STM32F103VCT6的SPI1数据发送和接收问题
LeoZhou34 提问时间:2015-3-24 12:59 /
各位大侠,我刚开始接触STM32F103VCT6,关于SPI1的数据发送的一些疑问,请帮忙!写了一个测试程序(SPI Master Mode),每秒定时发送数据,SPI部分的程序如下:
/* SPI1初始化*/
       GPIO_InitTypeDef  GPIO_InitStruct;
       SPI_InitTypeDef    SPI_InitStruct;
       NVIC_InitTypeDef  NVIC_InitStruct;
        /* Enable GPIOA and SPI1 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
        /* Enable the SPI1 Pins Software Remapping */
        GPIO_PinRemapConfig(GPIO_Remap_SPI1, DISABLE);
        /* Connect PXx to SPI1_NSS(PA.4) */
        GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_4;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOA, &GPIO_InitStruct);
        GPIO_SetBits(GPIOA, GPIO_Pin_4);
        /* Connect PXx to SPI1_SCK(PA.5) and SPI1_MOSI(PA.7) */
        GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_7 | GPIO_Pin_5;
        GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_PP;
        /* Connect PXx to SPI1_MISO(PA.6) */
        GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_6;
        GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
        /* SPI1 configuration -------------------------------------*/
        SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
        SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low;
        SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge;
        SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
        SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStruct.SPI_CRCPolynomial = 7;
        SPI_Init(SPI1, &SPI_InitStruct);
        SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_RXNE, ENABLE);
        SPI_Cmd(SPI1, ENABLE);
        /* NVIC configuration */
        /* Configure the Priority Group to 2 bits */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        /* Enable the SPI1 Interrupt */
        NVIC_InitStruct.NVIC_IRQChannel = SPI1_IRQn;
        NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStruct);
主程序中每1s进行SPI1数据发送。
       if(net_spi1_flag == 1)
            net_spi1_flag = 0;
            GPIO_ResetBits(GPIOA, GPIO_Pin_4);
            for(test_num=0; test_num<255; test_num++)
                for(test_len=0; test_len<255; test_len++)
                    SPI_I2S_SendData(SPI1, net_spi1_data[test_len]);
                      while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
问题:在程序中只开启了SPI1得接收中断,而没有开启发送中断,每次SPI1发送数据时,都会进入到SPI1中断服务程序中。SPI1的中断服务程序如下:
void SPI1_IRQHandler(void)
   static uint8_t spi_num=0;
    if(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) != RESET)
       spi_num++;
请不吝赐教!
赞 收藏 评论8 发布时间:2015-3-24 12:59
8个回答
stary666 回答时间:2015-3-24 13:05:48
帮顶。。。。。。。。。。。。。
小蚂蚁快溜跑 回答时间:2015-3-24 13:07:28
还不会,帮顶
wh854997179 回答时间:2015-3-24 14:18:50
帮顶
楼主你去群里问问
此名已占用 回答时间:2015-3-24 15:09:55
发送是clok上有没有波形?
废鱼 回答时间:2015-3-24 15:12:00
楼主看一下进入中断以后,中断寄存器的值  SPI 状态寄存器(SPI_SR)
kqh1120 回答时间:2015-3-25 08:51:13
木木鱼 回答时间:2015-3-25 09:03:10
不懂,帮顶
zhangdaijin 回答时间:2015-3-25 09:33:31
学习了!!!
