| 本帖最后由 hpdell 于 2016-11-24 10:19 编辑 请教下,有谁使用过 usb3300 这个芯片 ??? 我现在在捣鼓这个芯片,发现 所有与这个芯片想连接的 Io 口的电平都为0,拔掉这个 usb3300 的模块 后,io口的电平都是高电平,想请教下 是不是我的这个 usb3300的模块有问题啊【在淘宝买的,目前就购买了一片】。 程序表现的现象如下: 挂载fatfs系统成功,但是要 f_open 函数时返回值为1,查看这个对应的返回值说明,是磁盘 IO 错误 /* File function return code (FRESULT) */ typedef enum { FR_OK = 0, /* (0) Succeeded */ FR_DISK_ERR, /* (1) A hard error occurred in the low level disk I/O layer */ FR_INT_ERR, /* (2) Assertion failed */ FR_NOT_READY, /* (3) The physical drive cannot work */ FR_NO_FILE, /* (4) Could not find the file */ FR_NO_PATH, /* (5) Could not find the path */ FR_INVALID_NAME, /* (6) The path name format is invalid */ FR_DENIED, /* (7) Access denied due to prohibited access or directory full */ FR_EXIST, /* (8) Access denied due to prohibited access */ FR_INVALID_OBJECT, /* (9) The file/directory object is invalid */ FR_WRITE_PROTECTED, /* (10) The physical drive is write protected */ FR_INVALID_DRIVE, /* (11) The logical drive number is invalid */ FR_NOT_ENABLED, /* (12) The volume has no work area */ FR_NO_FILESYSTEM, /* (13) There is no valid FAT volume */ FR_MKFS_ABORTED, /* (14) The f_mkfs() aborted due to any problem */ FR_TIMEOUT, /* (15) Could not get a grant to access the volume within defined period */ FR_LOCKED, /* (16) The operation is rejected according to the file sharing policy */ FR_NOT_ENOUGH_CORE, /* (17) LFN working buffer could not be allocated */ FR_TOO_MANY_OPEN_FILES, /* (18) Number of open files > _FS_LOCK */ FR_INVALID_PARAMETER /* (19) Given parameter is invalid */ } FRESULT; 上述是fatfs的返回值定义,fatfs版本v0.12b 硬件连接与官网的 stm32f769 eval 的原理图一样,
提示 usb 连接成功,但就是不能够读写操作 ,不知为何 ??? /** * @brief SOF callback. * @param hhcd: HCD handle * @retval None */ void HAL_HCD_SOF_Callback(HCD_HandleTypeDef *hhcd) // 程序会进入到这个函数里面来, { USBH_LL_IncTimer (hhcd->pData); // printf("USBH SOF Callback ... ... \r\n"); // } /** * @brief Connect callback 连接回调函数. * @param hhcd: HCD handle * @retval None */ void HAL_HCD_Connect_Callback(HCD_HandleTypeDef *hhcd) { USBH_LL_Connect(hhcd->pData); printf("USBH Connect Callback ... ... \r\n"); } /** * @brief Disconnect callback 断开回调函数. * @param hhcd: HCD handle * @retval None */ void HAL_HCD_Disconnect_Callback(HCD_HandleTypeDef *hhcd) { USBH_LL_Disconnect(hhcd->pData); printf("USBH Disconnect Callback ... ... \r\n"); } 程序源码如下:
stm32f777 v1.14-USB3300.part01.rar
(5 MB, 下载次数: 574)
已经搞定了,是我吧usb3300的速度设置为480bps造成的,改成 12bps就可以了,估计是我的sd卡的速度更不上造成读写错误
没有使用过 otg,具体不知道啊
http://www.mbdcore.com/forum.php ... d=142&fromuid=1
(出处: 基于模型设计论坛)
(出处: 基于模型设计论坛)
