各位,用STM32L051单片机做从机接收其他模块的数据,使用寄存器操作,为什么IIC中断只能进一次,大家帮看下,谢谢。 /** * Brief This function configures I2C1, slave. * Param None * Retval None */ void Configure_I2C1_Slave(void) { /* Configure RCC for I2C1 */ /* (1) Enable the peripheral clock I2C1 */ /* (2) Use APBCLK for I2C CLK */ RCC->APB1ENR |= RCC_APB1ENR_I2C1EN; /* (1) */ RCC->CCIPR &= ~RCC_CCIPR_I2C1SEL; /* (2) */ /* Configure I2C1, slave */ /* (3) Timing register value is computed with the AN4235 xls file, fast Mode @400kHz with I2CCLK = 16MHz, rise time = 100ns, fall time = 10ns */ /* (4) Periph enable, address match interrupt enable, receive interrupt enable */ /* (5) 7-bit address = 0x5A */ /* (6) Enable own address 1 */ I2C1->TIMINGR = (unsigned int)0x00300619; /* (3) */ I2C1->CR1 = I2C_CR1_PE | I2C_CR1_RXIE | I2C_CR1_ADDRIE; /* (4) */ I2C1->OAR1 |= (unsigned int)(I2C1_OWN_ADDRESS << 1); /* (5) */ I2C1->OAR1 |= I2C_OAR1_OA1EN; /* (6) */ /* Configure IT */ /* (7) Set priority for I2C1_IRQn */ /* (8) Enable I2C1_IRQn */ NVIC_SetPriority(I2C1_IRQn, 0); /* (7) */ NVIC_EnableIRQ(I2C1_IRQn); /* (8) */ } /** * Brief This function handles I2C1 interrupt request. * Param None * Retval None */ void I2C1_IRQHandler(void) { unsigned int I2C_InterruptStatus = I2C1->ISR; /* Get interrupt status */ if((I2C_InterruptStatus & I2C_ISR_ADDR) == I2C_ISR_ADDR) { I2C1->ICR |= I2C_ICR_ADDRCF; /* Address match event */ } else if((I2C_InterruptStatus & I2C_ISR_RXNE) == I2C_ISR_RXNE) { /* Read receive register, will clear RXNE flag */ CLearLinkErrorCnt(); if(iicRecDataFlag == FALSE) { iicRecBuf[iicRecBufIndex] = I2C1->RXDR; iicRecBufIndex++; if(iicRecBufIndex == IICWINFOLEN) { iicRecDataFlag = TRUE; iicRecBufIndex = 0; } } } else { error = ERROR_I2C; /* Report an error */ NVIC_DisableIRQ(I2C1_IRQn); /* Disable I2C1_IRQn */ } } |
http://blog.sina.com.cn/s/blog_59bab09f0101s6m6.html
的作用不太了解。你是想用这个语句去触发什么吗?
但感觉问题出在else if这个块里面。
建议你设置断点看一看是不是handler程序进入这里出的问题。
如果是,建议你看看这里面
做了事情,而如果不是是不是也要做一些事情。
抱歉,瞄了一眼真没看懂
