l053的RTC时钟
stary666 发布时间:2015-5-19 16:40
今天终于实现了L053的RTC时钟6 n& }! v6 Z4 p% J' Q
下面是代码
( X0 I0 ]1 m2 o5 V5 N#define __RTC_WRITEPROTECTION_DISABLE()             \
7 e( d; y7 \7 @, F    do \+ `9 `- y3 e8 z6 W0 }* Z
9 D( A" |/ |$ @. I        RTC->WPR = 0xCA;   \
1 D! ~: Z' [+ ?% \4 h        RTC->WPR = 0x53;   \$ p& @+ s8 Q9 P: x
    } while (0)
. y3 V8 D. h, @/ Z' q2 v/ z8 I( P4 ?* ~8 e9 v" F
. z1 R$ I& I6 ?; U  * @brief  Enable the write protection for RTC registers.
2 n. h6 m. j& B9 m" d- ]: T& J  * @param  __HANDLE__: specifies the RTC handle.
5 C% A! t0 f) ^% f( b, D  * @retval None
4 T3 O. ?# K# K- o  */) M9 }$ T- E& r# T
#define __RTC_WRITEPROTECTION_ENABLE()              \0 e0 g+ z; B' C
    do \4 R3 E$ ~! Y7 m3 c" H: U
    {                      \' a7 m( L/ ?0 a* P+ J/ }" s
        RTC->WPR = 0xFF;     \
1 z4 I3 K+ f' I' Q' |/ K    } while (0)
8 M1 l, \9 _# |! A. [( G4 A; c#define ASYN_PREDIVE_SHIFT 16
$ u8 z# `' E, X/ ~- q& p+ a$ d3 O; e#define YEAR_SHIFT         16
9 w, y$ S& |1 X1 ~/ L) y" ~: g#define MONTH_SHIFT        8
2 c. f+ P5 r  B3 P" {#define WEEKDAY_SHIFT      134 y0 J* g1 x) J  N  B
#define HOUR_SHIFT         16
8 ?$ S8 q; {( o8 M#define MINUTE_SHIFT       8  {  v! ^5 O1 B0 X% \
#define TIMEFORMAT_SHIFT   13
) [. f: j0 L& g8 J5 D. _( `#define PM_SHIFT           22# a+ C8 i0 ?; I. T3 B* M& g% U4 V
void
( C0 A- ]. ~* \& f3 O; I6 LRTC_Init(void)+ V  I, s+ [5 C! t
; {% S( ]3 U; s2 U; c2 Q    RCC->CSR |= RCC_CSR_LSION;
- Q* y1 O* D4 l" M
7 F5 k7 w9 Y/ E4 m6 a    while ((RCC->CSR & RCC_CSR_LSIRDY) != RCC_CSR_LSIRDY)
2 ^( E: W% Q) @0 E( S3 f4 T    {
9 C4 |2 }  J7 w, `) r; D  o/ w    }
6 o3 M$ X5 @) U
3 _/ K1 Y/ c! I" c    RCC->APB1ENR |= RCC_APB1ENR_PWREN;# W) C" O2 i& R& J/ K% v0 U
    PWR->CR      |= PWR_CR_DBP;
) n# L0 M5 X' h9 Q+ @! \) q    RCC->CSR      = (RCC->CSR & ~RCC_CSR_RTCSEL) | RCC_CSR_RTCEN | RCC_CSR_RTCSEL_1;
1 P4 d- U" j. @" G    RCC->APB1ENR &= ~RCC_APB1ENR_PWREN;
% S6 a. g( e5 {3 K1 J! l
4 j5 F: M9 Y+ t, a& l! }( R    /* Configure RTC */! \% i' x/ I/ y) R- l7 f0 A
    __RTC_WRITEPROTECTION_DISABLE();8 P. b% p3 J0 O
    /* Clear RTC_CR FMT, OSEL and POL Bits */
) d1 L% J4 v, Q! t, ^    RTC->CR   &= ((uint32_t) ~(RTC_CR_FMT | RTC_CR_OSEL | RTC_CR_POL));
8 e- E- H- K0 g# v. w; `8 z* O# s* t$ W3 N9 r  h4 e
    /* Configure the RTC PRER */
4 ^8 S  H  l0 a    RTC->PRER  = (uint32_t)(RTC_SYNCH_PREDIV);5 o  V* t* H' ~+ [- b
    RTC->PRER |= (uint32_t)(RTC_ASYNCH_PREDIV << ASYN_PREDIVE_SHIFT);
4 y3 M, J9 t& s" F! b6 f5 P    /* Exit Initialization mode */# I( |  T; Y$ M8 ~
    RTC->ISR  &= (uint32_t) ~RTC_ISR_INIT;
! u) F4 Q/ P4 z. n    RTC->OR   &= (uint32_t) ~(RTC_OR_ALARMOUTTYPE | RTC_OR_RTC_OUT_RMP);+ K6 S; u% k& v+ g9 H- a3 f
    __RTC_WRITEPROTECTION_ENABLE();- t5 K9 d5 q" D' U0 |
赞 收藏 评论6 发布时间:2015-5-19 16:40
6个回答
stary666 回答时间:2015-5-19 16:40:25
设置日期- A8 A0 \9 o5 f) U* p' j' y
void
& b1 U) T$ a, t4 wRTC_SetDate(RTC_DateTypeDef * st_Date)
: P2 a  X6 A# D' e% S4 u{' Q. s7 ~5 m" P+ }" x
    uint32_t u32_TateTmp = 0;
8 [  [0 C0 @. o: T; P1 [( ^2 J- |2 P$ [. \# H& P
    u32_TateTmp = ((((uint32_t)st_Date->Year) << YEAR_SHIFT) | \
! C: ^/ e+ O9 g+ a% Q3 N% n                   (((uint32_t)st_Date->Month) << MONTH_SHIFT) | \# F( g4 D1 ~, o* d2 s
                   ((uint32_t)st_Date->Date) | \& ?. ~0 G" b# t; ^6 n, `
                   (((uint32_t)st_Date->WeekDay) << WEEKDAY_SHIFT));; [& e3 ~2 J# g. g  i; k% y& R; G
% L; V' I$ X: x* }, B1 t/ |
' ?5 E. ^, R" x' b9 @0 X* z    RTC->ISR |= RTC_ISR_INIT;
  Z# A4 }5 y; q& O7 x/ C+ X
: o$ U) C7 G9 k$ S0 g* R4 p8 [    while ((RTC->ISR & RTC_ISR_INITF) != RTC_ISR_INITF)
  q# ?  J8 y0 r# J, _    {# ~- r8 U3 Z& |4 X' x9 O
1 t* a4 v1 U+ k1 q" E! z( O
+ ?0 \- w) K" V9 n8 O( W    RTC->DR   = (uint32_t)(u32_TateTmp & RTC_DR_RESERVED_MASK);% l5 O5 c( D# Q" }, ~
  O1 H: |% E* g  S  T
/ y* z( `$ X+ F% ?7 e& b    __RTC_WRITEPROTECTION_ENABLE();; H! {0 |6 ~. P$ s
1 T; [) o2 {) t. [5 l( z3 g
stary666 回答时间:2015-5-19 16:40:45
设置时间
  f# t7 x" d/ T) Cvoid
8 Y+ [0 g" g/ x) E/ ORTC_SetTime(RTC_TimeTypeDef * st_Time)
8 U. K+ ?. x) Q. ]* p5 J- D{- Q. s( N) o0 h$ m
    uint32_t u32_TimeTmp = 0;/ i/ `3 o8 ~5 }+ s
3 ?+ ?9 v2 D, g' r
    st_Time->TimeFormat = RTC_HOURFORMAT_24;3 j# z- c9 G8 X. j  x" q
    u32_TimeTmp         = (((uint32_t)(st_Time->Hours) << HOUR_SHIFT) | \4 R: h+ f7 F" v% s
                           ((uint32_t)(st_Time->Minutes) << MINUTE_SHIFT) | \
: G/ z3 q2 f5 b) f                           ((uint32_t)st_Time->Seconds) | \. b- P( x$ B, n& J( A% A
                           ((uint32_t)(st_Time->TimeFormat) << TIMEFORMAT_SHIFT));* H2 l% U9 Q+ P2 O3 s* R: Q1 @
3 ]/ H3 \$ e8 H9 K: l" C    __RTC_WRITEPROTECTION_DISABLE();% ^7 D) ^% Y& z' W! Y- @" i
    RTC->ISR = RTC_INIT_MASK;8 @; d5 N$ H: q
2 ^8 j6 J+ B( S: J
    while ((RTC->ISR & RTC_ISR_INITF) != RTC_ISR_INITF)+ K% V$ V# x, `5 ]( f. A# m! B
    {1 A, y: c& }, D, ?8 G. x3 u5 X
    }) K* k$ i8 _6 x1 ~$ k; r; E
5 X% F4 E0 |+ V- l* y. J    /* Set the RTC_TR register */
9 F, W! ?3 ^4 }) Q- O- q    RTC->TR   = (uint32_t)(u32_TimeTmp & RTC_TR_RESERVED_MASK);9 l0 e" C) l7 C5 C0 }% W/ m
0 X( D+ w  u- l- T1 P    /* Clear the bits to be configured */
' o9 b/ S3 c; X    RTC->CR  &= (uint32_t) ~RTC_CR_BCK;8 a' N6 b2 x$ |. s# u
( I& w$ S; Y: t& g    /* Configure the RTC_CR register */
& s) ]& M& g0 y1 l+ y6 r. o    RTC->CR  |= (uint32_t)(st_Time->DayLightSaving | st_Time->StoreOperation);4 g8 F- i* G( |- _, A- \
$ t0 t" h4 s7 O6 W    /* Exit Initialization mode */: h8 c' q4 y# T0 ~% a
    RTC->ISR &= (uint32_t) ~RTC_ISR_INIT;% a' d% i* C( {7 f
: W: M# p9 A0 m  v1 E% X1 x) G. u    __RTC_WRITEPROTECTION_ENABLE();2 ?& N  I! X: f+ d0 ?# W
stary666 回答时间:2015-5-19 16:41:09
获取时间8 J, V: D3 W  e; S% g
void
" Y( _6 [1 Q5 W, I' v8 d% R! C, aRTC_GetTime(RTC_TimeTypeDef * st_Time)
" V  G- {  F5 i# J{
& A% s& x( ]0 @: g0 k) {    uint32_t u32_TimeTmp = 0;+ Y9 U9 @; G6 F# G5 c1 G' B1 w, T% k
2 r3 m8 m0 B% ~* Y5 ~$ T    /* Get subseconds values from the correspondent registers*/
7 O6 ?# ?0 N3 ^& p% b9 k& L; y    st_Time->SubSeconds = (uint32_t)(RTC->SSR);
/ a+ K5 o5 x. V6 w/ R4 J6 T7 {* k6 N/ p( x  T! X
    /* Get the TR register */
8 k: d: s- L- o: o    u32_TimeTmp         = (uint32_t)(RTC->TR & RTC_TR_RESERVED_MASK);6 d3 {, j; E, E9 @
! h9 R6 m8 F8 U$ K+ S- t' K    /* Fill the structure fields with the read parameters */
1 h3 ]. j! E2 }0 p3 r( k- ^    st_Time->Hours      = (uint8_t)((u32_TimeTmp & (RTC_TR_HT | RTC_TR_HU)) >> HOUR_SHIFT);  v5 u) t" x( M! H& K: d) l
    st_Time->Minutes    = (uint8_t)((u32_TimeTmp & (RTC_TR_MNT | RTC_TR_MNU)) >> MINUTE_SHIFT);
2 G% J& z0 }* Y0 S7 e    st_Time->Seconds    = (uint8_t)(u32_TimeTmp & (RTC_TR_ST | RTC_TR_SU));/ g6 o! I7 f& I, b& R# b0 f
    st_Time->TimeFormat = (uint8_t)((u32_TimeTmp & (RTC_TR_PM)) >> PM_SHIFT);+ _9 I& F! _* A% b7 d
沐紫 回答时间:2015-5-19 16:43:28
恭喜楼主大大
mark0668 回答时间:2015-5-19 17:33:45
恭喜楼主,顶顶加深对RTC知识
为什么是EEFOCUS小白 回答时间:2015-5-20 08:55:14
F0系列的RTC是不是比F1的好用呢
