/* PLL configuration: PLLCLK = HSE * 6 = 72 MHz */ ( c3 B5 o3 S& q* Z; h) z, PRCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |( S/ D) Y1 X6 M) F2 ], S
RCC_CFGR_PLLMULL));0 r, v1 y# u& p8 D B
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6); & {( Z- \. W" I2 }" w . A, E" M9 B; Z. W, m
1 G' ~; n- M2 R" a, m. t( M
+ P! M: T: @3 ^0 S. n$ _8 o, g$ s h8 ], n& y% f2 R
" A7 U$ f" \4 d! i
" U; T; X) o1 N$ L: [. ^
(2)对于HAL库版本,需要修改两个地方: 7 W% o* k; W- j & _% b0 x9 f' ?# k* k& u3 B m(A)修改stm32f1xx_hal_conf.h头文件,大概在101行,如果用mini板或者战舰板(8M外部晶振)需要将#define HSE_VALUE ((uint32_t)12000000) 改为 #define HSE_VALUE ((uint32_t)8000000)2 m) d: [0 E8 V4 y4 b
[AppleScript] 纯文本查看 复制代码0 l2 a- v$ p% A( R3 D8 E3 o, [0 o- J ?3 s7 C1 ]4 k7 K" X8 a/ i( V
1
1 V) Y4 Y1 i Z0 V
2
7 H' x* f+ i7 x( n2 S) Z. h
3
; b6 V9 E7 p; A D
#if !defined (HSE_VALUE) 6 g: ~$ m0 [3 w6 N #define HSE_VALUE ((uint32_t)12000000) /*!< Value of the External oscillator in Hz */% l I( f6 c) I, {
#endif /* HSE_VALUE */ % ]$ V C' F1 J; Z) u. Q/ X" d0 W$ t
8 ~/ N% l0 b& q* L5 S% I3 l; N& I* {+ k! L k
! G* a8 o) h8 n, C) R
6 [! D% Q( K' Z$ O8 e
% K) i7 I0 `. o, S(B)修改board.c的SystemClock_Config函数,如果你是用mini板或者战舰板(8M外部晶振)修改就比较简单,只需将RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6; 改为RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;大概率在58行:9 Y. H8 x a" `$ p5 _( z2 }/ \$ e
[AppleScript] 纯文本查看 复制代码6 c8 `, u# V/ o' k# b ? ( ?" B6 f) t% H/ A$ q) w
1
; `! Q; B" ~ o0 D1 k) a
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6; + X J3 A. |* q+ A& g+ }2 v z5 r& \; L+ V P7 B% b7 e
1 C# U# `) q. ^3 `9 |4 |" d8 E- H; \$ n
! k2 T+ }; Q' f! m0 Q- O
" y& b: Y+ ~0 X$ \# [
8 [' M2 t- a, U n1 n
2 ?/ M" M# b7 o; L; b2 ?1 d注意:对于HAL版本的修改,为确保修改不出错,也可以用STM32CubeMX配置时钟图重新生成代码,然后将原来的stm32f1xx.h、stm32f1xx_hal_conf.h、stm32f1xx_it.c、stm32f1xx_it.h、stm32f103xe.h、system_stm32f1xx.c、system_stm32f1xx.h替换成用STM32CubeMX配置后新生成的。 3 u( [* o' ]8 N ( j! u6 F; ]' t G - l9 Z0 Z' d9 A. C- J5 P9 A- Z3 s以上,可能有遗漏或者错误地方,请指出指正,谢谢!
( E& I+ d' e$ i
/ u$ x1 b4 m- f! o5 H 4 \3 u. a! A- M$ Y0 ^' o
, C$ X) |- j# O7 n5 q1 A* M+ L1 r7 g |
; }4 L' {+ O8 L7 T' \
2 x9 E1 W/ G6 e6 T
