STM8-2路ADC控制2个LED灯PWM调光问题?
zhangli-li 提问时间:2017-11-16 21:24 /
学习用stm8做个2路ADC电位器调节2个LED灯pwm调光的程序,屏蔽程序里任何一路ADC另一路是可以调节LED光的,2路一起用就不能正常调光了,请兄弟们帮忙看看是哪里出了问题呢?谢谢
/*2个电位器分别PWM调节2个LED*/
#include<iostm8s103f3.h>
unsigned char x;
unsigned int ADCData;
unsigned int PWM1;
unsigned int PWM2;
void PORTInit()             //PWM输出端口设置
  PC_DDR_bit.DDR3 = 1;      //set out
  PC_CR1_bit.C13 = 1;       //推挽输出
  PC_CR2_bit.C23 = 0;       //输出速度
  PD_DDR_bit.DDR2 = 1;      //set out
  PD_CR1_bit.C12 = 1;       //PD_CR1 |= 0x0d;
  PD_CR2_bit.C22 = 0;
**函数名称:void TIM1_PWM_Init()
**功能描述:定时器1 PWM初始化
**入口参数:无
**输出:无
  TIM1_CR1_bit.CEN = 0;       //停止计数
  TIM1_BKR_bit.MOE = 1;
  TIM1_CCMR3_bit.OC3M = 7;    //PWM2 MODEL
  TIM1_CCMR3_bit.OC3PE = 1;
  TIM1_CCER2_bit.CC3E = 1;    //output enable
  TIM1_CCER2_bit.CC3P = 1;    //OC1 hi
  TIM1_PSCRH =  0x00;         //16MHZ/
  TIM1_PSCRL =  0x00;
  TIM1_ARRH =  1000 / 256;
  TIM1_ARRL =  1000 % 256;
  TIM1_CCR3H = 0x00;            //50%
  TIM1_CCR3L  = 0x00;
  TIM1_CR1 = 0x01;
**函数名称:void TIM2_PWM_Init()
**功能描述:定时器2PWM初始化
**入口参数:无
**输出:无
  TIM2_CR1_bit.CEN = 0;       //禁能定时器2
  TIM2_CCMR3_bit.OC3M = 7;    //定时器通道3 PWM模式 PWM2 MODEL
  TIM2_CCMR3_bit.OC3PE = 1;   //输出比1预装载使能
  TIM2_CCER2_bit.CC3E = 1;    //定时器2通道3设置为输出
  TIM2_CCER2_bit.CC3P = 1;    //定时器2通道3为低电平为有效电平
  TIM2_PSCR_bit.PSC = 0;     //设置预分频
  TIM2_ARRH =  1000 / 256;
  TIM2_ARRL =  1000 % 256;
  TIM2_CCR3H = 0x00;          //50%
  TIM2_CCR3L  = 0x00;
  TIM2_CR1 = 0x01;
**函数名称:void ADC_Init()
**功能描述:初始化ADC
**入口参数:无
**输出:无
void ADC_Init()
  PC_DDR_bit.DDR4 = 0;   //设置PC->4 为输入
  PC_CR1_bit.C14 = 0;    //设置为悬空输入
  PC_CR2_bit.C24 = 0;    //设置中断禁止
  PD_DDR_bit.DDR3 = 0;   //设置PD->3 为输入
  PD_CR1_bit.C13 = 0;    //设置为悬空输入
  PD_CR2_bit.C23 = 0;    //设置中断禁止
  ADC_CR1_bit.SPSEL = 1;    //fmaster / 3 = 16MHZ / 3 = 5.333MHZ
  ADC_CR2_bit.ALIGN = 1;    //RIGHT ALIGN
  ADC_CR1_bit.ADON = 1;     //启动ADC
**函数名称:void ADC_Data_Read(unsigned int *AD_Value)
**功能描述:读取ADC完成一次模数转换结果
**入口参数:unsigned int *AD_Value
            *AD_Value ->读取ADC采样数据的指针
**输出:无
  ADC_CSR_bit.CH = x;       //选择通道
  while(ADC_CSR_bit.EOC == 0);  //等待转换结束
  *AD_Value = ADC_DRH;          //先读取高8位
  *AD_Value = (unsigned int)((*AD_Value << 8) + ADC_DRL);   //高8位与低8位相加,凑成16位数据
/*    主函数    */
int main(void)
  CLK_CKDIVR = 0x00;      //CPUDIV = 1 HSIDIV = 1  内部时钟 = 16Mhz
  PORTInit();
  TIM1_PWM_Init();
  TIM2_PWM_Init();
  ADC_Init();             //调用ADC初始化函数
  while(1)
      x = 2;
      ADC_Data_Read(&ADCData);              //读取ADC的采样数值
      PWM1=ADCData;
      TIM1_CCR3H = PWM1 / 256;
      TIM1_CCR3L  = PWM1 % 256;
      x = 4;
      PWM2=ADCData;
      TIM2_CCR3H = PWM2 / 256;
      TIM2_CCR3L  = PWM2 % 256;
收藏 评论4 发布时间:2017-11-16 21:24
4个回答
zhux 回答时间:2017-12-22 12:27:15
想通过一个脚的ADC值达到一定值 就控制一个LED灯亮怎么写程序,小白一个,还请指导。谢谢各位!
点评
有什么问题可以单独发帖求助~  发表于 2018-3-31 14:32
zhux 回答时间:2017-12-22 12:32:34
是用STM32F103C8T6 的芯片
荒废0 回答时间:2018-4-16 21:23:46
看看
参与人数 1ST金币 -1 收起 理由
zero99 -1 求助帖禁止灌水
