【活动】庆祝STM32出货量超10亿颗,开发板送不停!
沐紫 提问时间:2016-1-4 13:06 /
赞 收藏 2 评论434 发布时间:2016-1-4 13:06
434个回答
zhwd102198 回答时间:2016-1-26 08:41:52
有LTDC功能,主频高达180M
主要使用在继电器保护装置上!
沐紫 回答时间:2016-1-26 09:03:55
zhwd102198 发表于 2016-1-26 08:41
有LTDC功能,主频高达180M
主要使用在继电器保护装置上!
再上传一个文档才行哦
Ljmp 回答时间:2016-1-26 09:17:20
哟哟哟,不错哦!!!
laoguoex 回答时间:2016-1-26 09:20:11
1. 图片见附件
2. 产品型号: STM32F103RC. 资料见附件
   特性:
   1. NVIC外部中断功能以及优先级配置起来很不错
   2. GPIO可灵活配置
3. 设计: 开发过智能卡读卡器和智能卡之间的数据抓取仪器
arm_cortexm3_processor_trm_100165_0201_00_en.pdf
889.64 KB, 下载次数: 0, 下载积分: ST金币 -1
arm_cortexm4_processor_trm_100166_0001_00_en.pdf
813.42 KB, 下载次数: 0, 下载积分: ST金币 -1
ARMv7-M Architecture Reference Manual (1).pdf
2.42 MB, 下载次数: 0, 下载积分: ST金币 -1
ARMv7-M Architecture Reference Manual.pdf
Critical_Interrupt_Prioritization_PRD04_PRDC_013242_1_0.pdf
445.53 KB, 下载次数: 0, 下载积分: ST金币 -1
DDI0337E_cortex_m3_r1p1_trm.pdf
2.14 MB, 下载次数: 0, 下载积分: ST金币 -1
DDI0344K_cortex_a8_r3p2_trm.pdf
4.3 MB, 下载次数: 0, 下载积分: ST金币 -1
DDI0413D_cortexm1_r1p0_trm.pdf
943.48 KB, 下载次数: 0, 下载积分: ST金币 -1
DDI0432C_cortex_m0_r0p0_trm.pdf
461.17 KB, 下载次数: 0, 下载积分: ST金币 -1
DDI0440C_etm_m4_r0p1_trm.pdf
446.26 KB, 下载次数: 0, 下载积分: ST金币 -1
DDI0479C_cortex_m_system_design_kit_r1p0_trm.pdf
1.52 MB, 下载次数: 0, 下载积分: ST金币 -1
DDI0484C_cortex_m0p_r0p1_trm.pdf
417.14 KB, 下载次数: 0, 下载积分: ST金币 -1
DDI0489D_cortex_m7_trm.pdf
1.04 MB, 下载次数: 0, 下载积分: ST金币 -1
枫飞 回答时间:2016-1-26 09:25:45
NUCLEO-F072RB
特性很多啦
The STM32 Nucleo board provides an affordable and flexible way for users to try out new ideas and build prototypes with any STM32 microcontroller line, choosing from the various combinations of performance, power consumption and features. The Arduino™ connectivity support and ST Morpho headers make it easy to expand the functionality of the STM32 Nucleo open development platform with a wide choice of specialized shields. The STM32 Nucleo board does not require any separate probe as it integrates the ST-LINK/V2-1 debugger and programmer. The STM32 Nucleo board comes with the STM32 comprehensive software HAL library together with various packaged software examples, as well as direct access to mbed online resources.
Key Features
    STM32 microcontroller with LQFP64 package
    Two types of extension resources
    Arduino Uno Revision 3 connectivity
    STMicroelectronics Morpho extension pin headers for full access to all STM32 I/Os
    mbed-enabled (http://mbed.org)
    On-board ST-LINK/V2-1 debugger/programmer with SWD connector
    selection-mode switch to use the kit as a standalone ST-LINK/V2-1
    Flexible board power supply
    USB VBUS or external source(3.3 V, 5 V, 7 - 12 V)
    Power management access point
    Three LEDs
    USB communication (LD1), user LED (LD2), power LED (LD3)
    Two push buttons: USER and RESET
    USB re-enumeration capability: three different interfaces supported on USB
    Virtual Com port
    Mass storage
    Debug port
    Supported by wide choice of Integrated Development Environments (IDEs) including IAR™, Keil®, GCC-based IDEs
最欣赏的是对于外设引脚全部引出,经典的开发部分+stlink部分,在原先discover板子的基础上精简了很多
外壳反面对于这块板子的使用也做了些简要介绍。
用于实际项目,主要用到串口、usb口、驱动led、按键、oled、lcd12864、各种传感器等各种
DM00105823.pdf
1.94 MB, 下载次数: 0, 下载积分: ST金币 -1
DM00105918.pdf
233.45 KB, 下载次数: 0, 下载积分: ST金币 -1
skymaze 回答时间:2016-1-26 09:26:52
2.STM32F303
具有高性能、实时功能、数字信号处理、低功耗与低电压操作特性,做飞行器,跑个滤波算法妥妥的。
DM00058181.pdf (2.29 MB, 下载次数: 5)
w919720378 回答时间:2016-1-26 09:29:16
使用f103rct,没拿过官方开发板,都是自己折腾的。使用stm32开发过两个项目,一个是电机转速表,一个是云台控制板。
STM32F103RCT6.PDF
1.66 MB, 下载次数: 0, 下载积分: ST金币 -1
songdalong 回答时间:2016-1-26 09:31:40
1、   晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
使用了discovery开发板;
2、   说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)
实际使用了STM32F103RC的芯片,选择这颗芯片,主要的特点是性价比高,芯片资料齐全,学习资料多,开发起来简单易用。
3、   基于STM32你做过哪些设计?(如没有则不写)
采用了STM32F103RC做过低电压采集器,相机外部控制器等。
MB997C
MB997C
colin2135 回答时间:2016-1-26 09:49:36
2.产品特性
   128KB FLASH,16KB SRAM
   两组扩展座子,可连接ARDUNIO
   板载了STLINK/V2-1,可在mbed进行在线编程
   2组I2C接口
   4组UART接口
  11个定时器
DM00141386.pdf (1.48 MB, 下载次数: 0)
凤羽呈祯 回答时间:2016-1-26 09:50:49
ows: 2; word-spacing: 0px; -webkit-texFeatures
 Core: ARM® 32-bit Cortex™-M0 CPU,
frequency up to 48 MHz
 Memories
– 16 to 64 Kbytes of Flash memory
– 8 Kbytes of SRAM with HW parity checking
 CRC calculation unit
 Reset and power management
– Voltage range: 2.0 V to 3.6 V
– Power-on/Power down reset (POR/PDR)
– Programmable voltage detector (PVD)
– Low power modes: Sleep, Stop, Standby
– V
BAT supply for RTC and backup registers
 Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x6 PLL option
– Internal 40 kHz RC oscillator
 Up to 55 fast I/Os
– All mappable on external interrupt vectors
– Up to 36 I/Os with 5 V tolerant capability
 5-channel DMA controller
 1 x 12-bit, 1.0 μs ADC (up to 16 channels)
– Conversion range: 0 to 3.6 V
– Separate analog supply from 2.4 up to 3.6
 One 12-bit D/A converter
 Two fast low-power analog comparators with
programmable input and output
 Up to 18 capacitive sensing channels
supporting touchkey, linear and rotary touch
sensors
 Up to 11 timers
– One 16-bit 7-channel advanced-control
timer for 6 channels PWM output, with
deadtime generation and emergency stop
– One 32-bit and one 16-bit timer, with up to
4 IC/OC, usable for IR control decoding
– One 16-bit timer, with 2 IC/OC, 1 OCN,
– Two 16-bit timers, each with IC/OC and
OCN, deadtime generation, emergency
stop and modulator gate for IR control
– One 16-bit timer with 1 IC/OC
– Independent and system watchdog timers
– SysTick timer: 24-bit downcounter
– One 16-bit basic timer to drive the DAC
 Calendar RTC with alarm and periodic wakeup
from Stop/Standby
 Communication interfaces
– Up to 2 I2C interfaces; one supporting Fast
Mode Plus (1 Mbit/s) with 20 mA current
sink, SMBus/PMBus and wakeup from STOP
– Up to two USARTs supporting master
synchronous SPI and modem control; one
with ISO7816 interface, LIN, IrDA
capability, auto baud rate detection and
wakeup feature
– Up to two SPIs (18 Mbit/s) with 4 to 16
programmable bit frame, 1 with I2S
interface multiplexed
 HDMI CEC interface, wakeup on header
reception
 Serial wire debug (SWD)
 96-bit unique ID
 All packages ECOPACK®2
Audio and waveform generation using the DAC in STM32F0xx microcontroller families.pdf (486.25 KB, 下载次数: 0)
mrclp 回答时间:2016-1-26 09:52:47
1.
2.STM32F051R8T6 内置 64KB 闪存、 8 KB RAM, 采用 LQFP64 封装
a.板载 ST-LINK/V2, 提供模式选择开关, 可把电路板变成一个独立的 STLINK/V2 在线调试器及编程器 ( 通过 SWD 接口烧录和调试代码 )
b.电路板电源: 通过 USB 数据线或外部 5V 电源供电
c.外部应用电源: 3V 和 5V 输出电压
STM32F0-DISCOVERY用户手册.pdf (3.23 MB, 下载次数: 0)
ayumi7 回答时间:2016-1-26 10:01:25
很喜欢 STM的  MCU    自己有空就玩下,淘宝买的血糖仪 里面是 STM8L152   捣鼓了下  弄了个玩具 ,求一套开发板吧。STM32也很想试试
IMG_20160116_210805.jpg IMG_20160121_222333_HDR.jpg IMG_20160121_222417_HDR.jpg IMG_20160121_222317_HDR.jpg IMG_20160121_212412_HDR.jpg
重在参与吧  混个熟脸
陋室林 回答时间:2016-1-26 10:12:57
         型号:  STM32F103ZET6
        特性:该芯片具有 64KB SRAM、512KB FLASH、2 个基本定时器、4 个通用定时器、2 个高级定时器、2 个 DMA 控制器(共 12 个通道)、3 个 SPI、2 个 IIC、5 个串口、1 个 USB、1 个 CAN、3 个 12 位 ADC、1 个 12 位 DAC、1 个SDIO 接口、1 个 FSMC 接口以及 112 个通用 IO 口
       STM8 32选型手册.pdf (1.39 MB, 下载次数: 0)
GX_Liu 回答时间:2016-1-26 10:32:22
1、
一个是用到的芯片:STM32F207,一个是买了玩的开发板;
2、STM32F207特性:
高达1M字节的Flash存储器, 512字节的动态口令存储器
12个16位和2个32位的定时器,频率可达120MHz,每个定时器有多达4个用于输入捕获/输出比较/PWM或脉冲计数的通道和增量编码器输入
4个USART接口和2个UART接口 (传输速率7.5 Mbit/s,支持ISO7816,LIN,IrDA接口和调制解调控制)
带有专用DMA的10/100 以太网 MAC.,支持硬件IEEE 1588v2(MII/RMII) 8到14bit并行摄像头接口,最高达48Mbyte/s
3、设计:数据采样分析器--采集湿度、温度、pm2.5(通过蓝牙跟pm2.5成品相连)等
stm32f207G.pdf
2.52 MB, 下载次数: 0, 下载积分: ST金币 -1
武穆传奇 回答时间:2016-1-26 10:57:18
用特定颜色填充目标图像的一部分或全部
将源图像的一部分(或全部)复制到目标图像的一部分(或全部)中
通过像素格式转换将源图像的一部分(或全部)复制到目标图像的一部分(或全部)中
将像素格式不同的两个源图像部分和/ 或全部混合,再将结果复制到颜色格式不同的部分
或整个目标图像中。
用此芯片控制了可调电源
DM00031020_Chap11_16_29_37_zh.pdf
2.13 MB, 下载次数: 0, 下载积分: ST金币 -1
