#include "stm8l15x.h" #include "NRF24l01P.h" /*********************************************************************/ #define IRQ (GPIOB->IDR & GPIO_Pin_2) * x! |+ ]& `( d. @* X) S #define MISO (GPIOB->IDR & GPIO_Pin_7) /*********************************************************************/ #define CE_0 GPIO_ResetBits(GPIOB, GPIO_Pin_3) #define CE_1 GPIO_SetBits(GPIOB, GPIO_Pin_3) #define CSN_0 GPIO_ResetBits(GPIOB, GPIO_Pin_4) : M b" n T5 J/ k) ^) w+ o #define CSN_1 GPIO_SetBits(GPIOB, GPIO_Pin_4) #define SCK_0 GPIO_ResetBits(GPIOB, GPIO_Pin_5) " W% @ A* P+ \: E7 c8 \0 h #define SCK_1 GPIO_SetBits(GPIOB, GPIO_Pin_5)& O0 C1 Q6 G9 K0 H4 s #define MOSI_0 GPIO_ResetBits(GPIOB, GPIO_Pin_6) 6 V6 K0 l. b" d/ R #define MOSI_1 GPIO_SetBits(GPIOB, GPIO_Pin_6); |1 @9 v& T/ n9 m: c$ I$ G /*********************************************************************/% J- V1 p2 K3 I4 T& ~9 u //unsigned char tx_buf[PAYLOAD_WIDTH]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,7 L5 E$ j, u$ H // 0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,2 O" W8 Q0 _- d. j* f // 0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24, // 0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32};/ H& ]$ x2 d9 a/ L" W2 G unsigned char TX_ADDRESS[ADDRESS_WIDTH] = {0xE7,0xE7,0xE7,0xE7,0x00}; ; j+ p# |1 Q, A1 I unsigned char RX_ADDRESS0[ADDRESS_WIDTH] = {0xE7,0xE7,0xE7,0xE7,0x00}; unsigned char RX_ADDRESS1[ADDRESS_WIDTH] = {0xE7,0xE7,0xE7,0xE7,0x01};2 j2 _3 k3 J8 Z5 F unsigned char RX_ADDRESS2[1]= {0x02}; unsigned char RX_ADDRESS3[1]= {0x03}; ( D) l) B7 N2 O unsigned char RX_ADDRESS4[1]= {0x04}; unsigned char RX_ADDRESS5[1]= {0x05}; /* nRF24L01 Instruction Definitions */* ?6 k5 b% u- P: S }% q #define W_REGISTER 0x20 /**< Register write command */8 l+ }. w& R# ?& z8 k1 c #define R_RX_PAYLOAD 0x61 /**< Read RX payload command */ #define W_TX_PAYLOAD 0xA0 /**< Write TX payload command */ #define FLUSH_TX 0xE1 /**< Flush TX register command */$ c3 t0 d: ~% a+ S( j #define FLUSH_RX 0xE2 /**< Flush RX register command */ #define REUSE_TX_PL 0xE3 /**< Reuse TX payload command */ #define ACTIVATE 0x50 /**< Activate features */' U/ r; |6 e1 J* P8 { #define R_RX_PL_WID 0x60 /**< Read RX payload command */- t* B; s% Y4 W+ t, S B #define W_ACK_PAYLOAD 0xA8 /**< Write ACK payload command */ #define W_TX_PAYLOAD_NOACK 0xB0 /**< Write ACK payload command */: R% `) Q8 n9 ?" j; x #define NOP 0xFF /**< No Operation command, used for reading status register */ ' D+ I) x" ~% S1 t /* nRF24L01 Register Definitions */ #define CONFIG 0x00 /**< nRF24L01 config register */; ~) ?- X; x' W" Y! k% T6 w #define EN_AA 0x01 /**< nRF24L01 enable Auto-Acknowledge register */ #define EN_RXADDR 0x02 /**< nRF24L01 enable RX addresses register */8 {* M) \( d$ r: E #define SETUP_AW 0x03 /**< nRF24L01 setup of address width register */ #define SETUP_RETR 0x04 /**< nRF24L01 setup of automatic retransmission register */ #define RF_CH 0x05 /**< nRF24L01 RF channel register */( A1 N) T# [( `! Y7 ^ #define RF_SETUP 0x06 /**< nRF24L01 RF setup register */1 D9 o7 l- H# K' p. r #define STATUS 0x07 /**< nRF24L01 status register */% t' E: i" R* E% C0 z1 C" B #define OBSERVE_TX 0x08 /**< nRF24L01 transmit observe register */+ S$ w. e p& ^7 b. l* u #define CD 0x09 /**< nRF24L01 carrier detect register */1 g6 n+ [( g7 O9 `/ g #define RX_ADDR_P0 0x0A /**< nRF24L01 receive address data pipe0 */ #define RX_ADDR_P1 0x0B /**< nRF24L01 receive address data pipe1 */1 I) y7 n9 S, ^8 p #define RX_ADDR_P2 0x0C /**< nRF24L01 receive address data pipe2 */# z8 D A- R* R+ I #define RX_ADDR_P3 0x0D /**< nRF24L01 receive address data pipe3 */+ |* ~5 h4 q& Y+ H #define RX_ADDR_P4 0x0E /**< nRF24L01 receive address data pipe4 */% S! ]6 M& q2 s9 {: Z) B #define RX_ADDR_P5 0x0F /**< nRF24L01 receive address data pipe5 */ #define TX_ADDR 0x10 /**< nRF24L01 transmit address */ #define RX_PW_P0 0x11 /**< nRF24L01 \# of bytes in rx payload for pipe0 */ #define RX_PW_P1 0x12 /**< nRF24L01 \# of bytes in rx payload for pipe1 */( |2 n* G. ]" F* T #define RX_PW_P2 0x13 /**< nRF24L01 \# of bytes in rx payload for pipe2 */# i. f3 l0 ~' h6 x #define RX_PW_P3 0x14 /**< nRF24L01 \# of bytes in rx payload for pipe3 */ #define RX_PW_P4 0x15 /**< nRF24L01 \# of bytes in rx payload for pipe4 */2 X0 c* l+ z, K' v #define RX_PW_P5 0x16 /**< nRF24L01 \# of bytes in rx payload for pipe5 */2 k4 }4 j. T0 s* ] #define FIFO_STATUS 0x17 /**< nRF24L01 FIFO status register */ #define DYNPD 0x1C /**< nRF24L01 Dynamic payload setup */ #define FEATURE 0x1D /**< nRF24L01 Exclusive feature setup */4 b( r& z5 t' N# u9 ] /** @name STATUS register bit definitions */ #define RX_DR 0x40 /**< STATUS register bit 6 */ #define TX_DS 0x20 /**< STATUS register bit 5 */) O; T2 P; [- M6 w1 X$ _ #define MAX_RT 0x10 /**< STATUS register bit 4 */9 t ?; C+ s/ _% q7 ^8 x0 u, _ #define TX_FULL 0x01 /**< STATUS register bit 0 */, z/ H l" ^: Z9 W3 g: w$ b# j; S' t /** @name FIFO_STATUS register bit definitions */ #define TX_REUSE 0x40 /**< FIFO_STATUS register bit 6 */9 t% f4 P6 m' J3 e+ p* X& r( j* E #define TX_FIFO_FULL 0x20 /**< FIFO_STATUS register bit 5 */3 D# t- S7 C, ^9 Z" v" a2 B3 O; T/ v #define TX_EMPTY 0x10 /**< FIFO_STATUS register bit 4 */ #define RX_FULL 0x02 /**< FIFO_STATUS register bit 1 */ #define RX_EMPTY 0x01 /**< FIFO_STATUS register bit 0 */ X+ T) K+ q$ Y, |+ }. g 1 o) t+ X% _! c+ k% `' M" `) K- F unsigned char SPI_SendByte(unsigned char byte) { unsigned char i;9 f1 K9 [0 A6 l Y for(i = 0; i < 8; i++) { if (byte & 0x80) , C o0 L9 m6 e( _ MOSI_1; else MOSI_0;6 ?) }5 V9 H i% r byte <<= 1; SCK_1; if (MISO) byte++; 7 _! }) K7 A+ h SCK_0; }! y( O- B& W3 l' e/ p) C return byte; }9 D2 }) Z5 Q; S' j; D7 Y! p5 r , Q3 M% t) ~: i0 i unsigned char NRF24L01_WriteReg(unsigned char reg, unsigned char value), P; o! Z; x P% J" b { unsigned char status; $ S: F3 [2 O3 _" S3 V. l I' i CSN_0; ) U- @* P2 h: ~. b9 P. p status = SPI_SendByte(reg); SPI_SendByte(value); CSN_1; - k9 s8 D9 x0 R+ Q9 _ return(status); " I5 P3 s4 w8 U$ U# }5 w! n! @ }+ P2 I2 R3 }6 m) P7 C' \% [+ d 5 p! z, ?3 }) X( [" w% {. z& [0 ~ unsigned char NRF24L01_ReadReg(unsigned char reg) { unsigned char value; 7 ~/ \: c! ?* k) k# ], B' F! W CSN_0; 0 B. b R( ]* `# G SPI_SendByte(reg); : _* H8 L. H' W& b, s0 x( B, c value = SPI_SendByte(0x00); CSN_1; return(value); % v3 K2 j& C& M' C n } 2 g3 r7 D+ P _9 V; ^ / G% Y w) R! t) Y unsigned char NRF24L01_ReadBuf(unsigned char reg, unsigned char buf[], unsigned char len)1 Z( \: N3 v2 I { unsigned char i, status; 4 D. S, J2 m2 l5 X2 c7 }, {& X CSN_0; status = SPI_SendByte(reg); 5 b2 {1 e2 f! {# I for(i = 0; i < len; i++) buf[i] = SPI_SendByte(0x00);) H+ _3 ?" a8 _ CSN_1; ( J* \2 z2 f. F% Y8 x return(status); 7 S6 p6 Z- \" Y2 f/ g }, c' ^+ Q1 v* F: `) d- ] - r& H5 k5 j3 f, H% G" m unsigned char NRF24L01_WriteBuf(unsigned char reg, unsigned char buf[], unsigned char len)/ d8 A5 @$ \' K" D& r2 o) w4 h P { unsigned char i, status; ! T9 Y2 C" d8 V' v( k! l CSN_0; : d! _' s3 K( b4 \8 F. V: k status = SPI_SendByte(reg); for(i = 0; i < len; i++) SPI_SendByte(buf[i]); ; M( P, L" T# _$ m5 N2 Z& d CSN_1; return(status); } void NRF24L01_Initial(void) { GPIO_Init(GPIOB, GPIO_Pin_2 | GPIO_Pin_7, GPIO_Mode_In_FL_No_IT); GPIO_Init(GPIOB, GPIO_Pin_3 | GPIO_Pin_4 |GPIO_Pin_5 | GPIO_Pin_6, GPIO_Mode_Out_PP_Low_Fast);1 N, q& j, |8 o! p& W8 Y8 [ GPIO_Init(GPIOB, GPIO_Pin_2, GPIO_Mode_In_FL_IT); 6 a m- C4 \: K9 _4 c( l: ?( N7 s- j EXTI_SetPinSensitivity(EXTI_Pin_2, EXTI_Trigger_Falling);//NRF24L01P* `0 `7 T3 X8 P0 v3 F/ ~8 m CE_0; ) H. j) J0 r9 Y5 f1 A0 m CSN_1; SCK_0; * N* Z' ]3 Y9 Z0 t. w; l NRF24L01_WriteReg(W_REGISTER + EN_AA, 0x01);! S0 `& a% P+ r' E9 a NRF24L01_WriteReg(W_REGISTER + EN_RXADDR, 0x01);3 d' \. V5 y3 L! ^2 r# X" y. z NRF24L01_WriteReg(W_REGISTER + SETUP_AW, 0x03);* O/ ? `$ r$ B+ g" c NRF24L01_WriteReg(W_REGISTER + SETUP_RETR, 0x1A); NRF24L01_WriteReg(W_REGISTER + RF_CH, 0); NRF24L01_WriteReg(W_REGISTER + RF_SETUP, 0x0C); //0x08:-18dBm,2Mbps //0x00:-18dBm,1Mbps4 @% P: X# n6 F $ H' ?- D* K9 j4 ]: F% X5 y NRF24L01_WriteBuf(W_REGISTER + RX_ADDR_P0, RX_ADDRESS0, ADDRESS_WIDTH); ( n) R! o0 C( A) H- L; L NRF24L01_WriteBuf(W_REGISTER + RX_ADDR_P1, RX_ADDRESS1, ADDRESS_WIDTH); 2 a) Y. O/ m3 H9 R. { NRF24L01_WriteBuf(W_REGISTER + RX_ADDR_P2, RX_ADDRESS2, 1); NRF24L01_WriteBuf(W_REGISTER + RX_ADDR_P3, RX_ADDRESS3, 1);# z5 R6 i$ d- N% X# ~4 F NRF24L01_WriteBuf(W_REGISTER + RX_ADDR_P4, RX_ADDRESS4, 1);4 c8 N$ ?0 e9 O. R1 d NRF24L01_WriteBuf(W_REGISTER + RX_ADDR_P5, RX_ADDRESS5, 1); NRF24L01_WriteBuf(W_REGISTER + TX_ADDR, TX_ADDRESS, ADDRESS_WIDTH); NRF24L01_WriteReg(W_REGISTER + RX_PW_P0, PAYLOAD_WIDTH); 3 f! h3 `5 B5 r: m7 O/ C" g NRF24L01_WriteReg(W_REGISTER + RX_PW_P1, PAYLOAD_WIDTH); NRF24L01_WriteReg(W_REGISTER + RX_PW_P2, PAYLOAD_WIDTH); NRF24L01_WriteReg(W_REGISTER + RX_PW_P3, PAYLOAD_WIDTH); NRF24L01_WriteReg(W_REGISTER + RX_PW_P4, PAYLOAD_WIDTH); ) T4 y; G0 Z. j+ g6 E' B/ x NRF24L01_WriteReg(W_REGISTER + RX_PW_P5, PAYLOAD_WIDTH); , v0 x) V- o; ?3 d NRF24L01_WriteReg(FLUSH_RX, 0x00);2 ~# o% Q U: z% L3 p4 s NRF24L01_WriteReg(FLUSH_TX, 0x00); / D1 l: |5 D! o7 g4 L# h) O NRF24L01_WriteReg(W_REGISTER + STATUS, 0x70); NRF24L01_WriteReg(W_REGISTER + CONFIG, 0x00); " T" y/ b4 P! [/ H }# }8 W } unsigned char NRF24L01_RxPacket(unsigned char rx_buf[]) { unsigned char status; NRF24L01_WriteReg(W_REGISTER + CONFIG, 0x0F); delay_ms(2); CE_1; //while(IRQ);2 s) C( g# a7 R# Q' Y0 J Z delay_ms(10); CE_0; NRF24L01_WriteReg(W_REGISTER + CONFIG, 0x00);% S- u m- `, H$ k' G& ?/ T status = NRF24L01_ReadReg(STATUS);! P: Q* i# G- G+ L7 \; o9 R# L, I NRF24L01_WriteReg(W_REGISTER + STATUS, status);* i5 ^5 K. l1 I' o* G , x8 r9 Z9 z: }$ u8 H4 S" A% r if(status & RX_DR) {* _$ s: o* A$ `# q, D) P NRF24L01_ReadBuf(R_RX_PAYLOAD, rx_buf, PAYLOAD_WIDTH); NRF24L01_WriteReg(FLUSH_RX, 0x00); , m0 g' M$ C+ f return 1; }' Y$ x5 M6 z8 G! E1 a# |+ _# w! u else i: w& u5 |, N& B- M {/ b+ M4 ]3 \/ x: V3 Z! ] NRF24L01_WriteReg(FLUSH_RX, 0x00); K2 R3 L6 i+ x) T( f- K return 0;5 S1 D& E3 g" v: b! J: { }: w5 N0 j8 a/ k/ j2 `) N- d0 G } unsigned char NRF24L01_TxPacket(unsigned char tx_buf[]) { unsigned char status; 2 F& `/ w. {0 V7 q$ C NRF24L01_WriteBuf(W_TX_PAYLOAD, tx_buf, PAYLOAD_WIDTH);0 V3 `% N- C0 ^' n0 ^7 y NRF24L01_WriteReg(W_REGISTER + CONFIG, 0x0E); delay_ms(2); b9 C/ M2 F7 `4 g, Y! r CE_1; //while(IRQ);) s% R2 m- j9 ~, s delay_ms(10); CE_0;1 d' [2 ^' E* S; |/ _ ; K% n1 s8 v% I9 U NRF24L01_WriteReg(W_REGISTER + CONFIG, 0x00); status = NRF24L01_ReadReg(STATUS); NRF24L01_WriteReg(W_REGISTER + STATUS, status); + O0 @0 }3 b% K# {3 ^# v6 M. ? if(status & MAX_RT)* C. w# G3 T; K+ ~' S {2 Q7 p! W0 z2 `$ @( P NRF24L01_WriteReg(FLUSH_TX, 0x00);" I8 d+ O- H" `: C) ~4 f return 0; }2 T9 c4 f+ T9 a& ]. l6 ? if(status & TX_DS) {4 y: W6 @3 i0 S% S NRF24L01_WriteReg(FLUSH_TX, 0x00);; C0 E; }" V. U# I return 1; } return 2;/ u3 j- t' [( ~- u0 l+ x1 _ }3 S. M2 f& ^, l* o4 Y ( J# f" O# v6 T) {2 Y I* f% f4 [0 ~. |0 { |
NRF24L01P.rar
下载2.2 KB, 下载次数: 522
STM8自学笔记(推荐STM8很好的入门电子书)
无刷直流电机控制应用+基于STM8S系列单片机---电子书
【精华资料】STM8Sxx固件库FOR IAR
基于STM8的DALI (数字可寻址调光协议)
分享STM8 风驰光盘的资料,是完整的(包括原理图+例程+PDF注释)
《无刷直流电机控制应用 基于STM8S系列单片机》
STM8S库函数中文参考 小软件
【资料分享】STM8L的智能手持血糖监测设备的源码
基于STM8S207工程模板
【培训资料】STM8系列PPT培训资料
可以的
谢谢支持
