STM32Cube创建工程时钟问题
zhjb1 提问时间:2018-1-2 15:53 /
问题如题。在STM32CubeMX中创建了一个工程,选设了GPIO——开发板上的3个LED分别连接在PC7、PB7、PB14上因此选设这3个口,并分别命名为LED1,LED2,LED3;在Cube中时钟的设置只有HSI RC的显示为正常色,LSE、HSE都显示为灰色的不可选状态,因此选择前者。一切设置好生成工程后在IAR下编译下载都正常,但LED没有闪烁,程序运行后好像时钟不计数一样——永远在初始态,因为采用的是HSI RC内部振荡器,无法用示波器查看,请问是什么原因?在while(1)中:
HAL_GPIO_WritePin(GPIOC,LED1_Pin,GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOB,LED2_Pin,GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOB,LED3_Pin,GPIO_PIN_SET);
HAL_Delay(5000);
HAL_GPIO_WritePin(GPIOC,LED1_Pin,GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOB,LED2_Pin,GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOB,LED3_Pin,GPIO_PIN_RESET);
HAL_Delay(5000);
结果是LED 亮以后永远不灭了——没有闪烁!
先谢谢了
参与人数 1 ST金币 -5 收起 理由
Inc_brza -5
赞 收藏 评论11 发布时间:2018-1-2 15:53
11个回答
netlhx 回答时间:2018-1-2 16:35:16
我要看时钟初始化代码,看跟我碰到的问题是不是一样的
zhjb1 回答时间:2018-1-2 16:54:58
//System Clock Configuration
void SystemClock_Config(void){
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
//Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK){
    _Error_Handler(__FILE__, __LINE__);
//Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK){
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK){
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_LPUART1|RCC_PERIPHCLK_I2C1|RCC_PERIPHCLK_ADC;
  PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_SYSCLK;
  PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
  PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_SYSCLK;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK){
//Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
//SysTick_IRQn interrupt configuration
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
以上是初始化的代码,谢谢
实际上我开了2路ADC、2路PWM、1路Time、额外的PD7~PD3 GPIO OUT,以及1个PE2的GPIO IN。
netlhx 回答时间:2018-1-2 19:33:07
  RCC_OscInitTypeDef RCC_OscInitStruct; ...
你这个直接用的HSI,没有使用PLL,跟咱的情况不一样哈。试着DEBUG一下,看看能不能找到问题
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
zhjb1 回答时间:2018-1-2 21:24:15
netlhx 发表于 2018-1-2 19:33
你这个直接用的HSI,没有使用PLL,跟咱的情况不一样哈。试着DEBUG一下,看看能不能找到问题 ...
没有问题,可以加上PLL,反正都是Cube自动生成的。完后拷贝上来给你,谢谢
zhjb1 回答时间:2018-1-2 21:32:46
zhjb1 发表于 2018-1-2 21:24
没有问题,可以加上PLL,反正都是Cube自动生成的。完后拷贝上来给你,谢谢 ...
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLN = 8;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
  PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLLSAI1;
  PeriphClkInit.PLLSAI1.PLLSAI1Source = RCC_PLLSOURCE_HSI;
  PeriphClkInit.PLLSAI1.PLLSAI1M = 2;
  PeriphClkInit.PLLSAI1.PLLSAI1N = 32;
  PeriphClkInit.PLLSAI1.PLLSAI1P = RCC_PLLP_DIV2;
  PeriphClkInit.PLLSAI1.PLLSAI1Q = RCC_PLLQ_DIV2;
  PeriphClkInit.PLLSAI1.PLLSAI1R = RCC_PLLR_DIV4;
  PeriphClkInit.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_ADC1CLK;
Inc_brza 回答时间:2018-1-3 09:06:07
标题不合格,请尽快修改标题
中山无雪 回答时间:2018-2-7 13:39:54
开GPIO的时钟了吗?
参与人数 1蝴蝶豆 +1 收起 理由
zero99 + 1
zhjb1 回答时间:2018-2-7 14:01:14
中山无雪 发表于 2018-2-7 13:39
开GPIO的时钟了吗?
在CUBE中设置了GPIO和时钟树直接可以看到打开了 GPIO时钟。为了简化问题,已用ARMmbed工程绕开后续问题,谢谢。
Mr.Luav 回答时间:2018-2-7 14:41:21
不是  楼主开RCC的外部时钟了吗? 要选择HSE 那一栏的最后一个  晶振  才算打开
还有生成的代码是没有  √  RESET and RUN  这一项的  你得复位一下  代码才开始跑
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
中山无雪 回答时间:2018-2-8 19:10:38
zhjb1 发表于 2018-2-7 14:01
在CUBE中设置了GPIO和时钟树直接可以看到打开了 GPIO时钟。为了简化问题,已用ARMmbed工程绕开后续问题, ...
查一下代码中是否有
__HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
这样的打开时钟的语句,这是打开GPIO时钟的函数
也不排除Cube生产的代码有Bug导致运行不正常的问题,我就曾发现过几个,还有就是看看《勘误表》是不是有什麽特别的说明
zhjb1 回答时间:2018-2-9 09:04:50
中山无雪 发表于 2018-2-8 19:10
查一下代码中是否有
谢谢
