特别注意NSS引脚的配置,见代码。
2 [# M) Q3 h$ U' r+ s1.GPIO的配置与103系列的不同;
5 Q/ k& b& r( H6 p* Y# _2.SPI功能更强大,比如支持CRC校验,配置与103系列不同;0 s' w+ d) b- W) N
其他特性请参考datasheet.
0 g7 L3 V# b b- /*******************************************************************************
# n$ k `' F9 a8 f" u/ z; ] - //STM32F207VGT6 FOR ENC28J60
9 |" e! L7 ^/ z2 \# ^ h - //SPI2初始化/IO初始化等
9 p. u9 u" I2 @* L3 G - //SPI configuration
9 s" m. q& w" \) s - @@ JUST FOR STM32F2XX2 Y/ K' }2 U* I7 g
- *******************************************************************************/* V4 @1 n) R7 n6 _
- void ENC28J60_SPI2_Init(void)
: j9 D, n# I: l, B% E, M - {, V1 r$ C4 G/ s+ s
- SPI_InitTypeDef SPI_InitStructure;7 z# z7 h& k& A
- GPIO_InitTypeDef GPIO_InitStructure;
A# L2 I% N; G7 F7 r. ?
" V8 {, Y+ F/ \* ~, Z- /*!< Enable the SPI2 clock */
4 F/ k" }- o6 E! H( h - RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
' R5 H3 Q e( S: n j, R s -
* s8 l3 ^! A$ y& T4 w3 V9 ?0 o! k3 u - /*!< Enable GPIO clocks */
7 a$ g: h7 H. n) Q6 E, k6 e7 X8 B - RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);1 U5 e0 i. v. ~- }; j
- /*!< SPI2 pins configuration */4 K# u3 d0 D* J6 }: C
- ) P% E' e3 p+ @4 N- g( A6 f
- /* Configure SPI2 pins as alternate function (No need to
2 G2 M3 Q3 i% \% w# d( ~ - configure PB12 since NSS will be managed by software) */
. f' \. A! K1 D4 | - GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_SPI2); //nss 6 t: N) T2 D/ C2 I$ s
- GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_SPI2); //sck
0 W# @. x) ]! R! M7 { - GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_SPI2); //miso2 X' E7 v3 `1 G4 q& P; N: b
- GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_SPI2); //mosi
& u( g$ g/ m- b1 Z' Z -
0 |5 _ j( H, B" |: m - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
! } L2 L3 G r$ h - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // also 100Mhz
0 a, V! y- D3 D1 P" @& o. O6 | r - GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
3 B) E. `2 d5 x3 @6 @) w+ W - GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; // GPIO_PuPd_DOWN
/ u6 `, S# {) h. N' R - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;( K5 m% s9 ^. [" |. l
- GPIO_Init(GPIOB, &GPIO_InitStructure);// PB13/14/15-SCK,MISO,MOSI
% `% x' ~, b& ] -
# p; p0 K# x* L: |+ D - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
: z7 t+ |$ k7 r7 d" i - GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;5 b- ]9 ]! T9 t6 t+ O
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;$ _2 a8 A, ]5 ~: n
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz; + Y1 L7 b- W. H: i/ k
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_12; // RESRT and CS for enc28j608 h& M2 s) ]1 }, k$ N8 o8 r
- GPIO_Init(GPIOB, &GPIO_InitStructure);9 N: {+ _3 T& e
- 0 B. e3 E. `. o7 `& j0 ?
- /*!< Configure enc28j60 interrupt pin in PullUp mode ********************/
- Y0 @, g _6 v6 N4 p - GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;6 c3 r' U5 V2 w' ?
# S( v7 Y0 e" F" J2 [ - GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
0 c. g# H6 s2 S- g, g - GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;( s8 s4 F5 J9 \% Z6 x
- /*!< SPI2 pin configuration */
1 @ v3 i! x* Y/ B7 I1 @' Z - GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //INT
: B+ n8 c' h1 T$ g7 u - GPIO_Init(GPIOB, &GPIO_InitStructure);
7 E! Z' n+ ~, @# ~# A - 2 j9 U' Q. ~6 X" t U. U
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//SPI设置为双线双向全双工
, E/ J, P( I9 m& l4 A: U5 q - SPI_InitStructure.SPI_Mode = SPI_Mode_Master;//设置为主SPI3 ]- R' i, d5 A. g, {+ d8 X
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;//设置SPI的数据大小:SPI发送接收8位帧结构
) x) x1 M% D4 G - SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;//选择了串行时钟的稳态:时钟悬空高' r# p& t' W" |! r3 t
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;//数据捕获于第二个时钟沿! J( P' C4 X3 h+ m$ p
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//(SPI_NSS_Soft)此时NSS引脚可以配置成普通GPIO去控制从设备
# w. X: g; _2 M2 A - SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;//Fclk/2" N2 j9 I; ^- T: c) l8 i, X8 r1 R
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; /* Initialize the SPI_FirstBit member */
, @: W4 `, l0 G' D' L/ K - SPI_InitStructure.SPI_CRCPolynomial=7;
' K: e y3 l7 \0 W0 L5 ?& n q5 F - SPI_Init(SPI2, &SPI_InitStructure);
7 C( U* g/ ^/ @ - SPI_Cmd(SPI2, ENABLE);+ c$ [6 q( U2 y- q) u
& M3 }1 ]) Y/ P# O5 v - }
% [( r/ r# Z7 g1 i; Z1 t7 w1 ]
0 D; U% q2 ] q" S S0 W- /*******************************************************************************1 a7 x9 }( m$ s1 [
- * Function Name : SPI_ReadWriteByte
9 t8 m" h% O. Q9 K - * Description : SPI读写一个字节(发送完成后返回本次通讯读取的数据)
% K* E5 V! d. _9 [ - * Input : unsigned char TxData
# T3 V# X6 [4 ^( { - * Output : None! V% ]9 |& U; e% m& E
- * Return : unsigned char RxData
# ]- g& \9 N& `( j* N - *******************************************************************************/
% G2 G* o- T3 b$ B' M - unsigned char SPI2_ReadWriteByte(unsigned char TxData)$ ^5 l- k: v* N- f9 Z
3 {- w. y9 z7 I( Q g: W% R6 Q - unsigned char RxData = 0;* ?2 w4 f# K2 m5 `( m) m
- /* Wait till Transmit buffer is empty */ 0 Z* T8 p! d1 m! _* b5 {. h; D
- while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
8 w0 G4 T' \; z! k! v - /* Send A data */
e; _: G9 w( V. Y: I - SPI_I2S_SendData(SPI2, TxData);
0 `( k1 }) a- p3 {# b - // while(SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET);
6 ?* l. B% i' S - //等待数据接收. ~4 |& f5 p# Y" ^+ p
- while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);" Z! `2 c1 V+ t( Q
- //取数据8 s. ?7 R/ k7 U6 P3 D
- RxData = SPI_I2S_ReceiveData(SPI2);
) N; i2 v& Y+ k$ U* [5 ? - return (unsigned char)RxData;
: N( r/ J {: k2 N. j# S0 e9 h* z - }# Z8 ~* ^5 s& f p1 u0 n& a9 N
/ X5 G) W5 k2 l% \! Z- $ R; \4 R- U3 r, R/ d& x, T$ Y& q
0 M! o5 K! e" l9 \- i3 f9 D% u0 ^ h+ b" l/ f( m
