想要請問,我有兩個Channel的ADC,第一個Channel : ADC1 IN11 PC1 和另一個Channel: ADC1 IN12 PC2,但是我在讀取的時後數值一直不對,所以想要請問我的程式是哪裡有問題呢? 謝謝 int main(void) { /* System clocks configuration ---------------------------------------------*/ RCC_Configuration(); /* NVIC configuration ------------------------------------------------------*/ NVIC_Configuration(); /* GPIO configuration ------------------------------------------------------*/ GPIO_Configuration(); /* Configure the USART1 */ USART_Configuration1(); /* Configure the ADC */ ADC_Configuration(); /* Configure the DMA */ DMA_Configuration(); while(1) { ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_239Cycles5); AD_value = ADC_GetConversionValue(ADC1); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 2, ADC_SampleTime_239Cycles5); AD_value2= ADC_GetConversionValue(ADC1); if (ticks++ >= 900000) { /* Set Clock1s to 1 every 1 second */ ticks = 0; Clock1s = 1; } /* Printf message with AD value to serial port every 1 second */ if (Clock1s) { Clock1s = 0; printf("The current IA value = 0x%04X \r\n", AD_value ); printf("The current IB value = 0x%04X \r\n", AD_value2); } } } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); } void ADC_Configuration(void) { /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 2; ADC_Init(ADC1, &ADC_InitStructure); /* ADC1 regular channel14 configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_55Cycles5); //通道11采样时间 ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 2, ADC_SampleTime_55Cycles5); //通道12采样时间 /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); //使能ADC1 /* Enable ADC1 reset calibaration register */ ADC_ResetCalibration(ADC1); //允许ADC1复位校准寄存器 /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); //检测校准寄存器是否复位完成 /* Start ADC1 calibaration */ ADC_StartCalibration(ADC1); //启动ADC1 校准 /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); //检测校准是否完成 /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); //允许ADC1进行DMA传送 /* Start ADC1 Software Conversion */ ADC_SoftwareStartConvCmd(ADC1, ENABLE); //软件触发启动ADC1转换 } void DMA_Configuration(void) { DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //DMA 外设 ADC 基地址 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC1_ConvertedValue; // //DMA 内存基地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 1; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); /* Enable DMA channel1 */ DMA_Cmd(DMA1_Channel1, ENABLE); } |
是不是两个数据互相影响,就好像从一个口读取出来的数据 |
