ V: C1 h& {7 q/ ~
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
$ f% X: C6 _4 a/ I, |7 A! [  GPIO_InitStruct.Pull = GPIO_NOPULL;) V' P5 O7 i: T: P9 J
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
6 b1 A) c; r( }; \, {# A/ K* E; R; M! V; k! }( M* ]0 N( y- N
  /*Configure GPIO pin : PA5 */. S4 _+ O1 r* `% i( e7 p+ T
  GPIO_InitStruct.Pin = GPIO_PIN_5;
( u  k8 Q" {1 K/ o7 V+ G7 q6 t  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
# l, t/ a. y6 v- u/ x! ^! `  GPIO_InitStruct.Pull = GPIO_NOPULL;8 J# P3 v  y) ?3 Z3 e% u
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;- q4 O& ~+ T5 D, u0 U
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);- W, s- e* l9 M" z+ P( z
" b6 R1 N+ M8 x" t- B* P7 k) w  /* EXTI interrupt init*/% e5 F: k( c6 S& G
  HAL_NVIC_SetPriority(EXTI4_15_IRQn, 0, 0);
# U" z* Y3 m4 g  HAL_NVIC_EnableIRQ(EXTI4_15_IRQn);& Q1 o/ r8 U) S# ?2 @4 k
! ^/ |( h* t, F3 L7 X9 z}5 ]6 }0 h; q( g& B& a; j2 \! S$ X
4 k$ ~* [4 A- g% J2 Y4 e+ C9 ?/* USER CODE BEGIN 4 */
" M3 D, }1 R1 k- q+ Uvoid EXTI4_15_IRQHandler(void)
6 j, J: T2 c1 ?{
( L9 A9 W" r! g  /* USER CODE BEGIN EXTI4_15_IRQn 0 */
0 o5 m2 a4 z, ?3 U" @* T% A# `
) C+ `- B" y8 N/ l: f" _8 p     switch(nDelay)+ |7 O0 n+ e& M0 }4 a
     {3 o& ~6 t$ K2 [) O' d6 {' C
         case 500:nDelay = 400;break;! d5 o9 i3 K6 X" ^6 C
         case 400:nDelay = 300;break; - q2 ~8 z- r+ X4 e
         case 300:nDelay = 200;break;, `0 q. R6 W( y* D! r9 Z
         case 200:nDelay = 100;break;  d& d: L( m; B( Y
         case 100:nDelay = 80;break;  m4 D  G$ T7 l/ C/ [
         case 80:nDelay = 50;break;
5 o6 l! _- c9 P- H* G, ^8 E         case 50:nDelay = 40;break;
1 J" X- O: J0 x: m         case 40:nDelay = 30;break;
3 U$ l; N% [3 I6 Y         case 30:nDelay = 20;break;
0 u5 Z; N" J" l1 C0 a: G         case 20:nDelay = 10;break;
. a% I8 t6 a2 a         case 10:nDelay = 9;break;# y8 y, H, r2 \2 D4 F$ D% |$ [. z
         case 9:nDelay = 8;break;7 I1 w$ q8 v: y( C' H
         case 8:nDelay = 7;break;
! @2 D# m, S, }0 W         case 7:nDelay = 6;break;
+ F9 N: G$ Q1 H& |         case 6:nDelay = 5;break;
6 m4 p6 Y# D7 J6 \7 i         case 5:nDelay = 4;break;/ F, s# l3 {( G6 b
         case 4:nDelay = 3;break;
- b8 D: o+ v- B  }3 g         case 3:nDelay = 2;break;
9 w0 {9 {) l5 w6 o2 R         case 2:nDelay = 1;break;
# R( ^* d% ]  b6 I         default:nDelay = 500;break;
9 s3 b! G/ _6 M6 ?- y) ^2 |4 \     }
: T# @8 n& p' }$ Z) X  /* USER CODE END EXTI4_15_IRQn 0 */6 _. m2 J# {1 `; ?
  HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_13);/ E( \9 N4 E1 `0 w! T' f% T8 ]- x9 L
  /* USER CODE BEGIN EXTI4_15_IRQn 1 */
5 o5 q( J) n$ X3 r- A4 b, O7 j0 S1 |. A  R
  /* USER CODE END EXTI4_15_IRQn 1 */
3 j+ [  R  L: Z5 d5 n}$ c( n4 S  o% x- Q. I" H. Y
( h8 q7 Q# N; o7 R' L1 C7 Z
/* USER CODE END 4 */
- U4 R' W8 P3 D  f' o
1 l# [  D7 w% {7 _3 I3 v#ifdef USE_FULL_ASSERT
: b& S4 b  l8 n5 G& ~
, A( A2 C+ d, _1 D7 s: W/**6 h8 |: G- ^; g; P1 d6 t
   * @brief Reports the name of the source file and the source line number+ y" c/ @8 i0 P* Y5 \2 R
   * where the assert_param error has occurred.5 U0 B0 d1 t& K7 ~! Q! s
   * @param file: pointer to the source file name
: q1 r! w& z& J+ a   * @param line: assert_param error line source number6 t" d6 V0 ~& z4 Q
   * @retval None
% C5 X% z; L8 U; Y; F   */  h# d+ q- E9 }' Y* x( `+ a
void assert_failed(uint8_t* file, uint32_t line)* H0 Z( i* X# m# K! ?# x
5 F! o$ ^$ {( Y5 r( P0 N4 a  t2 V  /* USER CODE BEGIN 6 */4 `' a% L' k5 E- V: u9 a
  /* User can add his own implementation to report the file name and line number,5 P) x+ B( p( ~
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- P3 d6 Z% `0 z" `) t- g  /* USER CODE END 6 */. N  \+ P( U) Y0 ^$ e# i  s: o
$ a" d, d7 l+ \8 ~9 Q% A" Y1 D
: z+ d  ~1 [8 W) s7 k/ a
7 q7 o; J5 ?" M) }4 L) @( {#endif: R- j/ H5 s& ]5 ?
2 p" b2 \0 a* P/ @  W$ @! [9 }/**
4 f! y, L# [& H  * @}
* Z2 t4 f& C+ e: C0 a0 P* {  */
, n8 p! P& k3 r+ E2 a- J9 T' t0 d2 r) b. B8 {
# q% p- _0 d4 R1 s$ b. K- P  * @}
! b, \% O5 Q4 x3 H*/
7 \  ]) [8 N* F  h6 D2 X
% E& O, _3 B4 D' O" X% I% R/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/+ |/ d, a- L. I1 u9 D9 z6 a
: B. a- z) e7 m9 @
4 Y. R. r( J# U' \3 t% W
nvic.rar
5.43 MB, 下载次数: 68
赞 收藏 4 评论58 发布时间:2015-1-7 09:18
58个回答
damiaa 回答时间:2015-1-8 15:53:03
支持楼主的奉献精神!  G6 t/ s  o) V4 o
5 ]& r6 F% q0 Z1 U3 ^1 I% N9 J$ ~4 O; G! [也来改改
- f; i: @* `% S5 X- j8 u+ q  `/ R" o- c+ c5 w) L
uint16_t delayval[19]={500,400,300,200,100,50,40,30,20,10,9,8,7,6,5,4,3,2,1};
) Z8 O- A* \: B  y, }1 N
! G: u4 I8 T4 L3 u4 R! ?  R2 l
' o; {( |) x, ]
2 ?6 p5 ]$ O! z. K3 Z7 q0 ~void EXTI4_15_IRQHandler(void)2 R. M- y/ \  F2 r" N* R
{" w/ m9 q/ S; s- B& i8 k* {
   static uint8_t n=0;. E6 b+ \9 E" M
   if((n<=18)&&(N>0)) 3 N; K3 L( J/ @! I- T8 ?, S
   n--;
$ a' ~+ `% W- I& o   else. z7 _. h5 \8 J. V" I
   n=18;6 p9 o2 K0 p$ Y- f
   nDelay = delayval[n];
) A1 V3 q9 a9 O: o0 r$ u}% c/ R3 ]; A8 Y
yceast 回答时间:2015-1-8 10:31:59
数码小叶 发表于 2015-1-8 10:18, z/ o0 f% J0 r" b& {, b8 C
是自带的那个程序吗?
" R- ~( y" N# ?$ Z  ^- v- ?' w不是的  自己编的  频率比自带的多
yceast 回答时间:2015-1-8 16:39:26
damiaa 发表于 2015-1-8 15:531 q* O- j4 i, U; r# Q/ l( Q
支持楼主的奉献精神!
) ~: N* W: S/ W, u+ p
/ |9 p; }0 _, _! d, y% g也来改改
6 r: E! f  Q5 A( u( F谢谢分享  简洁了不少
大秦正声 回答时间:2015-1-7 09:23:39
谢谢分享
yceast 回答时间:2015-1-7 09:24:37
大秦正声 发表于 2015-1-7 09:23
& J! k2 V8 t" L) s! V& A; A谢谢分享
& k" F! e# \; q3 y- |
谢谢支持
stm32_beginner 回答时间:2015-1-7 09:41:15
板子自带的就按键控制灯闪。
Small利 回答时间:2015-1-7 10:45:12
好东西
yceast 回答时间:2015-1-7 10:56:55
stm32_beginner 发表于 2015-1-7 09:41
+ Y, u& M8 [2 z$ s3 H, b+ ]板子自带的就按键控制灯闪。
$ k1 E/ V6 `1 w! N8 T, W5 q
呵呵 频率比自带的多点
yceast 回答时间:2015-1-7 10:57:10
Small利 发表于 2015-1-7 10:45
" a) M6 s5 ]! L" c9 T9 d好东西
- d/ ^$ W6 F8 K' t谢谢支持
非→你←不娶 回答时间:2015-1-7 11:08:35
哇,这个真给力,得大赞一个,对学习很有用处
拼命三郎 回答时间:2015-1-7 11:23:12
谢谢分享,这就研究下
yceast 回答时间:2015-1-7 11:23:24
谢谢支持哦
yceast 回答时间:2015-1-7 11:27:05
拼命三郎 发表于 2015-1-7 11:23$ z0 X1 |0 h: [5 Q7 F
谢谢分享,这就研究下
/ o! l& F' q* k谢谢支持哦
默默前行 回答时间:2015-1-7 11:33:06
很实用,赞一个
sirius65 回答时间:2015-1-7 17:05:52
谢谢分享 学习了
cxtarm 回答时间:2015-1-7 17:24:13
赞一个。。。
巅峰残狼 回答时间:2015-1-7 17:35:56
谢谢分享
1234下一页
