keil MDK5.14最新版下载
yongjun 发布时间:2015-2-14 18:48
Keil有最新版的MDK5.14可下载,喜欢尝鲜的可以下载试试,不过还是没有解决“代码自动完成”功能的软件死机的问题。
3 A" v& c9 B( S  uhttps://pan.baidu.com/s/1pJ7JOJh
) \- S7 _. r  {# MMicrocontroller Development Kit - Version 5.14
  • [uVision]
    • This MDK release contains µVision V5.14.0.0.
    • Improved download support for missing Software Packs where a fixed version is selected in the project. Before the latest version was downloaded.
    • At load time of a project the device name can be manually changed when the project was using an obsolete device that no longer available with the current Software Pack.
    • The new debug command SBC allows to control software breakpoints which is for example important for algorithm verification that calculate CRC over a code area.
    • The Event Viewer displays now also timing information for interrupt execution.1 p5 [4 H7 G6 y7 D* Y$ Z/ E
  • [ARM Compiler]
    • This MDK release contains ARM Compiler 5.05u1 (build 106). All compiler related files located in ..\ARM\ARMCC\ directory. Details can be found in the Compiler specific Release Notes.
    • The ARM Compiler 5.04u2 for safety critical applications is available from ARM Compiler download area (a registration or login is required).: s1 n- M; b/ d- L1 p1 l2 I6 A
  • [Software Packs included]
    • Keil.MDK-Middleware Version 6.2.0 and CMSIS Version 4.2.0.  X: z; F% t# |3 p
  • [Target debugging]
    • Updated: ULink2 Firmware version update to 2.03 that fixes a potential problem with USB 3.0 ports.
    • Updated: Segger J-Link driver for ARM devices to version 4.96d that now supports Cortex-M7.
    • Updated: NuLink version 1.28.6386 with correct access to Flash algorithms from Software Packs.
      " y; J4 l2 ^/ |1 E5 j: `7 s
  • [Supported Operating Systems]- k6 b* l6 I4 M
0 l! I9 f4 r5 q/ J9 Y0 Q  y0 _$ n
8 e4 \# @3 q$ c, j+ ^7 J! @
赞 收藏 评论0 发布时间:2015-2-14 18:48
