stm32l053 WDT 驱动及使用
stary666 发布时间:2015-4-8 13:47
void
) Y/ f1 E+ l2 @; M# y2 vHAL_IWDG_Init(IWDG_HandleTypeDef * pst_Iwdg)
  k+ R- X  o: X1 [+ i6 l9 Y* |{" _1 Y; g" E9 G' T. T/ f
    /* Change IWDG peripheral state */. W$ A$ l, R$ y+ [( R
    pst_Iwdg->State = HAL_IWDG_STATE_BUSY;% N8 M! ^7 `& X0 L/ z5 b4 J
) M: Y$ n0 c' t4 R: j    /* Enable write access to IWDG_PR, IWDG_RLR and IWDG_WINR registers */
5 k  O. V0 }2 w7 E8 u- a" T5 a    /* by writing 0x5555 in KR */
$ H2 e1 O5 Y* P: ?    IWDG->KR |= KR_KEY_EWA;
/ b: q+ R, ~2 o* ^
, G# m: c/ o$ ]! C, m    /* Write to IWDG registers the IWDG_Prescaler & IWDG_Reload values to work with */
5 @% b! [- c3 d3 C    MODIFY_REG(IWDG->PR, (uint32_t)IWDG_PR_PR, pst_Iwdg->Init.Prescaler);
6 \  J  _  N5 m: U    MODIFY_REG(IWDG->RLR, (uint32_t)IWDG_RLR_RL, pst_Iwdg->Init.Reload);
2 W" j- \; T" R4 P! N$ I& f% R$ [7 a; m( x( _- a8 m. A
    /* check if window option is enabled */
" @+ t! e( M3 d. x( X* ^2 W& T    if (((pst_Iwdg->Init.Window) != IWDG_WINDOW_DISABLE) || ((IWDG->WINR) != IWDG_WINDOW_DISABLE))- d" J6 T9 ~3 ?% I1 a( I3 H" G! u
+ }: F: Q- f. D7 J7 i9 f1 d        /* Wait for register to be updated */2 O1 H- p& o* H* r- i
        while ((IWDG->SR & (IWDG_FLAG_PVU | IWDG_FLAG_RVU | IWDG_FLAG_WVU)) != 0)
* }. U( j2 J* q  m' g3 P' I  H! G        {
# |7 V5 h' ]; Y2 w+ ~        }9 E3 ]. E8 v  ?& J9 S. m- [# B
4 @1 s% s0 z" |. h, Z
        /* Write to IWDG WINR the IWDG_Window value to compare with */
+ ^5 K8 W" E) x6 s; h        MODIFY_REG(IWDG->WINR, (uint32_t)IWDG_WINR_WIN, pst_Iwdg->Init.Window);* M" \" e0 n' C* j% f  \
/ j4 I3 B- h# x! M/ N! M# z: ^6 G+ u) C+ k
    /* Change IWDG peripheral state */. n1 K. Z! V! `' j% m% Q
    pst_Iwdg->State = HAL_IWDG_STATE_READY;
' Y& d1 k9 |  a- k( b  I}
  e+ O! \# q8 F1 o: H
/ v& Q, A$ S0 ]! y  {( z  _& y  O$ ~void
/ ]; a' ~/ J9 F) _5 O6 \! DHAL_IWDG_Start(IWDG_HandleTypeDef * pst_Iwdg)
" s" u! h5 |! u8 w8 ]{
: w3 O3 i1 l( ?4 T8 k& J    /* Change IWDG peripheral state */
5 G' ~  D$ o; G8 G    pst_Iwdg->State = HAL_IWDG_STATE_BUSY;
! N( |" J3 w6 `( k9 V" `& p
3 e  ~  y+ d" k) F% L4 y/ w2 F    /* Reload IWDG counter with value defined in the RLR register */
6 h5 G' U. ~+ |! B. I: l    if ((pst_Iwdg->Init.Window) == IWDG_WINDOW_DISABLE)
* r4 |9 r7 E" H3 q- g' O1 G& H    {+ f% c0 c* n8 X& v) |: c# w8 `6 v& G
        IWDG->KR |= KR_KEY_RELOAD;7 E: P0 Z* Y+ \, W. m/ c" C
    }% s, D5 J' w  S  S/ N% ~8 S
- ?$ K' }# T% V9 N. B7 ?    /* Enable the IWDG peripheral */1 s0 O% C  n) [5 z
    IWDG->KR |= KR_KEY_ENABLE;7 C7 }, |1 E3 Q; ^0 ]' K7 T* F
5 h  e+ Y/ b9 _, X) g( T    /* Wait until PVU, RVU, WVU flag are RESET */( {7 ?' ^% ]+ _; s' d
    while (0 != ((uint32_t)(IWDG->SR & (IWDG_FLAG_PVU | IWDG_FLAG_RVU | IWDG_FLAG_WVU))))+ k3 p5 ?) f. X* \$ s' K, R
6 y, Y- [% U; z    }6 ?6 C, h, C$ t( ]: G
( _) A0 u0 A3 Q
; K) i% b. C6 y' E2 g    pst_Iwdg->State = HAL_IWDG_STATE_READY;
7 o) o2 y. v6 x( W$ Y, e0 g1 c}4 r$ L. h" c# O. P) ]
- e6 t+ h7 m/ g/ |$ g
void! ?* V" Q7 C1 a' X( p, o
HAL_IWDG_Refresh(IWDG_HandleTypeDef * pst_Iwdg)
( n: D3 O, T& {; b: e{
8 n" ^: X) L9 s% j    /* Change IWDG peripheral state */! y& S5 d1 \# w+ c+ o
- ~5 v+ D$ O, ^" N, ?- h; i
# ~8 P+ _' p: Z. D9 L# f  {  N& _    /* Wait until RVU flag is RESET */
& d7 |( Z% Y7 v8 x( B3 J    while ((IWDG->SR & (IWDG_FLAG_RVU)) == IWDG_FLAG_RVU)# a( N. E. H& d: x4 b: w) O
    {' }+ g# a/ Y; _) u) w
    }' z. b3 ]1 y- K5 A
1 \8 A- z6 g, j5 S
    /* Reload IWDG counter with value defined in the reload register */0 ^' v7 S7 h. I9 l
    IWDG->KR       |= KR_KEY_RELOAD;' n0 m5 P7 I) s/ ~% s3 w( W
% U  l9 C9 `+ a3 F5 x: v6 a" q
( k# t( O7 v- r    pst_Iwdg->State = HAL_IWDG_STATE_READY;, h0 m2 s& d, u, x# i2 ~
5 z  c; A8 Q4 x+ t& ]5 A& ^' o% @+ S/ ^7 M" I. ^6 j
HAL_IWDG_StateTypeDef
1 M& q7 ]0 X" \; k6 THAL_IWDG_GetState(const IWDG_HandleTypeDef * pst_Iwdg)
  s% V' N/ g6 H8 o0 |* V{
; F; m) |! j8 v7 F+ ~    return pst_Iwdg->State;; P$ G( L% a, N: B3 s8 ~$ Z
}& @: F6 H! E% C- }! o
$ ^* Q0 m' M* q* D/ ]
void8 l* U" w. F' ~: W1 W- o
IWDG_Delay(void)5 G5 O  K+ O8 {' h
{9 t( n0 m, h7 E" {2 @" u
    uint32_t u32_stic;- O0 _  ]/ P8 P
, O3 P2 _% I( w4 u5 l    u32_stic = GET_SYSTEM_TICK_VALUE();
: t/ z6 W/ _( [; _) y) t% R; e7 X. ?0 g
    /*@ignore@*/$ D+ g  J8 E: `( Z
    do
9 D$ M+ i0 Y; m5 U* x; E    {0 Z0 ?* Q! L) m, V) D
    } while (GET_SYSTEM_TICK_ECLIPSE(u32_stic) < (uint32_t)(IWDG_SYSTICK));6 o: V& ^  f  r
( n( z8 E; y5 _  W, e+ G
    /*@end@*/# c: D9 G# @4 z: E3 I$ s7 q
) \6 E0 {$ Q3 l# s, U# f$ p* M8 b) O" y" P
void
' t2 x9 g! D- |. _& OIwdg_Refresh(void)
; H% P* e8 V* }: H2 m/ V  f{
) b- r( w& ~% K* t    HAL_IWDG_Refresh(&IwdgHandle);' Y. L/ f5 Y: c9 O- V% U: L
" t: S) S/ V& f; y2 x. n! D; ]1 r: U6 J% A+ U+ n
void
2 P# g3 i0 h7 j) v! ~( yIwdg_main(void)
7 l3 P! e" @6 f. h) z4 u7 w{
8 ]) P# n( E7 [3 m! ^# u1 q    /*##-1- Check if the system has resumed from IWDG reset ####################*/% V9 I6 z: Q0 y, l
    if ((uint32_t)__HAL_RCC_GET_FLAG(RCC_FLAG_IWDGRST) != 0)/ S* ^. X& a0 |( J; O7 z
    {/ I2 P: {/ j0 q$ d" @8 m
        /* Clear reset flags */' D- n) |4 K& L" g  p; W' f2 `
        RCC->CSR |= RCC_CSR_RMVF;
% S6 ^+ _. }% K  ?9 f2 c0 A  j/ O' ^    }
6 Z# l& P$ {% h6 y: Q
$ a8 u; I6 ~  i( w" O2 {    /*##-2- Configure & Initialize the IWDG peripheral ######################################*/* o0 Y5 ^. Q6 L3 V: P8 W
    /* Set counter reload value to obtain 762ms IWDG TimeOut.
* i: u* V5 G% E; p$ N" m; @     Counter Reload Value = LsiFreq*Timeout(s)/prescaler% V$ K9 ^9 j! J+ ]: H( C
                          = 40000*700ms/(16*1000)8 a) e' r- q- U+ @% O
                          = 1750 (approx)
6 v6 P( f- d, d, D    */5 h3 j' X8 u3 p! @# d9 Y$ n3 o
    IwdgHandle.Init.Prescaler = IWDG_PRESCALER_32;
4 s. B! o0 `' ?/ y; z    IwdgHandle.Init.Reload    = (uint32_t)IWDG_RELOAD_NUMBER(IWDG_RELOAD, IWDG_PRESCALER_32); /* IWDG_RELOAD,16prescaler(40khz) */& r3 m. R0 R/ o: d4 u* B
    IwdgHandle.Init.Window    = 0xfff;                                                        /* Window =  0xfff*/3 r. {/ N/ E" ^* a6 ]/ J
  w8 M5 ~% x2 W; J
    /* when window option is enabled, we enable the IWDG immediately */
" _6 W1 o4 V" c2 u5 J; V2 O* [    /* by writing 0xCCCC to the KEY register */
1 L. J) N' a( |$ _) ~( t! e4 m# I" k
    /*##-3- Start the IWDG #####################################################*/1 h1 z8 w0 c0 ^% u% N
    HAL_IWDG_Start(&IwdgHandle);
2 _2 B: R7 H$ T9 p% }    HAL_IWDG_Init(&IwdgHandle);
, N! L- g: q3 f2 T6 ?! ?}
赞 收藏 评论1 发布时间:2015-4-8 13:47
肖久 回答时间:2015-4-8 20:42:30
帮顶一下 让更多的人 过来帮你
