STM32F103VB VBAT的问题
【MCU实战经验】+基于STM32F103RBT6无线温度控制系统
STM32F105 USB HID RCC設定
STM32F103VCT6单片机的复位引脚和地引脚短路
【官方例程】STM32F107以太网官方例程
【MCU实战经验】基于STM32F103C8T6的hart总线调试器设计
求教STM32F103进入STOP模式后用外部中断唤醒的问题
基于STM32F103RCT6的无源蜂鸣器音乐播放(生日快乐歌)
STM32F103c8t6有没有DAC 功能?
STM32F103x中文数据手册
这样做:
Tim4_Init(void)
{ GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_ICInitTypeDef TIM_ICInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOB,&GPIO_InitStructure); //Max17830 Alarm
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);
TIM_TimeBaseStructure.TIM_Prescaler = 71;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_Period = 49999;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
TIM_ICInitStructure.TIM_Channel = TIM_Channel_4; //选择输入端 IC4映射到TI4上
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_BothEdge; //上升沿下降沿都捕获
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI4上
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;//配置输入分频,不分频
TIM_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置输入滤波器 不滤波
TIM_ICInit(TIM4, &TIM_ICInitStructure);
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
TIM_ITConfig(TIM4,TIM_IT_CC4,ENABLE);//允许CC4IE捕获中断
TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);//允许更新中断
TIM_ClearITPendingBit(TIM4,TIM_IT_CC4);
TIM_ClearITPendingBit(TIM4,TIM_IT_Update);
TIM_Cmd(TIM4,ENABLE);
中断函数
void TIM4_IRQHandler(void)
if(TIM_GetITStatus(TIM4,TIM_IT_CC4) != RESET)
TIM_SetCounter(TIM4,0);
if (TIM_GetITStatus(TIM4,TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM4,TIM_IT_Update); //清除TIMx的中断待处理位:TIM 中断源
main函数里判断
if(TIM_GetCounter(TIM4) >= 32) // (1/16.384KHz)/2= 30.517578125us
AlarmFlag = 1; // 故障标志
上升沿和下降沿都清零计数器,只要计数器大于32即认为有故障。但开启了溢出中断的话(TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE)),会频繁导致看门狗复位。
怎么想的呀,高电平故障不是吗,那就是上升沿开始计数,下降沿复位计数,你可以设置超时中断,只要不超时(16.384Khz的半周期很容易算出来),所以只要超时了不就是有故障了吗,不过频繁中断会对cpu的消耗很大,所以要根据应用场景来看是否需要这么严格,从而设计一个比较宽裕的条件!
最靠谱和比较渐变的方法就是统计脉冲数呀,例如按照你16.384Khz,1s有多少个脉冲数是固定的呀,加入允许点误差,就前后加一点点,如果出现了故障,最后的脉冲数肯定不会是你定义的正常的脉冲数呀.
中断太频繁了,对你的系统压力太大~
你用脉冲数统计法吧,这样得话你只需要格一段时间去轮询脉冲数就行了,记住溢出的时候也要处理一下(复位一下继续统计)
其实楼主可以设置1个外部上下沿中断,下降沿中断计数值加1,上升沿中断如果超时下降沿中断未到来就读取当前计数值即可。
详细点
楼主在问题中的表达我的理解是楼主想对16.384KHz的时钟进行计数,这样可以用GPIO的外部中断,下降沿到来时触发外部中断,计数器加1.
之前在群里有说过这个问题,提出的解决方案如下:
1、采用输入捕获脉冲数,对一段时间内进行统计,如果数量不够,说明这段时间出现故障
2、采用上升沿计时,下降沿停止统计时间的方式实时监测出故障
不用外部中断 就用Tim4 可以做到吗?
不用外部中断,就用TIM4 可以做到吗?
输入捕获,不需要外部中断吧!
我还是没弄明白你是要同步定时器还是要对外部脉冲进行计数?
用Tim4 输入捕获,当捕捉到上升沿就清零计数器, 当计数器值大于30.当计数器大于30.5us时(16.384KHz的半个周期时间)就认为有故障 ?
都可以啊,上面不是说了吗
