【学习经验】STM32笔记之九:打断它来为我办事,EXIT (外部...
ashantx 发布时间:2015-5-16 13:59
sw笨笨的STM32笔记之九:打断它来为我办事,EXIT (外部I/O中断)应用$ N! R$ Y; \! l2 b3 X0 A
- W; _9 b$ s8 X
) }) t# k9 G, `0 M1 Xa)        目的:跟串口输入类似,不使用中断进行的IO输入效率也很低,而且可以通过EXTI插入按钮事件,本节联系EXTI中断。/ X8 v1 G# i0 z  ?5 b
b)        初始化函数定义:* Q) j3 W  d/ K2 |1 D( t% R
void EXTI_Configuration(void); //定义IO中断初始化函数# \" J/ Y: \7 r( E0 t: V+ u
c)        初始化函数调用:
0 x! O: K; a- j- MEXTI_Configuration();//IO中断初始化函数调用简单应用:
3 H( ?" o' Q) C5 \$ f+ z* Jd)        初始化函数:
3 ?0 R; r# X' I) O6 C! h" G0 dvoid EXTI_Configuration(void)
" ~6 z7 i- k4 _{% d6 E  Z: F/ _! }* m! X
  EXTI_InitTypeDef EXTI_InitStructure;        //EXTI初始化结构定义
9 I# f- X: l) R5 G; _
. |0 v& R2 J! T7 B1 c6 P. nEXTI_ClearITPendingBit(EXTI_LINE_KEY_BUTTON);//清除中断标志
- J0 j6 J& g# m; L, K' N2 ^* |   GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource3);//管脚选择3 E. m9 D& R. o4 [
   GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource4);# ]8 U+ X/ i" ~2 H3 w
     GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource5);* X0 a5 `4 N$ \
     GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource6);
5 Q" D9 L5 I  Q& ~- k: b+ t
/ K. P, J$ u) G    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;//事件选择6 {% \3 v+ `' ~& j; v
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;//触发模式4 c7 L. p! q/ q+ O' L
  EXTI_InitStructure.EXTI_Line = EXTI_Line3 | EXTI_Line4; //线路选择2 i, g5 @7 o, U
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;//启动中断
9 G6 T2 A: X( t; @7 D9 ^6 W  EXTI_Init(&EXTI_InitStructure);//初始化" b7 I5 i  l  Z0 s' A$ F
( a( ]2 o% c# v  C9 N/ b$ k2 C
- V, P$ l5 R2 V7 [e)        RCC初始化函数中开启I/O时钟
5 u3 `, T& m3 G% r' a2 x# \RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
8 M  t! O; e! o  U   e! _% p: I( `# `
GPIO初始化函数中定义输入I/O管脚。6 C) c: [( Z/ {$ a
//IO输入,GPIOA的4脚输入; U5 D$ f2 Q6 w" y9 ?0 {2 b
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
$ v5 D& S9 D/ e* Q8 H4 D/ t    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;         //上拉输入2 d* u, N, E4 i7 M/ y- n- ~
  GPIO_Init(GPIOA, &GPIO_InitStructure);                //初始化
+ ]4 {+ H# `! m3 mf)        在NVIC的初始化函数里面增加以下代码打开相关中断:
8 x3 d3 l  h& }0 r6 ^4 f: f4 O! W  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQChannel;        //通道
0 {; k" A. f3 [6 |) C( c: Z  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//占先级
% _, y, c. M# K1 q& M+ A9 P& h  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                        //响应级5 m& \% B1 h5 i& e
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //启动1 m% q8 G4 ^7 U5 l; c) x  y
  NVIC_Init(&NVIC_InitStructure);        //初始化, G  {2 b! j  l( Z1 U1 K: W% |
& b% l7 `7 z# _) tg)        在stm32f10x_it.c文件中找到void USART1_IRQHandler函数,在其中添入执行代码。一般最少三个步骤:先使用if语句判断是发生那个中断,然后清除中断标志位,最后给字符串赋值,或做其他事情。
# s1 J# m6 \8 ^' q6 Z0 s9 v# R  if(EXTI_GetITStatus(EXTI_Line3) != RESET)                                  //判断中断发生来源5 Q+ _% y7 x4 U2 K. O
   { EXTI_ClearITPendingBit(EXTI_Line3);                                          //清除中断标志/ @% u. E' M) k; X8 m1 g7 c% [1 F
    USART_SendData(USART1, 0x41);                                              //发送字符“a”
$ q: J0 S9 x' I) q$ E    GPIO_WriteBit(GPIOB, GPIO_Pin_2, (BitAction)(1-GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_2)));//LED发生明暗交替* |5 t' ~, e) y
}* S% w  ^& v+ F; L% c  d
h)        中断注意事项:
5 N5 r% F( u; E; w* V中断发生后必须清除中断位,否则会出现死循环不断发生这个中断。然后需要对中断类型进行判断再执行代码。
4 y6 ]! u% t8 V, x# c使用EXTI的I/O中断,在完成RCC与GPIO硬件设置之后需要做三件事:初始化EXTI、NVIC开中断、编写中断执行代码。* W6 J' F8 L% T  h
4 T% {; X2 Q5 G0 g/ M3 E
2 h: m; W- _) K% P9 m; R
赞 收藏 评论1 发布时间:2015-5-16 13:59
魅影迷踪 回答时间:2015-5-20 08:55:08
这也行吗
