刚开始学单片机,STM8在IAR环境下能用C++,对我来说实在是太好了,我是那种没对象不会编程的银,我可以把功能都封装起来,以后需要优化时再脱离库函数。 这两天总结了一下STM8 ADC的用法,手头的103F6支持5路ADC,两路被UART占用了,这里列出我的三路扫描的方法,与各位初学者共同探讨:0 e7 K$ ?4 _) `0 K 5 T, e: Y& K7 i, o% N // 头文件: /*; D$ J7 g( V4 E ADC */3 b; \3 i. Z6 B. R) z: u* k' H 9 q9 t F6 p- j/ } #ifndef _ADC1_H #define _ADC1_H 7 Q. H( ~/ k5 }5 y0 r& p: v #include "stm8s_conf.h"! X* e6 p+ x; G #define ADC1_EOC_IRQ 0x16% h& _/ i' [( w class __near cADC1! u/ E: K: ], L, I8 t { public:9 N" _' C- Y- {/ \ cADC1(int);# b1 p' C, `, m3 \ uint16_t read_ADC_value(ADC1_Channel_TypeDef);& ^% H+ }% o5 `! a N/ ~8 w void NextConversion();" X$ t: r' R0 b% E- W ` void StartConversion(); private: uint16_t m_channel2_value,m_channel3_value,m_channel4_value; p2 M& {& R* r. R5 ~/ Z ADC1_Channel_TypeDef m_current_channel; }; cADC1 __near Adc1(0); #endif // 源程序+ h! C- h$ K" ]* `1 W& }5 }$ S #include "Adc1.h"$ e0 F! @6 C t) ] 6 `9 k5 G% Q3 A E5 M- Y3 u /* ADC1 通道扫描方式, 开通了三个通道 */! g( u4 p/ M+ s& L2 R3 ^ 8 w6 y$ ^' }& ?# a( ^ cADC1 __near *Adc1_instance; cADC1::cADC1(int id) { Adc1_instance = this; // 中断要引用这个实例 // 对于stm8s003 103F3,有ANI2~6 // ADC1_CHANNEL_2:% Z- x* Q+ N9 h8 a GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_IN_FL_NO_IT); // ADC1_CHANNEL_3: l7 R9 Q* Y4 G5 C2 k1 M GPIO_Init(GPIOD, GPIO_PIN_2, GPIO_MODE_IN_PU_NO_IT); // ADC1_CHANNEL_4: GPIO_Init(GPIOD, GPIO_PIN_3, GPIO_MODE_IN_PU_NO_IT); W! Z- o1 Q' M7 L. W! R' h // ADC1_CHANNEL_5: // UART1_TX$ u7 B; }- L# l3 r7 g // GPIO_Init(GPIOD, GPIO_PIN_5, GPIO_MODE_IN_FL_NO_IT);, | \. R1 w' B5 F2 S0 N8 W: @# B // ADC1_CHANNEL_6: // UART1_RX // GPIO_Init(GPIOD, GPIO_PIN_6, GPIO_MODE_IN_FL_NO_IT); m_current_channel = ADC1_CHANNEL_2; ADC1_Init(ADC1_CONVERSIONMODE_SINGLE , m_current_channel, ADC1_PRESSEL_FCPU_D8,\( d1 w) M5 @) m ADC1_EXTTRIG_TIM, DISABLE, ADC1_ALIGN_RIGHT,ADC1_SCHMITTTRIG_ALL,ENABLE); ADC1_ScanModeCmd(ENABLE); // 扫描模式* D+ k& v" b0 M2 G, f7 S ADC1_DataBufferCmd(ENABLE); // 使用数据缓冲区寄存器 ADC1_ITConfig(ADC1_IT_EOCIE, ENABLE); // 转换结束中断 StartConversion(); // 执行第一次转换 } uint16_t cADC1::read_ADC_value(ADC1_Channel_TypeDef Ani): K1 z, U' q0 g; [' L% ]$ N2 h { switch (Ani)% J% |8 M; v( ~# v; Q3 J { case ADC1_CHANNEL_2: return m_channel2_value;! X! x7 x. [6 ?! \! l- y+ [ case ADC1_CHANNEL_3: return m_channel3_value; case ADC1_CHANNEL_4: return m_channel4_value; default: return 0;3 r6 w3 m1 s: C z6 C& U1 X# X } } - E ^% E" h4 ?. c/ R 9 ~/ H! U7 X4 v7 j+ f& y void cADC1::StartConversion()) m5 `' `4 r6 j3 h { if (ADC1_CHANNEL_2 == m_current_channel) // 启动通道+ v, Z# ~) t1 Z3 k {; D# ?# j9 i! R" ~6 L ADC1_Cmd(ENABLE); // 中断使能 ADC1_StartConversion(); }- p. a% ~' E. t% c } : Y' R$ E& w1 a6 D void cADC1::NextConversion()5 [# }7 [6 j" _. X, E% l9 D m o; H {- c, Z( B' x' C+ M) u switch (m_current_channel)- B* L; _+ G. A1 W {$ @- F# t9 K% y case ADC1_CHANNEL_2:. r5 T9 x! Y3 }/ Y1 C m_channel2_value = ADC1_GetBufferValue(0x02); // 读取ADC结果,保存在成员变量中" O6 D! M9 I. U# m8 ?2 f D m_current_channel = ADC1_CHANNEL_3; // 切换到下一个通道 ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE, m_current_channel, ADC1_ALIGN_RIGHT); break;, D* Z5 X; I8 G% t- f' n& X( [ ' j/ V" g8 ?. n8 y9 f, B case ADC1_CHANNEL_3: m_channel3_value = ADC1_GetBufferValue(0x03); // 读取ADC结果,保存在成员变量中0 v( f- o7 S7 d m_current_channel = ADC1_CHANNEL_4; // 切换到下一个通道6 u1 ]* d+ @; r) c' A$ } ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE, m_current_channel, ADC1_ALIGN_RIGHT);2 P% S" J: _6 V break;! y( z: Y6 H* V7 ^ case ADC1_CHANNEL_4: m_channel4_value = ADC1_GetBufferValue(0x04); // 读取ADC结果,保存在成员变量中 m_current_channel = ADC1_CHANNEL_2; // 切换到下一个通道4 D/ x# Y- @1 o. \2 n C+ G9 r0 H ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE, m_current_channel, ADC1_ALIGN_RIGHT); " ?. ?$ J3 r# [! Q4 i ADC1_Cmd(DISABLE); // 停止,由StartConversion启动下一次的扫描' r& V% J) e& \, a break;8 V& ]' ^0 F5 c+ L& g2 t( _' u // 可以扩展到通道5、6 default: break; }7 v& w# W2 I; \1 `% A! u# N }5 \* y+ `) T9 s) C & g0 F' j4 F4 I' o2 Y INTERRUPT_HANDLER(ADC1_EOC_IRQHandler, ADC1_EOC_IRQ) {# ]6 p1 x' S+ T; m& }" ? ADC1_ClearITPendingBit(ADC1_IT_EOC); Adc1_instance->NextConversion(); } 只需要定时调用Adc1.StartConversion(),就可以通过 Adc1.read_ADC_value(ADC1_CHANNEL_x)读取相应通道的ADC值。 |
STM8自学笔记(推荐STM8很好的入门电子书)
无刷直流电机控制应用+基于STM8S系列单片机---电子书
【精华资料】STM8Sxx固件库FOR IAR
基于STM8的DALI (数字可寻址调光协议)
分享STM8 风驰光盘的资料,是完整的(包括原理图+例程+PDF注释)
《无刷直流电机控制应用 基于STM8S系列单片机》
STM8S库函数中文参考 小软件
【资料分享】STM8L的智能手持血糖监测设备的源码
基于STM8S207工程模板
【培训资料】STM8系列PPT培训资料
{; E7 P* g6 C. C/ y' H
int value;$ X" o* o5 G" K) R
// Led_yellow.Flash();
value = Adc1.read_ADC_value(ADC1_CHANNEL_2);3 v% o9 N: y3 A5 G; W) c. S+ U
double voltage = value * 3.3/ 1023;7 L3 _4 r7 a4 D0 x
double radio = (double)value / 1023 * 100;
cUART1::printf("value = %d %d %d %fV %f% \r\n",8 P: d. C- F$ K. E4 ?- x6 o
Adc1.read_ADC_value(ADC1_CHANNEL_3),
Adc1.read_ADC_value(ADC1_CHANNEL_4),
(int)value, voltage, radio);
}. H' Y* [9 O3 M1 I% F7 z1 x
三路采样输出的结果:7 {; |, J) Y- z
22:55:29.677 value = 550 658 413 1.3322V 40.3714%
22:55:30.180 value = 550 658 414 1.3354V 40.4692% 5 l5 z. o( Y- b2 z" v
22:55:30.683 value = 550 658 414 1.3354V 40.4692% , [ q; a t& Q$ J' d
22:55:31.186 value = 551 657 413 1.3322V 40.3714%
22:55:31.690 value = 550 657 413 1.3322V 40.3714% $ q* O3 N$ k( f8 J
22:55:32.192 value = 550 657 413 1.3322V 40.3714%
22:55:32.695 value = 550 657 414 1.3354V 40.4692% . g0 _+ {5 k6 q& y! q
22:55:33.198 value = 550 658 414 1.3354V 40.4692% ! F" }2 F5 q1 B3 ]
22:55:33.701 value = 551 658 414 1.3354V 40.4692% % n \! H! @, V* N
22:55:34.206 value = 550 658 413 1.3322V 40.3714% 5 Q9 q7 d0 @5 @' @/ Z
22:55:34.707 value = 550 657 414 1.3354V 40.4692%
22:55:35.210 value = 550 657 413 1.3322V 40.3714%
22:55:35.713 value = 550 657 413 1.3322V 40.3714% - `! ^9 f8 u( o: |% z' |9 r' b
22:55:36.216 value = 550 657 413 1.3322V 40.3714% ) l5 @8 H/ U/ F, D
22:55:36.719 value = 550 658 413 1.3322V 40.3714%
22:55:37.220 value = 550 658 414 1.3354V 40.4692%
22:55:37.720 value = 550 657 414 1.3354V 40.4692% ; x6 ?2 n' @" J! H; Q/ i" N! b8 Q
22:55:38.228 value = 550 657 413 1.3322V 40.3714% 8 O% ]' h& M$ ]4 Z* c9 V+ ?7 _2 k
22:55:38.731 value = 550 657 413 1.3322V 40.3714%
22:55:39.234 value = 550 658 413 1.3322V 40.3714%
