STM32F767 FLASH改成双BANK模式 keil烧写异常
123-356510 提问时间:2018-6-28 10:15 /
悬赏8ST金币未解决
本来F767FLASH默认单BANK模式, 后来用STLINK工具将flash的选项字改为双bank模式在单bank模式下,keil5烧写程序都正常
但是在双bank模式下,发生异常,没法正常烧写,感觉像是擦除失败了,因为我用stlink工具手动擦除一下,就能用keil正常烧写,但是每次改了程序,都要手动擦除一下,比较麻烦
个人感觉keil还是在用单bank的模式擦除,所以造成这个问题,但不知到怎么修改配置,不知道感觉对不对
我的keil配置
烧写异常问题
Load "..\\OBJ\\UART.axf"
Erase Done.
Programming Done.
Contents mismatch at: 0800C001H  (Flash=E5H  Required=F5H) !
Contents mismatch at: 0800C002H  (Flash=00H  Required=80H) !
Contents mismatch at: 0800C003H  (Flash=00H  Required=50H) !
Contents mismatch at: 0800C004H  (Flash=80H  Required=81H) !
Contents mismatch at: 0800C005H  (Flash=00H  Required=60H) !
Contents mismatch at: 0800C006H  (Flash=00H  Required=40H) !
Contents mismatch at: 0800C007H  (Flash=00H  Required=46H) !
Contents mismatch at: 0800C009H  (Flash=00H  Required=E7H) !
Contents mismatch at: 0800C00CH  (Flash=20H  Required=64H) !
Contents mismatch at: 0800C00DH  (Flash=00H  Required=06H) !
Contents mismatch at: 0800C010H  (Flash=2CH  Required=2DH) !
Contents mismatch at: 0800C011H  (Flash=28H  Required=E9H) !
Contents mismatch at: 0800C012H  (Flash=58H  Required=F8H) !
Contents mismatch at: 0800C013H  (Flash=4CH  Required=4FH) !
Contents mismatch at: 0800C014H  (Flash=03H  Required=8BH) !
Contents mismatch at: 0800C015H  (Flash=40H  Required=46H) !
Contents mismatch at: 0800C016H  (Flash=10H  Required=37H) !
Contents mismatch at: 0800C018H  (Flash=40H  Required=C0H) !
Contents mismatch at: 0800C019H  (Flash=62H  Required=6AH) !
Contents mismatch at: 0800C01AH  (Flash=00H  Required=80H) !
Contents mismatch at: 0800C01BH  (Flash=60H  Required=68H) !
Contents mismatch at: 0800C01DH  (Flash=10H  Required=90H) !
Contents mismatch at: 0800C01EH  (Flash=0EH  Required=4FH) !
Contents mismatch at: 0800C01FH  (Flash=30H  Required=F0H) !
Contents mismatch at: 0800C021H  (Flash=01H  Required=09H) !
Contents mismatch at: 0800C023H  (Flash=20H  Required=24H) !
Contents mismatch at: 0800C025H  (Flash=22H  Required=26H) !
Contents mismatch at: 0800C026H  (Flash=00H  Required=A2H) !
Contents mismatch at: 0800C027H  (Flash=42H  Required=46H) !
Contents mismatch at: 0800C028H  (Flash=22H  Required=32H) !
Contents mismatch at: 0800C029H  (Flash=40H  Required=48H) !
Contents mismatch at: 0800C02AH  (Flash=40H  Required=D0H) !
Contents mismatch at: 0800C02BH  (Flash=58H  Required=F8H) !
Contents mismatch at: 0800C02DH  (Flash=00H  Required=80H) !
Contents mismatch at: 0800C02FH  (Flash=2EH  Required=BFH) !
Contents mismatch at: 0800C030H  (Flash=41H  Required=5DH) !
Contents mismatch at: 0800C031H  (Flash=00H  Required=46H) !
Contents mismatch at: 0800C032H  (Flash=00H  Required=3FH) !
Contents mismatch at: 0800C033H  (Flash=00H  Required=E0H) !
Contents mismatch at: 0800C034H  (Flash=48H  Required=D8H) !
Contents mismatch at: 0800C035H  (Flash=60H  Required=F8H) !
Contents mismatch at: 0800C039H  (Flash=60H  Required=F0H) !
Contents mismatch at: 0800C03CH  (Flash=00H  Required=10H) !
Contents mismatch at: 0800C03DH  (Flash=21H  Required=B1H) !
Contents mismatch at: 0800C03EH  (Flash=2AH  Required=6FH) !
Contents mismatch at: 0800C03FH  (Flash=20H  Required=F0H) !
Contents mismatch at: 0800C040H  (Flash=01H  Required=07H) !
Contents mismatch at: 0800C041H  (Flash=04H  Required=07H) !
Contents mismatch at: 0800C042H  (Flash=26H  Required=3FH) !
Contents mismatch at: 0800C043H  (Flash=60H  Required=E0H) !
Contents mismatch at: 0800C044H  (Flash=64H  Required=6EH) !
Contents mismatch at: 0800C045H  (Flash=01H  Required=89H) !
Contents mismatch at: 0800C046H  (Flash=0DH  Required=4FH) !
Contents mismatch at: 0800C047H  (Flash=30H  Required=F0H) !
Contents mismatch at: 0800C049H  (Flash=02H  Required=0AH) !
Contents mismatch at: 0800C04AH  (Flash=21H  Required=23H) !
Contents mismatch at: 0800C04BH  (Flash=60H  Required=E0H) !
Contents mismatch at: 0800C04CH  (Flash=00H  Required=40H) !
Contents mismatch at: 0800C04DH  (Flash=00H  Required=F2H) !
Contents mismatch at: 0800C04EH  (Flash=00H  Required=F4H) !
Contents mismatch at: 0800C04FH  (Flash=00H  Required=53H) !
Contents mismatch at: 0800C050H  (Flash=00H  Required=1AH) !
Contents mismatch at: 0800C051H  (Flash=13H  Required=1BH) !
Contents mismatch at: 0800C052H  (Flash=63H  Required=6BH) !
Contents mismatch at: 0800C053H  (Flash=60H  Required=68H) !
Contents mismatch at: 0800C054H  (Flash=02H  Required=03H) !
Contents mismatch at: 0800C055H  (Flash=60H  Required=EBH) !
Contents mismatch at: 0800C056H  (Flash=08H  Required=0AH) !
Contents mismatch at: 0800C059H  (Flash=00H  Required=9BH) !
Contents mismatch at: 0800C05AH  (Flash=00H  Required=18H) !
Contents mismatch at: 0800C05BH  (Flash=01H  Required=19H) !
Contents mismatch at: 0800C05CH  (Flash=70H  Required=F4H) !
Contents mismatch at: 0800C05DH  (Flash=22H  Required=F7H) !
Contents mismatch at: 0800C05EH  (Flash=20H  Required=30H) !
Contents mismatch at: 0800C05FH  (Flash=62H  Required=FAH) !
Contents mismatch at: 0800C060H  (Flash=40H  Required=D8H) !
Contents mismatch at: 0800C061H  (Flash=68H  Required=F8H) !
Contents mismatch at: 0800C063H  (Flash=00H  Required=80H) !
Contents mismatch at: 0800C064H  (Flash=40H  Required=D8H) !
Contents mismatch at: 0800C065H  (Flash=20H  Required=F8H) !
Contents mismatch at: 0800C069H  (Flash=60H  Required=F0H) !
Contents mismatch at: 0800C06CH  (Flash=00H  Required=10H) !
Contents mismatch at: 0800C06DH  (Flash=20H  Required=B1H) !
Contents mismatch at: 0800C06EH  (Flash=25H  Required=6FH) !
Contents mismatch at: 0800C06FH  (Flash=60H  Required=F0H) !
Contents mismatch at: 0800C070H  (Flash=00H  Required=07H) !
Contents mismatch at: 0800C071H  (Flash=01H  Required=07H) !
Contents mismatch at: 0800C072H  (Flash=26H  Required=27H) !
Contents mismatch at: 0800C073H  (Flash=20H  Required=E0H) !
Contents mismatch at: 0800C074H  (Flash=00H  Required=D8H) !
Contents mismatch at: 0800C075H  (Flash=70H  Required=F8H) !
Contents mismatch at: 0800C079H  (Flash=00H  Required=90H) !
Contents mismatch at: 0800C07AH  (Flash=00H  Required=40H) !
Contents mismatch at: 0800C07BH  (Flash=00H  Required=F2H) !
Contents mismatch at: 0800C07CH  (Flash=64H  Required=F4H) !
Contents mismatch at: 0800C07DH  (Flash=40H  Required=50H) !
Contents mismatch at: 0800C080H  (Flash=24H  Required=36H) !
Contents mismatch at: 0800C081H  (Flash=00H  Required=1AH) !
Contents mismatch at: 0800C083H  (Flash=60H  Required=F2H) !
Contents mismatch at: 0800C084H  (Flash=64H  Required=F4H) !
Too many errors to display !
Error: Flash Download failed  -  "Cortex-M7"
Flash Load finished at 09:41:09
收藏 1 评论1 发布时间:2018-6-28 10:15
喜欢你 回答时间:2021-10-19 13:52:42
解决了?
