先是HAL大致驱动模块部件
MAIN函数运行流程 {* S) F. X6 h" t( {8 \& V" L HAL_Init(); SystemClock_Config(); & m% S% ]1 x5 b0 R6 R* b% a( s/ b9 I /* Configures User push-button */5 A6 l. b# O9 [! Q BSP_PB_Init(BUTTON_USER, BUTTON_MODE_EXTI);$ l2 i0 @ n7 b /*##-1- Configure the DAC peripheral #######################################*/ DacHandle.Instance = DACx;% v+ ]0 s# N1 X% Y& Y$ Q- I+ V# v9 | /*##-2- Configure the TIM peripheral #######################################*/ TIM6_Config();! w3 Z! F0 P- O/ } * v9 D; N, T( W( p4 r! B /* Infinite loop */+ L2 ]# p9 r! Y* T. t while (1)5 o. p( B7 b) u& x3 x. o {3 d& N* e. b: u" Y& X. F /* If the Key is pressed */7 w% P* g, c K2 q if (ubKeyPressed != RESET). i- g E3 i `1 b { HAL_DAC_DeInit(&DacHandle); % o7 Q- v6 c+ g) V# @% ? /* select waves forms according to the User push-button status */ if (ubSelectedWavesForm == 1)! r* E3 ]9 A2 a M3 h! M {接下来就是三角波产生的函数, N$ J# {+ I; L% L: D /* The triangle wave has been selected */) n8 T, V! W4 U- a3 m; U: _ /* Triangle Wave generator -------------------------------------------*/ DAC_Ch1_TriangleConfig(); }产生三角波* r6 T) a6 p+ \2 @ else {产生阶梯波形6 f! S2 G8 _0 R: |2 N/ u1 D* J' ] /* The escalator wave has been selected */. O3 S' M4 {; s6 C4 h( H& p( ` /* Escalator Wave generator -------------------------------------------*/ DAC_Ch1_EscalatorConfig();2 ~5 P% ^) Z% G }9 B3 v$ f. m7 r& I3 n/ U1 n3 n 7 l, ]4 Y+ D1 u: r ubKeyPressed = RESET; } } }+ ]9 A& _ E; l" A0 Y2 ~ 0 I& \* W4 }. n0 q 首先说说STM32的DAC模块配置过程。
梯形波需要设一个数组。
触发源可能的列表' Y. B! F! E5 P4 V
好像不够了 |
| 多谢分享,赞~! |
多谢分享 |
| 感谢分享! |
| 学习了,不错。 |
| O(∩_∩)O谢谢大家支持 |
学习了,多谢楼主分享 |
| 学习了,HAL |
