; Y! R% p$ ^7 i) z: `2 Xvoid broadlink_broadcast_init(void)& x- W3 S4 y0 F
( v- a0 [ a# d: R: ` struct pbuf *p;
1 h" \, ]. f2 c" ~
0 [$ e U- i n8 y4 P) ^. \ SET_IP4_ADDR(&broadlink_ip, BROADLINK_IP_ADDR); ' N# s9 b8 x3 Q% ]/ i
/* Create a new UDP control block */
( Y% }6 E2 F; W+ c+ ~& | broadlink_infor.upcb = udp_new(); % x" H) v% g) b( Y/ ]' ?
p = pbuf_alloc(PBUF_TRANSPORT, sizeof(sm), PBUF_RAM);4 U: G( j5 c1 w: k8 @
p->payload = (void*)sm;
" B* i9 v3 u. {3 X o2 w! q. l p->len =8;; o( C/ s; n2 P% Y
p->tot_len = 8;- V/ W+ b1 Z* b7 ]6 z8 ^. t3 T
broadlink_infor.upcb->local_port = UDP_CLIENT_PORT;6 q. Z8 _3 q% }: p6 k3 P
udp_connect(broadlink_infor.upcb, &broadlink_ip, BROADLINK_PORT);
& N1 W6 r: J3 B& M9 ^ udp_send(broadlink_infor.upcb, p); 3 Q" w5 e1 m+ C4 U
9 b* @3 D6 N1 ?* |$ |! t* N
+ Q6 ?5 c0 i7 o7 L7 F /* Bind the pbroadlink_upcb to any IP address and the UDP_PORT port*/% g0 C# H! y! l" w' {, o+ r
udp_bind(broadlink_infor.upcb, IP_ADDR_ANY, UDP_CLIENT_PORT);1 j) h4 [! u I) w8 O; J; s# w" q- k
udp_recv(broadlink_infor.upcb, broadlink_rec_callback, NULL);# y/ H6 \# Q4 c0 v+ X
/* Reset the pbroadlink_upcb */) @0 X& J1 n! ?5 l& n8 n$ B. r4 z
udp_disconnect(broadlink_infor.upcb); //如果去掉这个函数,sever端将无法收到数据
) [0 Q1 ^2 B- h, z /* Free the p buffer */% e) l& q; T6 D( h% J' P8 z' _' i+ l
pbuf_free(p);6 G& Z6 ?4 T7 V1 f8 W1 E' @5 @
" O% l1 `; s$ M; e: z1 u+ R
( }. H2 ]( |& H# r* @: \- ~7 ~能否解释下,为什么要去掉udp_disconnect(broadlink_infor.upcb)函数才能将数据发送出去,为什么? 还是我哪里设置有问题?求解 |
$ K6 U- {4 v) u0 w i3 d |
这段代码是官方的?
