stm32f103串口3的接收中断进不去
攻城狮小黄 提问时间:2017-9-23 09:20 /
以下是我的串口3的初始化程序和中断程序,大神们请帮小弟看看,问题出在哪儿了,不胜感激
void USART3_Init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        NVIC_InitTypeDef  NVIC_InitStructure;
        /* config USART3 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
        /* USART3 GPIO config */
        /* Configure USART3 Tx (PB.10) as alternate function push-pull */
        /* Configure USART3 Rx (PB.11) as input floating */
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_11;
        /* USART3 mode config */
        USART_InitStructure.USART_BaudRate =9600;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_Init(USART3, &USART_InitStructure);
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
        USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
        USART_Cmd(USART3, ENABLE);
void USART3_IRQHandler(void)
  if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    RXBuffer[RXCounter++] = (USART_ReceiveData(USART3) & 0x7F);
    /* Clear the USART1 Receive interrupt */
    USART_ClearITPendingBit(USART3, USART_IT_RXNE);
    if(RXCounter == 100)
      /* Disable the USART Receive interrupt */
      USART_ITConfig(USART3, USART_IT_RXNE, DISABLE);
赞 收藏 评论5 发布时间:2017-9-23 09:20
5个回答
MrJiu 回答时间:2017-9-23 09:43:17
标准库?上HAL,一键化配置!!!!
anobodykey 回答时间:2017-9-23 09:48:00
可以看看能不能输出,确定外设是好的
斜阳 回答时间:2017-9-23 10:00:35
推荐CubeMX配置工程。方便快捷
参与人数 1ST金币 +2 收起 理由
攻城狮小黄 回答时间:2017-9-23 16:54:47
anobodykey 发表于 2017-9-23 09:48
可以看看能不能输出,确定外设是好的
输出没有问题
YY777 回答时间:2023-12-6 18:20:49
大佬想问下怎么解决的呀?
