基于SYSTICK中断的键盘状态机扫描
wamcncn 发布时间:2015-1-27 20:38
人机交互的界面,其中之一就是键盘.键盘扫描的方法很多,状态机是其中一种,调试了好几天,终于调好了
5 u, ~8 d2 i6 r( F& Q# `* {void Key_Scan(void); r, ]: N: `1 `( D
{      $ N' N. R0 h' u) n+ [9 Z. o
    static unsigned int KeyStateTemp = 0;   //初始化键盘状态变量
  H" B+ ]) {, t% y    static unsigned int KeyTime=0;             //初始化按键时间变量
8 N' I7 M4 z7 ~. v/ Y) L9 s/ m
' t& j( }! B1 D, K: }    - p# Z4 f1 n/ \9 ^3 |3 K
switch(KeyStateTemp)
0 a  Z, }8 x$ w, n0 x {
8 t. O' }( o% f+ q; j, p  case StateInit:      7 f; Z6 I( G8 k4 Q
   if(!KEY1_USER)                                              //判断按键是否按下( @$ S7 f7 V9 D" U( l( Y
    KeyStateTemp = StateAffirm;
/ O: l* d) a; E   break;" s+ s4 D0 [# m* B8 O& a6 j
  case StateAffirm:     4 K* q" p7 Q3 H! x
   if(!KEY1_USER)
$ p0 N& _* Q6 m/ B) `   {
5 F3 ^& K1 o; X    KeyTime = 0;4 A! X; Y. x* c  U) t
    KeyStateTemp = StateSingle;
; n3 ^/ [( B! Q% Q4 x+ S) X   }+ q' F  b- p7 Z. F) k' j3 G6 ~, `
   else KeyStateTemp = StateInit;  # S- ^1 O# W: k' e
   break;
7 M/ A1 H6 A' z/ }3 R3 c9 H$ S  case StateSingle:     4 z7 n9 ?2 I4 v% z
   if(KEY1_USER )
" F* l9 o" Y% A2 `: \# T; w   { 9 K+ H' Q0 S. Z
9 T: e7 d3 U* s1 U& `0 s    num++; 8 e) s  Z5 W- Y+ S- ]: ^
                sprintf(buffer,"%-16d",num);                   //把按键次数转换成字符/ m6 T3 Z9 F- X2 J/ @" Q9 b8 H
          display_x(0x98,buffer);                                  //把转换的按键次数显示到液晶上
" S9 `7 u3 ], ?( p$ N    if(125== num)  num = 0;
2 S( j2 ^) a, _8 X7 ?9 f   }
" |; ^0 ^0 M! e: P   else if(++KeyTime> 50)  //如果按键时间大于50*20MS5 ?5 D% |4 J9 w- r$ ]4 ]
. t. ?. r* k" C8 K3 k, ]! G               1 b3 h# z+ h. X. |6 h
                    KeyStateTemp = StateRepeat;
" O9 }" R8 Q% R1 s                    KeyTime = 0; 4 a: J% k. z1 @' k5 {" ~
3 S: w) ?, y9 v$ E. {            }% {2 H) P$ n1 q9 y7 Y% ^
   break;
" z* ?3 B; Z7 y* t& m  case StateRepeat:     0 y9 Y6 ?8 X  h# M4 |; ]
   if(KEY1_USER ) 5 E( A8 |' U2 b
    KeyStateTemp = StateInit; : i1 c9 D( Y$ e* [- w% h
   else if(++KeyTime> 10)   //如果按键时间大于10*20: v, C8 I. Y  ~2 M0 u
    {        K' z6 ]$ g! o- D6 s( V- P
                    KeyTime = 0;
9 D+ t% o. x- h# `7 h4 I                   num++; * P5 [" n7 l$ n- b% H
                    sprintf(buffer,"%-16d",num);4 d! y; Y5 ~. r+ V1 N
* }, A3 {7 {  G6 m" N     if(125== num)  num = 0;: C4 ]3 @( D6 a
    }$ y' F- C+ c$ t0 e- |: g2 J5 Z/ s
                break;
8 f- r2 b6 g3 ]2 p" u) c
8 ^, X4 L- e: d" F' k1 \, D        default: KeyStateTemp = KeyStateTemp = StateInit; break;
% Y; H- V/ ~3 ^9 G4 O9 k( D }
0 h* {/ ~8 c& B; a- a
( B; }5 `/ O& V+ O8 }}+ k3 T  E3 r- `' R
, z1 _& h% J$ p; x- }# G
中断函数的设置' U- e* F' W0 Z
void SysTick_Handler(void)
2 ]0 V  ~* s5 r{
  k3 ~# y& X$ ^6 r5 \/ L4 W
0 y9 e! z* Z- o# w# e       systick_num++;
/ d, }2 n% m- c+ z# `& j2 Y    if(systick_num==20)
" w: S' c% t+ O" O- a0 v   {  5 o: y1 J# I9 T" ^( J$ P
        Key_Scan();: e. k( `( E' Y) Z, A
      systick_num =0;           # u+ \  ^' }% P! @
2 Y2 H7 Q  q  w  p! [( Z}
2 N+ R8 a) p3 k* l0 X( |1 p. h" r& x( W  G9 K$ E
+ `( C: D1 U" I, m2 e8 g# B
赞 收藏 1 评论17 发布时间:2015-1-27 20:38
17个回答
wamcncn 回答时间:2015-1-31 09:21:34
$ D7 ]* T1 m3 R7 x1 o* |
holts1 发表于 2015-1-31 09:12
2 X$ Q5 `( T; f抖动的时候仍会进中断,状态也跟着抖,如何消抖。
/ A. r. ~7 U" D1 o, e9 y$ @4 Q3 W/ o8 J% ]
抖动有20MS长吗,第1次中断后,假如是抖动的话,第2次进入中断,如果按键状态保持,就认为是按键了,否则认为是抖动
wamcncn 回答时间:2015-1-31 09:35:17
holts1 发表于 2015-1-31 09:262 j9 t8 Y$ d* S/ ]0 F! H5 w
在20MS内会多次触发你的键盘中断,每次进去你的状态机的值都在变,你如何判断哪次是有效的 ? ...
  @  B$ b9 V* b是20MS进入中断检测一下键盘,不是触发键盘中断
holts1 回答时间:2015-1-29 08:10:11
wambob 发表于 2015-1-28 08:53$ C  Y5 z, K* v3 L' n9 T; O8 Z( Z
进一次中断就检测一下有没有按键啊,本来想用定时器中断的,可还不熟悉
# D8 N/ b" L6 L! y你的键盘处理也在中断中,这个有点不合理
holts1 回答时间:2015-1-28 08:10:33
为什么放中断里 ?
wamcncn 回答时间:2015-1-28 08:53:02
holts1 发表于 2015-1-28 08:10+ Z1 \, ?2 t" \
为什么放中断里 ?
- i! m# L, z$ c+ [8 y+ r6 E/ n
feel-376797 回答时间:2015-1-28 08:55:49
这办法好,省定时器
拼命三郎 回答时间:2015-1-28 09:26:21
谢谢分享
党国特派员 回答时间:2015-1-28 09:36:11
记得Atmel有硬件消抖。
wyxy163@126.com 回答时间:2015-1-28 15:08:58
holts1 回答时间:2015-1-29 08:11:15
而且你用键盘中断,消抖如何处理 ?
wamcncn 回答时间:2015-1-29 12:11:41
holts1 发表于 2015-1-29 08:11
4 M2 B" u7 p' h4 ]7 K* p而且你用键盘中断,消抖如何处理 ?
- z8 w$ R. S6 o3 d关于消抖,建议你看看状态机按键原理就明白了
holts1 回答时间:2015-1-30 08:17:28
wambob 发表于 2015-1-29 12:11
- C! }7 p7 O! n+ T  T, ]关于消抖,建议你看看状态机按键原理就明白了
/ c. K, M9 B' s1 }! E6 E
你在键盘中断中处理按键,状态机原理有冲突啊?
拼命三郎 回答时间:2015-1-30 08:26:16
wamcncn 回答时间:2015-1-30 13:11:06
holts1 发表于 2015-1-30 08:17% }0 E2 [: z$ i- V) [7 {- C; Z
* N: r( H# ~; |5 u% v( W. a( ?
请问冲突在哪
holts1 回答时间:2015-1-31 09:12:30
wambob 发表于 2015-1-30 13:112 _; ]# _4 H* w3 ^  K
请问冲突在哪
( j( K, A5 h5 G2 V1 a. {- u
12下一页
