Keil升级到5.15了
党国特派员 发布时间:2015-6-5 15:39
升级信息
2 Q) V8 Q8 C- K5 T
  • [ARM Compiler]- d$ j# m5 a! N+ a# d5 b
    •       This MDK release contains ARM Compiler 5.05u2 (build      169). All compiler related files located in      ..\ARM\ARMCC\ directory. Details can be found in the      Compiler specific Release Notes.+ n% l, w( M8 e8 W2 Z
  •     [uVision]$ }8 Y: ?" x" f5 K- `
    •       This MDK release contains µVision      V5.15.0.
    •       Improved: Support for multiple ARM Compiler Versions that allows now to Setup Default ARM Compiler Versions for each      processor core.
    •       Added: Support for Stack usage watermark in the      System and Thread Viewer that is available with      CMSIS-RTOS RTX V4.78 or higher. This also shows the maximum      stack load during execution of a thread.
    •       Improved: Icons in the Project Window for RTE Configuration Files indicate compatibility of      current files with software components from new Software Packs.      The new command Update Config File and Lauch Merge      available from context menu in the Project Window simplifies      the migration of existing configuration settings.
    •       Improved: MDK now uses Semantic Versioning for      Software Packs, software components, and configuration      files.
    •       Added: Set-up PC-Lint has a new option to include all      project-target related folders for searching header      files.
    •       Added: Source      Version Control System (SVCS) templates files for      GIT      and Tortoise SVN.9 w) C: N. o9 X) N. [' w
  •     [Software Packs included]" ^. o) c) n0 C
    •       Keil - MDK-ARM Professional Middleware 6.4.0% K. O1 |, R0 F5 z# i
            The Keil::MDK-Middleware 6.4.0 Software Pack supports      now ARM Cortex-M7 devices and solves a problem with File System      (fpwd function) and Networking (HTTP server).      Keil::MDK-Middleware 6.4.0 requires ARM::CMSIS 4.3.0 and      Keil::ARM_Compiler 1.0.0 Software Pack.
    •       ARM - CMSIS 4.3.0( P9 _2 D* ~, h6 ~: ^6 S
            The ARM::CMSIS 4.3.0 Software Pack adds a CMSIS-Driver      for Serial Audio Interface (SAI) and improves CMSIS-RTOS RTX      with Stack Watermark and IRQ timing statistics. Included are      also several other enhancements such as cache control functions      for Cortex-M7.
    •       Keil - ARM Compiler Extensions 1.0.04 y% Y% v# M# q7 N
            The Keil::ARM_Compiler 1.0.0 Software Pack contains the      new Software Component Compiler that expands MicroLib with      assert and enables I/O re-targeting via File System, UART, ITM      debug channel, or user-defined functions.
      . \1 L* N) e* P, F" `4 x, \; O& M
  •     [Target debugging]
    2 f% G! o! O/ G8 C9 s5 A, c
    •       Updated: Driver for Segger J-Link with bug fixes and      support for JTAG clock speed: 20, 25, 33, and 50      MHz.
    •       Updated: Driver and firmware for STMicroelectronics      ST-Link to support the latest STM32 devices.
    •       Updated: Driver for Nuvoton Nulink with bug fixes      and support for M0519, NM1320 and Mini58      Cortex-M0 based devices.8 h4 _% K, u$ C
  •     [Pack Installer]
      g- _0 o, v/ I) U% B
    •       Improved: Selection of Devices and Boards      lists Device Specific and Generic Software Packs and      relevant Project Examples. When the Pack Installer is      launched from uVision the device of the project target is      selected.
    •       Added: Output window that summarizes warning and      error messages.
        e5 R* O2 g5 A' [! a- }, X7 P" n
  •     [Supported Operating Systems]) a  b& q+ M( q, F
& U& R3 F( m. e4 X
需要的同志自己去下吧。
3 H* r$ p. j* Q, P- j7 U% v下载链接:http://www.keil.com/fid/itz2awwtdy9j1w16z011l46m3mlvkks1o66vd1/files/umdkarm/MDK515.EXE
( G" T2 A/ u0 L% O- s
4 P$ k* x. V- x- Y; c# x. R  f0 |3 W4 y9 @2 z3 z5 ?, h2 M
  n. R1 e, y* j+ N7 B, d4 D  X2 h
赞 收藏 评论19 发布时间:2015-6-5 15:39
19个回答
JackieLaura 回答时间:2015-6-5 15:58:57
semon12345 发表于 2015-6-5 15:515 j) S& j9 y- s: u
我也是前天更新的5.14,变化挺大的与4相比
! i/ X. \4 }; {- s& U5刚出来的时候用过,当时下载的是5.02,试了下,后来一直用的4.7。前几天换了个F303RE,才去下载的5.14。不过现在4.7也可以开发F303RE,只需要安装一下F303标准外设库里面的第三方插件就可以了。
semon12345 回答时间:2015-6-5 15:51:21
JackieLaura 发表于 2015-6-5 15:49- \$ u' N- R2 U
我还是先用5.14吧
' U8 ?( }( k: ?  [
semon12345 回答时间:2015-6-5 15:48:28
JackieLaura 发表于 2015-6-5 15:41* v1 n0 J3 ]2 v4 U
前两天刚换的5.14,这么快5.15就出来了。。
+ X& X0 V; d. k* i
快两个星七了吧
JackieLaura 回答时间:2015-6-5 15:41:18
Paderboy 回答时间:2015-6-5 15:41:26
有啥更新吗?对比5.14
JackieLaura 回答时间:2015-6-5 15:49:42
semon12345 发表于 2015-6-5 15:48: ]- b5 R' o3 M+ ~# Z; s" F
快两个星七了吧
6 |* ~& q/ m9 j; s: M! p我还是先用5.14吧
Paderboy 回答时间:2015-6-5 15:53:45
5.14是变化小,对比4.7
星辰一方 回答时间:2015-6-5 16:54:06
一直5.12
你好我好大家好! 回答时间:2015-6-5 19:26:57
4.72最好用
wyxy163@126.com 回答时间:2015-6-5 19:43:06
夏明smile 回答时间:2015-6-5 19:43:22
我用的是5,却不知道是5点几
夏明smile 回答时间:2015-6-5 19:44:34
怎么注册呢?原来的就行吗?
wamcncn 回答时间:2015-6-5 20:09:03
不想升级了,没玩没了
博根 回答时间:2015-6-5 21:51:37
KEIL5.14用的时候总是卡退 回到4.72A了
12下一页
