ST给的TIM例子都是实现一个固定频率的当时输出,如果想在每次定时中断后改变定时器值,那么需要动态的修改定时器周期配置。
2 t" i& t% l2 p, N! U9 ]5 M实测中发现一有坑,给大家共享。
3 B0 ? E! U- z+ H& N( G' B7 l' @- void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
+ g$ i3 k$ L! r6 n/ m( o0 X; Z - {4 o9 f3 `! ]4 [! R' A3 B
- /* USER CODE BEGIN Callback 0 */
; H" g2 r( E1 M$ @. i$ u8 e
8 Z/ i3 b, g6 e6 u. z- /* USER CODE END Callback 0 */, q+ U2 b( P- C) V3 I: D
- if (htim->Instance == TIM22) {+ z* f% q6 ~3 a, s' J( z, o# Q
- HAL_IncTick();
" n# g/ k7 u1 X/ P" o1 T. | - }
! B! s, r* ?$ t1 ]# z7 } - /* USER CODE BEGIN Callback 1 */# I3 A; {$ ~7 M+ k- J! ~' F
- if (htim->Instance == TIM2) {7 X. Z) M6 B4 a( b2 |- r
- IrdaTransfer(pDataNEC);
, N1 Q0 u% V3 h' G7 z( ^ - }
3 j E4 {; z, K' k - /* USER CODE END Callback 1 */
! {) O7 P) O9 L7 {9 X: f - }: l1 U' G4 z! e) h
复制代码 首先在HAL_TIM_PeriodElapsedCallback中添加TIM的Update事件中断回调函数,自己写IrdaTransfer(pDataNEC)实现NEC编码的红外遥控。3 r/ C0 E3 c& z( r' z
- uint16_t IrdaTransfer(uint8_t* pDataNEC)
1 F* }5 i1 @' \; [, x - {
) g+ [' |$ L, y6 u- Z - PulseVal=TimeSerial(pDataNEC,PulseSteps);
' y" b& w l5 O) u! z- O - PulseSteps++;: |9 ?1 N" a. I+ n5 r( P6 S1 `) w
- if(PulseVal>0)
9 ~3 R1 e7 s! ~& A% x4 u - {) l$ x$ h E5 x2 I$ d j: r9 Y& ?
- htim2.Init.Period = PulseVal&0x7fff;- @. |# K+ E+ S. \! W3 v9 M5 [' J8 Q
- HAL_TIM_Base_Init(&htim2);+ G0 w% @. T2 [" e/ l1 \( p; i! X
- __HAL_TIM_CLEAR_FLAG(&htim2, TIM_SR_UIF);, y7 r$ L' T n7 G0 q8 l: q) S
- HAL_TIM_Base_Start_IT(&htim2);
2 w: z- T1 z# ?! ]" Y4 `& P - }
9 w) z( {6 M6 K4 l - else
F6 P; W# Y+ e, {4 N. w - {
& ]4 r5 c) I' A, }9 M1 z - __HAL_TIM_CLEAR_FLAG(&htim2, TIM_SR_UIF);8 g) s/ G! g" u& M
- HAL_TIM_Base_Stop_IT(&htim2);; B$ S b5 [7 e" h# r' Q
- }9 T+ b/ T: X" r0 V* S4 j
- if(PulseVal&0x8000)* d1 a% L+ a7 f D+ A/ K$ d6 t
- HAL_GPIO_WritePin(IrDA_Output_GPIO_Port, IrDA_Output_Pin, GPIO_PIN_SET);
. B. I: Y1 H& y: H - else1 i/ U6 s2 d, L* A; C* w+ B& g- R3 t1 m
- HAL_GPIO_WritePin(IrDA_Output_GPIO_Port, IrDA_Output_Pin, GPIO_PIN_RESET);
) }# i6 g. X4 S7 a' x2 V3 G% p - return PulseVal;- l5 N% T) k1 H* I6 [1 d, ^9 s' x
+ U: ?1 K0 ]- x; G
复制代码 注意这里的坑是:
) z+ o( `/ m8 D0 b& vhtim2.Init.Period = PulseVal&0x7fff;1 `" {3 ]! U3 i/ f
HAL_TIM_Base_Init(&htim2);3 P& ]5 n( J% s# o: U
__HAL_TIM_CLEAR_FLAG(&htim2, TIM_SR_UIF);//这是坑,必须在此处加。
! u( g! }4 O- d$ rHAL_TIM_Base_Start_IT(&htim2);
: A) A a. A. d: Q2 D! K- p在初始化定时时长后,必须先清除中断标志,再启动定时器中断,否则会直接进中断而没有在定时结束时进,这个坑调了我一天,不明白为啥初始化定时器就会触发一次UPDATE中断。
Y( c( S) D$ Q: \5 T' | _以上代码即可实现每次定时后立即更新定时值,实现任意的序列控制。具体的NEC红外序列实现功能我就不放了,留点自己动脑子的地方,填的坑与大家共享。
% D9 u T! P$ w4 Y6 ?
. o8 {3 F; X5 R* [2 T# S) M) [ D6 f: L8 b9 @5 P' y. x1 o
6 k. J/ E# u+ \: U$ V |
7 ^: ~0 Q* C# L- s6 E
HAL_TIM_Base_Start_IT(&htim2);- v5 G* ~* F" ^& k5 F
==>不能算是个坑,应该是手册没看清楚。1 r6 B$ \/ K% S
因为有些寄存器比方PSC/RCR寄存器必须通过更新事件才能更新,我们初始化时只能操作预转载寄存器,所以让我们用户数据生效,就手动产生个更新事件,让预装载寄存器的数据拷贝到影子寄存器【实际寄存器】发挥作用。但这个操作会置位更新中断标志,所以我们在使能更新中断前有必要清除下该标志UIF,否则可能一使能更新中断就跳进更新中断服务程序。
