最近使用f4cube V1.5开发VCP驱动,按照F429-Discovery板子的配置选择OTG-HS接口作为Device设备来用,选择CDC协议。修改完APP_RX_DATA_SIZE和APP_TX_DATA_SIZE为2048,添加LineCoding代码。可是连接到计算机上,装完驱动(VCP V1.4)之后显示错误代码10的故障。计算机业换过win764/32位的。所以估计是代码的错误,使用USB VIEW观测之后,效果如下: Device Descriptor: bcdUSB: 0x0200 bDeviceClass: 0x00 bDeviceSubClass: 0x00 bDeviceProtocol: 0x00 bMaxPacketSize0: 0x40 (64) idVendor: 0x0483 (STMicroelectronics) idProduct: 0x5740 bcdDevice: 0x0200 iManufacturer: 0x01 0x0409: "STMicroelectronics" iProduct: 0x02 0x0409: "STM32 Virtual ComPort" iSerialNumber: 0x03 0x0409: "000000002B1A" bNumConfigurations: 0x01 ConnectionStatus: DeviceConnected Current Config Value: 0x00 Device Bus Speed: Full Device Address: 0x03 Open Pipes: 0 Configuration Descriptor: wTotalLength: 0x0043 bNumInterfaces: 0x02 bConfigurationValue: 0x01 iConfiguration: 0x00 bmAttributes: 0xC0 (Bus Powered Self Powered ) MaxPower: 0x32 (100 Ma) Interface Descriptor: bInterfaceNumber: 0x00 bAlternateSetting: 0x00 bNumEndpoints: 0x01 bInterfaceClass: 0x02 bInterfaceSubClass: 0x02 bInterfaceProtocol: 0x01 iInterface: 0x00 Unknown Descriptor: bDescriptorType: 0x24 bLength: 0x05 05 24 00 10 01 Unknown Descriptor: bDescriptorType: 0x24 bLength: 0x05 05 24 01 00 01 Unknown Descriptor: bDescriptorType: 0x24 bLength: 0x04 04 24 02 02 Unknown Descriptor: bDescriptorType: 0x24 bLength: 0x05 05 24 06 00 01 Endpoint Descriptor: bEndpointAddress: 0x82 IN Transfer Type: Interrupt wMaxPacketSize: 0x0008 (8) bInterval: 0x10 Interface Descriptor: bInterfaceNumber: 0x01 bAlternateSetting: 0x00 bNumEndpoints: 0x02 bInterfaceClass: 0x0A bInterfaceSubClass: 0x00 bInterfaceProtocol: 0x00 iInterface: 0x00 Endpoint Descriptor: bEndpointAddress: 0x01 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Endpoint Descriptor: bEndpointAddress: 0x81 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 观察发现枚举应该没有问题,可是端点没有打开。不知何故? |
又及:
关于cube和标准库的争辩由来已久。cube的好处是显而易见的:硬件免配置,用户可以将尽力用到应用上,而且熟悉了之后整个代码的结构还是相对简明的。但是标准库的好处也是不用言说的:代码结构非常简洁,不像cube同一个功能要封装几层,标准库很容易追踪到函数的实现。而且用户量庞大。
但是cube在另外一些方面也远远好于标准库,之前的标准库并不附带usb和freertos,当你使用stemwin的时候也要自己将其添加到工具中,但是cube想当一个百宝箱。
此外mbed的库叶挺不错,希望arm借助mbed能够将arm的变成标准化,今年年底应该可以看到mbed os。此外,谷歌新出的Brillo不知道是不是和M系列的CPU能搭上。
科技发展太快了,硬件工程师很累呀。希望能有办法只专注于应用,而非平台。
在usbd_conf.h中有两个宏:USBD_MAX_NUM_INTERFACES和USBD_MAX_NUM_CONFIGURATION。我将其值设置为2,问题顺利解决了。
这两个宏对应于CubeMX软件USB_DEVICE Configuration 配置卡里面Basic Parameters的头两项。
再说一下为什么要改这两项。在我用USB VIEW观察的时候我看到了两个接口。所以USBD_MAX_NUM_INTERFACES改为2是合理的。CDC类的确有两个Interface:第一个包含通讯端点,第二个包含两个数据端点。
但是为什么要将USBD_MAX_NUM_CONFIGURATION设置为2,我就不清楚,我只清楚的是:在usbd_ctlreq.c的函数USBD_SetConfig内部有if (cfgidx > USBD_MAX_NUM_CONFIGURATION ) 这句话。而cfgidx的含义是什么呐?我在追踪了一会发现这个值,可能是由setup阶段有关。
那么有谁能告诉我USBD_MAX_NUM_CONFIGURATION是什么意思。
HAL的结构的使用和Linux的做法很相似,将硬件层和应用层分离出来,这样的做法是很好的,但是适应的确需要个过程,比较标准库用了那么久了。
好像标准库也有USB的各种模式的驱动啊,我不知道你所指的没有USB是说哪方面?
%DESCRIPTION%=DriverInstall,USB\VID_0483& PID_5740
和我用USB VIEW看到的一样。
无助呀,
网站是: http://stm32f4-discovery.com/
我需要用usb view再观察一下,然后排查一下cube生成的代码还需要做什么工作。我看cube的那个um1734看了一两天,也没看明白流程。杯具呀!
下面是用usb view得出的数据:
Device Descriptor:
bcdUSB: 0x0200
bDeviceClass: 0x00
idProduct: 0x5740
bcdDevice: 0x0200
iManufacturer: 0x01
iProduct: 0x02
0x0409: "STM32 Virtual ComPort in FS Mode"
iSerialNumber: 0x03
0x0409: "00000000050C"
Current Config Value: 0x01
Open Pipes: 3
bInterval: 0x10
Transfer Type: Bulk
bInterval: 0x00
Transfer Type: Bulk
bInterval: 0x00
bNumEndpoints: 0x01
iInterface: 0x00
Unknown Descriptor:
bLength: 0x05
05 24 00 10 01
Unknown Descriptor:
bLength: 0x05
05 24 01 00 01
Unknown Descriptor:
bLength: 0x04
04 24 02 02
Unknown Descriptor:
bLength: 0x05
05 24 06 00 01
bInterval: 0x10
bNumEndpoints: 0x02
iInterface: 0x00
Transfer Type: Bulk
bInterval: 0x00
Transfer Type: Bulk
bInterval: 0x00
顺便吐槽一下cube库中F4/429-discovery没有USB Device的例程,F4X9的例程似乎也不适用。
我的F429使用的是标准库里面的USB CDC 驱动,比这个HAL好理解些,这个HAL的USB代码太复杂了
嗯,我刚才在看我提到网站上的VCP,他用的就是标准库。
