今天完成了OLED的调试
一花一世界003 发布时间:2015-2-5 18:10
. Z; }' `. ^+ F% b; `" r3 [OLED的驱动分析一下:
# J( Q) ?7 I$ J3 f) n& @9 Z( P, s  a+ }7 r* L9 ?% {: a: h
void OLED_Init(void)
" Q9 ?& C6 a; w: N, a3 f3 [8 d' {{
( U4 O- s3 s. K3 Z5 `    OLED_RST=0;
& @- a  F3 L9 R+ T3 e! ]( G/ i    DelayMs(50);
" n, a7 S6 j/ Y8 H4 q" @+ L    OLED_RST=1;       //从上电到下面开始初始化要有足够的时间,即等待RC复位完毕   ! ]' W1 g/ v& z& B9 G
" V2 M( n3 P9 O( x
    OLED_WrCmd(0xae);//--turn off oled panel
& c- D+ j. p$ z$ {( e+ P    OLED_WrCmd(0x00);//---set low column address
3 `: i4 k* V2 d5 z& V    OLED_WrCmd(0x10);//---set high column address6 |3 r4 p/ A! M/ c
    OLED_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
, v/ B" E/ p/ o3 c$ o. u) \    OLED_WrCmd(0x81);//--set contrast control register
' [, R3 ?4 r; v" y0 M4 z    OLED_WrCmd(Brightness); // Set SEG Output Current Brightness
% H$ {' l$ k7 E9 {( R2 u3 o) Y! Z    OLED_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
2 ^) Q+ @; l3 {% Q$ u' S2 i    OLED_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
- y4 C! g/ \( J5 s0 }    OLED_WrCmd(0xa6);//--set normal display
6 e3 t" J* b6 ], [    OLED_WrCmd(0xa8);//--set multiplex ratio(1 to 64)/ N1 [8 G9 V: E$ y9 e
    OLED_WrCmd(0x3f);//--1/64 duty
  c: C9 E9 U' Y, J( N$ i    OLED_WrCmd(0xd3);//-set display offset  Shift Mapping RAM Counter (0x00~0x3F)  u$ L! u  Y* @( N6 O
    OLED_WrCmd(0x00);//-not offset
* ?# I1 W3 u; Y; _" B- t) E( r    OLED_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
* y. t0 F4 s# z    OLED_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec! f# o9 {% [2 z7 G: Z* o6 r& L
    OLED_WrCmd(0xd9);//--set pre-charge period
' h. ?5 A0 v& z5 H2 I2 U/ y( w4 j. s# L% G    OLED_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
' I# x7 Q. n6 {2 M    OLED_WrCmd(0xda);//--set com pins hardware configuration
* n$ X: s4 a$ ~    OLED_WrCmd(0x12);9 z& q! c0 ~; q
    OLED_WrCmd(0xdb);//--set vcomh  z; ?( B0 j: O& D" c, u
    OLED_WrCmd(0x40);//Set VCOM Deselect Level$ J8 y1 X# \- Q( J/ \
    OLED_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)" [! G- K5 X1 ^4 K1 f7 p( J
    OLED_WrCmd(0x02);//
  q, r2 z- ^; z: u/ Y8 {    OLED_WrCmd(0x8d);//--set Charge Pump enable/disable
; Q- E* ~5 O8 x9 P; H    OLED_WrCmd(0x14);//--set(0x10) disable
% s7 i7 |1 V/ t    OLED_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
& Y: g) q/ F+ u. d5 T    OLED_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7) 2 E" S7 `. i, B1 v2 I2 ]  j
    OLED_WrCmd(0xaf);//--turn on oled panel+ p4 D! Y, Q1 ~4 _
) c6 T0 o$ e, T* K
    OLED_Fill(0x00);  //初始清屏
3 @$ X! o0 k* O    OLED_SetPos(0,0);   ! h. p: ~6 t& z1 Q8 C% x) ?$ D
} # q" P& `1 _  I2 Q2 R7 \# @9 x) z
% ]% H. N9 U' f) x. ?+ G0 D/*********************OLED写数据************************************/ $ X! X4 H( g# S: m0 m/ H2 V
void OLED_WrDat(unsigned char dat), b' n. E9 z' n
- n: P) A6 C( [    unsigned char i;
9 Y7 V6 J6 g; ?+ Q1 D: `7 f$ R    OLED_DC=1;  0 w9 [9 n3 r% [7 W$ g& }
    for(i=0;i<8;i++) //发送一个八位数据 6 t7 B: r. U1 \( \
3 @8 |2 F  W5 d: j) D, y        if((dat << i) & 0x80)$ s* A9 D0 P( V
        {) ]. Z, r* f$ r+ u! ^+ ]0 D
            OLED_SDA  = 1;- j3 |5 U5 I1 }  u9 k% J2 `! U! E$ d$ K
5 K' P9 o8 C4 M* Y        else  OLED_SDA  = 0;1 ~6 e) H/ a' n+ v) D+ Z6 [6 t9 t3 o
        OLED_SCL = 0;
. f( v) C3 Z: l/ Y* r        OLED_SCL = 1;) [3 D/ t( n# G! R
    }9 j5 m- ?. ?7 z% x; _
}3 h! f+ g! h, o( L; |' T
) m/ q4 D8 `. @1 c) J& j5 T; v$ _
/*********************OLED写命令************************************/                                      $ L; r2 d0 b; z, O8 Y, J( {0 ]
void OLED_WrCmd(unsigned char cmd)
* ]% Z7 J# J% ^  k{3 l) T" a* a6 |
    unsigned char i;
0 p' b. d+ Q" |2 S    OLED_DC=0;! D6 P" q' a: ?9 e, [1 p
# @2 L7 l' s3 [8 _: ?. N' T" ]    {
- D! s% E  S$ z' j# t+ P" o        if((cmd << i) & 0x80)
7 P* d7 X- b( Y0 l8 ~        {1 @! H5 @- H4 A: W, {
            OLED_SDA  = 1;
% u: ?1 X: M9 `0 A3 [2 f1 o        }
( |3 c- ~% x& g% N  v  V6 o        else 0 K9 I) m7 Z" }9 s
        {/ d* }( r9 H$ l" k: ?$ ~7 ?
            OLED_SDA  = 0;
" j4 ~0 a6 o1 B3 @# d8 {        }
# }* R; E% _3 W6 k* |. O- I        OLED_SCL = 0;( |& d* j. [" J2 o/ w: w  F
        OLED_SCL = 1;
* k6 i  [7 F6 E5 V- `. N    }
% Z* s' x! X+ H% f}) P; v7 w( ^! Z8 W7 u. c% A
! P, J' M' t' ~  V: _$ G. W! @打印了我们社区网站的网址的图片9 T" N( a+ L6 h- G
$ ~/ _" _) l6 ^' j" K0 F
赞 收藏 评论9 发布时间:2015-2-5 18:10
9个回答
天好蓝 回答时间:2015-2-5 20:12:34
lkl0305 回答时间:2015-2-5 20:14:01
多谢分享!
大秦正声 回答时间:2015-2-5 20:27:16
屏价格如何?工作温度范围?谢谢
一花一世界003 回答时间:2015-2-5 22:15:07
屏幕价格25,工作温度-50~60摄氏度
sacq12 回答时间:2015-2-5 22:24:48
不错,继续期待。。
拼命三郎V5 回答时间:2015-2-6 08:13:29
32F 回答时间:2015-12-1 11:52:28
" ?5 h' K! V; b) a. ^! W4 {1 d: A. t( d, F  L
好文章,值得学习,有原理图就好了
32F 回答时间:2015-12-7 16:12:12
好文章,值得学习
stary666 回答时间:2015-12-7 16:45:40
看看,,,,,,,,,,,,,,,
