STM32F103计时器TIM1不准
liweizhang 提问时间:2018-5-16 17:00 /
大家好!
我今天想用STM32F103C8T6的TIM1作为1KHz定时器,但是,注意到该定时器的中断频率不正确。请大家帮助一下啊,先谢谢啦
代码如下:
#include "TIM1.h"
* 函数名:TIM1_Mode_Config
* 描述  :TIM1 输出PWM信号初始化,只要调用这个函数
* 输入  :无
* 输出  :无
* 调用  :外部调用
void TIM1_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        NVIC_TIM1_Configuration();
//        TIM1_GPIO_Config();
void NVIC_TIM1_Configuration(void)
        //打开TIM1的全局中断,在中断中判断是更新中断还是捕捉中断
        /* Enable the TIM1 global Interrupt */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 4;
* 函数名:TIM1_GPIO_Config
* 描述  :配置TIM1复用输出PWM时用到的I/O
* 输入  :无
* 输出  :无
* 调用  :内部调用
void TIM1_GPIO_Config(void)
        GPIO_StructInit(&GPIO_InitStructure);
        /*转速输入,捕捉输入模式 用PA0配置成 */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
                //转速输入,捕捉输入模式 用PA0配置成
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
        GPIO_Init(GPIOB, &GPIO_InitStructure);*/
//转速输入捕捉,
void TIM1_Configuration(void)
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_ICInitTypeDef  TIM_ICInitStructure;
//TIM_ICInitTypeDef  TIM_ICInitStructure;
/* Time Base configuration */
TIM_DeInit(TIM1);
TIM_TimeBaseStructure.TIM_Prescaler = 7200-1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_Period = 10000-1;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
//TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/*        TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
        TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
        TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
        TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
        TIM_ICInitStructure.TIM_ICFilter = 0;
        TIM_ICInit(TIM1, &TIM_ICInitStructure);
//         TIM_TIxExternalClockConfig(TIM1,TIM_TIxExternalCLK1Source_TI1,TIM_ICPolarity_Rising,0);//设置为外部输入
        //TIM_ETRClockMode2Config(TIM1, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
//         TIM_SetCounter(TIM1, 0);   // 清零计数器CNT
        TIM_ClearFlag(TIM1, TIM_FLAG_Update);        /* 清除溢出中断标志 */
        TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
        //TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM1, ENABLE);                    // 使能TIM4重载寄存器ARR
        TIM_Cmd(TIM1,ENABLE);//使能计数
void TIM1_Configuration1(void) //??????????
           //??TIMER1?????
        TIM_DeInit(TIM1);
           TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
        TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); // Time base configuration
        TIM_Cmd(TIM1, ENABLE);
赞 收藏 评论8 发布时间:2018-5-16 17:00
8个回答
GKoSon 回答时间:2018-5-16 17:09:08
72MHZ的话
7200-1----10000-1----->1HZ
7200-1----10-1--------->1000HZ
TIM_TimeBaseStructure.TIM_Period = 10-1;
参与人数 1蝴蝶豆 +3 收起 理由
zero99 + 3
七哥 回答时间:2018-5-16 18:08:20
请先跑几个标准库的程序。
“STM32F10x_StdPeriph_Lib_V3.1.2\Project\STM32F10x_StdPeriph_Examples\TIM\TimeBase”
你的程序不全。
feixiang20 回答时间:2018-5-17 00:21:42
查看了类似疑问,不知道是不是临界代码的问题
liweizhang 回答时间:2018-5-17 08:12:39
非常感谢大家的帮助
liweizhang 回答时间:2018-5-17 09:15:58
与龙共舞 发表于 2018-5-16 17:09
72MHZ的话
按照上述的参数修改了,计时时间仍然不是1000hz,是不是时钟那里设置有问题呢?
yklstudent 回答时间:2018-5-17 09:19:10
那就先确认系统时钟
xiaoqin2046 回答时间:2018-5-17 09:39:44
学习了
参与人数 1ST金币 -1 收起 理由
zero99 -1 灌水处罚
五哥1 回答时间:2018-5-31 18:37:34
这几个函数都没有错,你的TIM的调用程序?要不你用CUBE快速生成一个测试程序看看。
