stm32l151 低功耗设置的问题
伤花怒放2003 提问时间:2017-7-8 13:17 /
各位高手:
    现在在使用stm32l151的stop模式,进入休眠后测量电流有1.8mA,比参考值大很多,进入休眠已将所有所有IO口配置成模拟,并且关闭了IO口时钟,串口时钟,定时器时钟,不知道还有什么地方设置的不对,请各位高手指点!!!
收藏 3 评论67 发布时间:2017-7-8 13:17
67个回答
zhao.zhao 回答时间:2017-7-19 10:46:14
// 恢复设置 USART1 的引脚功能
void  USART1_GPIO_Func_Set(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_USART1_CLK_ENABLE();
    /**USART1 GPIO Configuration
    PA9     ------> USART1_TX
    PA10     ------> USART1_RX
    GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
// 恢复设置 USART2 的引脚功能
void  USART2_GPIO_Func_Set(void)
    __HAL_RCC_USART2_CLK_ENABLE();
//    PA2     ------> USART2_TX
//    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
// 恢复设置 USART3 的引脚功能
void  USART3_GPIO_Func_Set(void)
    __HAL_RCC_GPIOB_CLK_ENABLE();
  /* USER CODE END USART3_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_USART3_CLK_ENABLE();
    /**USART3 GPIO Configuration
    PB10     ------> USART3_TX
    PB11     ------> USART3_RX
    GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_11;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
zhao.zhao 回答时间:2017-7-24 20:32:01
只要相对应的引脚设为下降沿中断,没用到的引脚设为模拟输入。
void MX_GPIO_Anialog_All(void)
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|
                        GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|
                        GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Pin  = GPIO_PIN_All;
  GPIO_InitStruct.Pin  =  GPIO_PIN_0 | GPIO_PIN_1  | GPIO_PIN_2  | GPIO_PIN_3  | GPIO_PIN_4| \
                          GPIO_PIN_5 | GPIO_PIN_6  | GPIO_PIN_7  | GPIO_PIN_8  | GPIO_PIN_9| \
                         GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  GPIO_InitStruct.Pin  = GPIO_PIN_2;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : PH0 PH1 */
  GPIO_InitStruct.Pin  = GPIO_PIN_0|GPIO_PIN_1;
  HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
    __HAL_RCC_GPIOH_CLK_DISABLE();
  /*Configure GPIO pin : PC13 */
  GPIO_InitStruct.Pin = GPIO_PIN_13;  // 接 唤醒1
  GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin  = GPIO_PIN_0;  // 接 唤醒2
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING_FALLING;
其他引脚的初始化在这个函数的后面完成
中断优先级设置函数
static void MX_NVIC_Init(void)
  /* RTC_WKUP_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(RTC_WKUP_IRQn, 5, 0);
  HAL_NVIC_EnableIRQ(RTC_WKUP_IRQn);
  /* EXTI0_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(EXTI0_IRQn, 7, 0);
  HAL_NVIC_EnableIRQ(EXTI0_IRQn);
  /* USART1_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(USART1_IRQn, 1, 0);
  HAL_NVIC_EnableIRQ(USART1_IRQn);
  /* USART2_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(USART2_IRQn, 3, 0);
  HAL_NVIC_EnableIRQ(USART2_IRQn);
  /* USART3_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(USART3_IRQn, 3, 0);
  HAL_NVIC_EnableIRQ(USART3_IRQn);
  /* EXTI15_10_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(EXTI15_10_IRQn, 7, 0);
  HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
  /* TIM6_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(TIM6_IRQn, 6, 0);
  HAL_NVIC_EnableIRQ(TIM6_IRQn);
// 外部引脚中断回调函数
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
  if(GPIO_Pin == GPIO_PIN_13)   // 中断由GPIO_PIN_13触发 PC13引脚
      Wkup_Flag1 = TRUE;           // 谁唤醒的标志位1
  else if(GPIO_Pin == GPIO_PIN_0)  // 中断由GPIO_PIN_0触发,PA0引脚
      Wkup_Flag2 = TRUE;           // 谁唤醒的标志位2
在main.c的while(1)循环中加入这2个中断判断标识就可以恢复正常运行了
zhao.zhao 回答时间:2017-7-8 15:36:26
你去找我的帖子,有个RTC.ZIP的文件,应该符合你的要求,包括芯片都是一样的。
伤花怒放2003 回答时间:2017-7-8 15:56:33
zhao.zhao 发表于 2017-7-8 15:36
你去找我的帖子,有个RTC.ZIP的文件,应该符合你的要求,包括芯片都是一样的。 ...
是这篇帖子吗?“STM32L151进入低功耗,并由RTC唤醒的故事”
zhao.zhao 回答时间:2017-7-8 17:15:27
是的,不过这个没有工程文件的,你找端午节的的那个帖子里的一个附件
伤花怒放2003 回答时间:2017-7-10 09:24:02
没找到
伤花怒放2003 回答时间:2017-7-10 09:35:07
还有,我现在MCU用的是外接的8M晶体,RTC也用的32.768K的外接晶体,这些会对休眠后的功耗有影响吗?
废鱼 回答时间:2017-7-10 14:13:06
STOP模式,要对IO进行配置,关闭不需要的外设。可以先用STANDBY模式测试功耗是否满足标准值。
zhao.zhao 回答时间:2017-7-10 14:35:17
影响不大
zhao.zhao 回答时间:2017-7-10 14:38:43
先把外接引脚处理好,最好设成模拟输入模式,如果实在不行,设成开漏输出也行,尽量减少外部电路不必要的电流泄露,然后进入STOP模式
伤花怒放2003 回答时间:2017-7-11 13:33:09
zhao.zhao 发表于 2017-7-10 14:38
先把外接引脚处理好,最好设成模拟输入模式,如果实在不行,设成开漏输出也行,尽量减少外部电路不必要的电 ...
我已把所有IO设成模拟输入了,功耗有800微安。是不是要根据IO口的使用情况进行配置,不能简单的全部设为模拟?
zhao.zhao 回答时间:2017-7-12 17:52:02
是的,低功耗时,外部电路的一点泄露,会造成功耗降不下来的
伤花怒放2003 回答时间:2017-7-13 15:53:47
我现在的IO口使用情况是这样:
PA1、PA2用于两路AD采集;
PA9、PA10用于UART1;
PB10、PB11用于UART3;
PA13、PA14、PA15、PB3用于JTAG;
还有几个IO配置为输出,剩余的没有用悬空。
进入STOP模式前,我将它们都配为模拟输入了,效果不好,上述这些用到的脚休眠前应该怎么配置比较好?
zhao.zhao 回答时间:2017-7-13 20:21:56
JTAG引脚不能设为模拟输入的,程序下载后,把JTAG接口拔掉,再上电测电流。
waiman 回答时间:2017-7-13 21:38:42
测试低功耗:
第一,没用的IO最好能固定电平,若悬空没用的,可以设置成慢速输出低电平。
第二,SPI ,串口,ADC等功能,先停止时钟,再关闭功能。
第三,进入STOP模式前,可以先用一些不注意的功能,例如比较器,PVD,VREFin,调试端口(SWD,JTAG)
第四,测试芯片功耗,最好单独测试,把外部芯片(包括LDO)、串口、调试接口的连接都断开。
zhao.zhao 回答时间:2017-7-14 08:12:59
第一个,没用到的IO口悬空,但是不要设成低电平输出,ST推荐模拟输入;
第二个,不要关闭时钟,也不要关闭功能,仅把IO引脚设成模拟输入就可以了;
第三第四好像没问题
12345下一页
关于意法半导体
招聘信息
