STM32CubeMX生成的代码在Keil5ARM中报错!
天堂鸟x1 提问时间:2016-4-30 17:32 /
每次在STM32CubeMX生成Keil5的代码,用Keil5打开后,编译过程中报错:
../Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_pwr.c(137): error:  #1113: Inline assembler not permitted when generating Thumb code
具体错误在:
/* Private functions ---------------------------------------------------------*/
__NOINLINE
static void PWR_OverloadWfe(void)
  __asm volatile( "wfe" );
  __asm volatile( "nop" );
当我将这2行注释掉后,系统能够从新编译,并能够正常运行!
请问:
1、这2句是什么意思,注释掉会不会有问题?(本人新人一个,还望大神详细解释)
2、有没有办法或哪里设置,将这里处理掉?
赞 收藏 评论3 发布时间:2016-4-30 17:32
3个回答
watershade 回答时间:2016-5-1 13:17:23
我的没有遇到过这种问题,请问你怎么配置的。可以穿一下配置文件
天堂鸟x1 回答时间:2016-5-3 10:10:53
我是在STM32CubeMX中生成的项目程序,使用STM32F103C8T8芯片,配合使用Firmware 1.3.1,Keil系统使用的是uVision V5.11,配的是对应编程模块。无论我陪什么样的设置,都提示这个错误,只有注释掉这2句,就能够使用!
附上原始生成的代码
  * @file    stm32f1xx_hal_pwr.c
  * @author  MCD Application Team
  * @version V1.0.3
  * @date    11-January-2016
  * @brief   PWR HAL module driver.
  *          This file provides firmware functions to manage the following
  *          functionalities of the Power Controller (PWR) peripheral:
  *           + Initialization/de-initialization functions
  *           + Peripheral Control functions
  * @attention
  * <h2><center>&copy; COPYRIGHT(c) 2016 STMicroelectronics</center></h2>
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "stm32f1xx_hal.h"
/** @addtogroup STM32F1xx_HAL_Driver
/** @defgroup PWR PWR
#ifdef HAL_PWR_MODULE_ENABLED
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/** @defgroup PWR_Private_Constants PWR Private Constants
/** @defgroup PWR_PVD_Mode_Mask PWR PVD Mode Mask
#define PVD_MODE_IT               ((uint32_t)0x00010000)
#define PVD_MODE_EVT              ((uint32_t)0x00020000)
#define PVD_RISING_EDGE           ((uint32_t)0x00000001)
#define PVD_FALLING_EDGE          ((uint32_t)0x00000002)
/** @defgroup PWR_register_alias_address PWR Register alias address
/* ------------- PWR registers bit address in the alias region ---------------*/
#define PWR_OFFSET               (PWR_BASE - PERIPH_BASE)
#define PWR_CR_OFFSET            0x00
#define PWR_CSR_OFFSET           0x04
#define PWR_CR_OFFSET_BB         (PWR_OFFSET + PWR_CR_OFFSET)
#define PWR_CSR_OFFSET_BB        (PWR_OFFSET + PWR_CSR_OFFSET)
/** @defgroup PWR_CR_register_alias PWR CR Register alias address
/* --- CR Register ---*/
/* Alias word address of LPSDSR bit */
#define LPSDSR_BIT_NUMBER        POSITION_VAL(PWR_CR_LPDS)
#define CR_LPSDSR_BB             ((uint32_t)(PERIPH_BB_BASE + (PWR_CR_OFFSET_BB * 32) + (LPSDSR_BIT_NUMBER * 4)))
/* Alias word address of DBP bit */
#define DBP_BIT_NUMBER            POSITION_VAL(PWR_CR_DBP)
#define CR_DBP_BB                ((uint32_t)(PERIPH_BB_BASE + (PWR_CR_OFFSET_BB * 32) + (DBP_BIT_NUMBER * 4)))
/* Alias word address of PVDE bit */
#define PVDE_BIT_NUMBER           POSITION_VAL(PWR_CR_PVDE)
#define CR_PVDE_BB               ((uint32_t)(PERIPH_BB_BASE + (PWR_CR_OFFSET_BB * 32) + (PVDE_BIT_NUMBER * 4)))
/** @defgroup PWR_CSR_register_alias PWR CSR Register alias address
/* --- CSR Register ---*/
/* Alias word address of EWUP1 bit */
#define CSR_EWUP_BB(VAL)         ((uint32_t)(PERIPH_BB_BASE + (PWR_CSR_OFFSET_BB * 32) + (POSITION_VAL(VAL) * 4)))
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/** @defgroup PWR_Private_Functions PWR Private Functions
* brief   WFE cortex command overloaded for HAL_PWR_EnterSTOPMode usage only (see Workaround section)
static void PWR_OverloadWfe(void);
__NOINLINE
  __asm volatile( "wfe" );                // 这个地方提示报错
  __asm volatile( "nop" );               // 这个地方提示报错
废鱼 回答时间:2016-5-3 11:46:46
汇编指令,
WFI(Wait for interrupt)和WFE(Wait for event)是两个让ARM核进入low-power standby模式的指令,由ARM architecture定义,由ARM core实现。
NOP 就是空指令。
