帮忙看一下这段代码为啥不能点亮LED,求大神指导
从天而降小太阳 提问时间:2016-10-25 20:41 /
这是main程序
#include "stm32f10x.h"
#include "bsp_usart1.h"
#include "bsp_led.h"
int main(void)
        LED_GPIO_Config();
        USART1_Config();
        NVIC_Configuration();
  while(1)
                char ch;
                if(ch=='A')
                 LED1(ON);
                else if(ch=='B')
                 LED1(OFF);
这是bsp.usart.c程序
  * @brief  USART1 GPIO ÅäÖÃ,¹¤×÷ģʽÅäÖá£9600 8-N-1
  * @param  ÎÞ
  * @retval ÎÞ
void USART1_Config(void)
        /* config USART1 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
        /* USART1 GPIO config */
        /* Configure USART1 Tx (PA.09) as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        /* Configure USART1 Rx (PA.10) as input floating */
        /* USART1 mode config */
        USART_InitStructure.USART_BaudRate = 115200;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_Init(USART1, &USART_InitStructure);
        /* ʹÄÜ´®¿Ú1½ÓÊÕÖÐ¶Ï */
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
//        USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
        USART_Cmd(USART1, ENABLE);
/// ÅäÖÃUSART1½ÓÊÕÖжÏ
void NVIC_Configuration(void)
        /* Configure the NVIC Preemption Priority Bits */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        /* Enable the USARTy Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
ÖжϷþÎñ³ÌÐò
void USART1_IRQHandler(void)
        uint8_t ch;
        if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
                  ch = USART_ReceiveData(USART1);
                  printf( "\r\n%02x\r\n", ch );    //printf·¢ËÍ·½Ê½
                  USART_SendData(USART1,ch);         //32¿âº¯Êý·¢ËÍ·½Ê½
                  while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);
                  USART_ClearFlag(USART1,USART_FLAG_TC);
    ¿ÉÒÔ·¢ËÍÒ»¸ö×Ö·û´®
void USART1_Send_s(u8 *ch)
        while(*ch)
                USART_SendData(USART1,*ch);
/// ÖØ¶¨Ïòc¿âº¯Êýprintfµ½USART1
int fputc(int ch, FILE *f)
                /* ·¢ËÍÒ»¸ö×Ö½ÚÊý¾Ýµ½USART1 */
                USART_SendData(USART1, (uint8_t) ch);
                /* µÈ´ý·¢ËÍÍê±Ï */
                while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
                return (ch);
/// ÖØ¶¨Ïòc¿âº¯Êýscanfµ½USART1
int fgetc(FILE *f)
                /* µÈ´ý´®¿Ú1ÊäÈëÊý¾Ý */
                while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
                return (int)USART_ReceiveData(USART1);
本人菜鸟,求大神指导
收藏 1 评论34 发布时间:2016-10-25 20:41
34个回答
jinglixixi 最优答案 回答时间:2016-10-26 08:19:56
先在主函数分别测一下
LED1(ON);
LED1(OFF);
如果有效证明问题可能在通讯方面,否则有可能是引脚定义与LED的位置不符。
参与人数 1ST金币 +2 收起 理由
jinglixixi 回答时间:2016-10-28 08:03:35
就是在主函数中去掉与LED1无关的语句,再用LED1(ON);如果亮(也可能是LED1(OFF);视硬件的接法),则说明对LED1的控制是有效的,问题是处在其他方面。
没事逛荡 回答时间:2016-10-26 09:15:11
1,把NVIC_Configuration();放到初始化最前面。
2,没看到LED_GPIO_Config();,想来应该不会有问题;
3,把printf( "\r\n%02x\r\n", ch ); 放到LED(ON);和LED(OFF);至少可以确定通讯是否有问题。
参与人数 1ST金币 +2 收起 理由
从天而降小太阳 回答时间:2016-11-1 19:33:19
xhzheng 发表于 2016-10-28 10:37
ch定义局部变量,
串口接收,无法进行ch赋值;
我把ch改为全局变量了,灯亮了,但是进入死循环出不来,只有复位后发送B才能灭,否则一直亮着
guiren 回答时间:2016-10-25 23:04:45
学习一些
anywill 回答时间:2016-10-26 07:16:36
没看到LED1()定义;
车厘子 回答时间:2016-10-26 08:15:46
题主确定程序成功进中断了么 如果发数据的话
高二毛 回答时间:2016-10-26 08:49:35
楼上正解。另外看看系统时钟起来了嘛?
废鱼 回答时间:2016-10-26 09:46:05
ch临时变量,改为全局变量。
anobodykey 回答时间:2016-10-26 10:05:30
这能点亮才怪,主循环中ch又没有赋值,按你的思路楼上的回答是对的
zfz9232 回答时间:2016-10-26 13:16:07
我猜想,你是要根据串口接收到的数据来点亮LED灯,
那么第一,你应该先把串口的收和发的功能都实现;
第二步才来实现根据接收的数据实现对应的功能。
assssdz 回答时间:2016-10-26 13:17:48
cuyebiren 回答时间:2016-10-26 14:04:28
mian函数和USART中断里的ch变量不是同一个,改为全局变量,中断里不要重新定义
zhoupxa 回答时间:2016-10-26 14:54:58
低级错误
samhong 回答时间:2016-10-26 14:56:06
没有看到LED1()定义?ch赋的值?
wudianjun2001 回答时间:2016-10-26 15:24:55
CH弄个全局变量看看
123下一页
