5 t( _) V# m7 Z5 i. e2 A: O /** * @brief Enters the Low Power Run mode." n3 x! J7 F8 U) I1 c * @note Low power run mode can only be entered when VCORE is in range 2.& W* k* m* d- L3 H' ^& @ * In addition, the dynamic voltage scaling must not be used when Low * power run mode is selected. Only Stop and Sleep modes with regulator * configured in Low power mode is allowed when Low power run mode is * selected. * @note In Low power run mode, all I/O pins keep the same state as in Run mode.5 S" ^( M. A" f; x2 v * @param None * @retval None( g3 J/ W1 q1 a */ void Enable_LowPowerRun_Mode(void)3 a8 l' ~( p3 j4 J% i { /* Enters the Low Power Run mode */- o5 z7 {5 y0 ^3 @ PWR->CR |= PWR_CR_LPSDSR;6 X% Z. a! @* T! R PWR->CR |= PWR_CR_LPRUN;% R' a; f% d% s a8 I. H* T }9 G) H( c1 J* x4 s I) n, `. r7 t /** * @brief Exits the Low Power Run mode.' Y% F" q; U$ p q" ` * @param None/ W( ^+ i- p5 \& [/ X * @retval None */ void Disable_LowPowerRun_Mode(void)/ U9 E% S( O! s& D- K { /* Exits the Low Power Run mode */ PWR->CR &= (uint32_t) ~((uint32_t)PWR_CR_LPRUN); PWR->CR &= (uint32_t) ~((uint32_t)PWR_CR_LPSDSR);$ A2 f+ ~' E$ F2 v }. c$ ^. u" g6 w+ R# Q( l |
| 谢谢,正在学习 |
学习学习 |
学习过,都忘了 |
| 学习学习 |
| 学习学习 |
| 还没有用过这东西 |
