调试了两天了stm32f373中SPI3的一直卡死在发送区非空,求救!
haocheng996 提问时间:2019-5-9 08:54 /
调试了两天了,stm32f373用官方固件库配置SPI3, 当发送数据时程序一直卡在 while (SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET) 这条语句中,那个大佬可以帮忙看看是配置哪里出错了吗?
void SPI_FLASH_Iint()
    GPIO_InitTypeDef  GPIO_InitStruc;
    SPI_InitTypeDef   SPI_InitStruc;
    //初始化GPIOC 时钟
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
    //初始化GPIOA 时钟
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    //初始化SPI3  时钟
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI3, ENABLE);
    //配置复用引脚
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_6);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_6);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_6);
    GPIO_InitStruc.GPIO_Pin   = GPIO_Pin_10| GPIO_Pin_11| GPIO_Pin_12;
    GPIO_InitStruc.GPIO_Mode  = GPIO_Mode_AF;
    GPIO_InitStruc.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStruc.GPIO_Speed = GPIO_Speed_Level_3;
    GPIO_InitStruc.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOC, &GPIO_InitStruc);
    GPIO_InitStruc.GPIO_Pin   = SPI_FLASH_CS;              //片选引脚  PA15 -- 片选引脚
    GPIO_InitStruc.GPIO_Mode  = GPIO_Mode_OUT;             //输出模式
    GPIO_Init(GPIOA, &GPIO_InitStruc);
    SPI_I2S_DeInit(SPI3);
    SPI_InitStruc.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;           //设置为2分频(速度最快)
    SPI_InitStruc.SPI_CPHA              = SPI_CPOL_High;                     //设置时钟极性
    SPI_InitStruc.SPI_CPOL              = SPI_CPHA_2Edge;                    //设置时钟相位, 选择第几个时钟跳变沿数据被采样
    SPI_InitStruc.SPI_CRCPolynomial     = 7;                                 //设置 CRC 校验多项式,提高通信可靠性,大于 1 即可
    SPI_InitStruc.SPI_DataSize          = SPI_DataSize_8b;                   //数据为 8 位还是 16 位帧格式选择项
    SPI_InitStruc.SPI_Direction         = SPI_Direction_2Lines_FullDuplex;   //SPI设置为双线双向全双工
    SPI_InitStruc.SPI_FirstBit          = SPI_FirstBit_MSB;                  //设置数据传输是 MSB 还是 LSB (MSB 高位在前)
    SPI_InitStruc.SPI_Mode              = SPI_Mode_Master;                   //设置SPI的主从模式(这里是主模式)
    SPI_InitStruc.SPI_NSS               = SPI_NSS_Soft;                      //设置 NSS 信号由硬件(NSS 管脚)还是软件控制 (这里是软件控制)
    SPI_Init(SPI3, &SPI_InitStruc);    //初始化结构体
    SPI_RxFIFOThresholdConfig(SPI3, SPI_RxFIFOThreshold_QF);
    SPI_Cmd(SPI3, ENABLE);             //使能SPI外设
    W25Q32_CS_H;
u16 SPI3_ReadWriteByte(u8 TxData)
    SPITimeout = SPIT_FLAG_TIMEOUT;
    //等待发送区空
        if ((SPITimeout--) == 0) return SPI_TIMEOUT_UserCallback(0);
    SPI_SendData8(SPI3, TxData);          //通过外设SPIx发送一个 byte 数据
    //重新装载超时值
    //等待接收完一个byte
    while (SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_RXNE) == RESET)
        if ((SPITimeout--) == 0) return SPI_TIMEOUT_UserCallback(1);
    return SPI_ReceiveData8(SPI3);         //返回通过SPIx最近接收的数据
赞 收藏 评论13 发布时间:2019-5-9 08:54
13个回答
byronsong 回答时间:2019-5-9 09:15:49
    W25Q32_CS_H;
在这个位置加一句SPI3发送0xFF,如下代码,试试。
  1.    SPI_Init(SPI3, &SPI_InitStruc);    //初始化结构体
  2.     SPI_RxFIFOThresholdConfig(SPI3, SPI_RxFIFOThreshold_QF);
  3.     SPI_Cmd(SPI3, ENABLE);             //使能SPI外设
  4.     W25Q32_CS_H;
  5.     SPI_SendData8(SPI3, 0xFF);
  6. }
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3
haocheng996 回答时间:2019-5-9 09:29:15
不行,发送缓冲区还是一直为非空状态
澜月亮 回答时间:2019-5-9 09:51:16
调用此函数SPI3_ReadWriteByte发送数据前片选拉低了吗?给的代码有限看不出来有啥问题
STMCU + 2
haocheng996 回答时间:2019-5-9 09:58:24
//读 W25Q32 的 FLSH ID
u16 W25Q32_ReadID(void)
    u16 Temp = 0;
    W25Q32_CS_L;
    SPI3_ReadWriteByte(W25X_ManufactDeviceID); //0X90
    SPI3_ReadWriteByte(DUMMY);
    Temp |= SPI3_ReadWriteByte(0XFF) << 8;
    Temp |= SPI3_ReadWriteByte(0xFF);
    W25Q32_CS_H;
    return Temp;
然后在主程序中:
while(1)
    flag = W25Q32_ReadID();
zoomdy 回答时间:2019-5-9 15:21:02
对照参考手册,检查 SPI3的寄存器是不是配置正确
STMCU + 2
edmundlee 回答时间:2019-5-9 15:32:51
这种情况, 不外乎几个原因
一 spi时钟没Enable
二 spi 没便能
三 spi_tx没使能
在寄存器确认以上三条就应该可以把问题找出来了
别看自己的代码写了什么, 要看在寄存器里有什么, 这才是调试。
STMCU + 2
byronsong 回答时间:2019-5-9 16:24:04
//初始化SPI3  时钟
这个是复位时钟吧,使能在哪里?
tanic 回答时间:2019-5-9 17:23:37
MOSI  MISO 引脚上啦
STMCU + 2
haocheng996 回答时间:2019-5-10 09:56:27
songshiqun2010 发表于 2019-5-9 16:24
这个是复位时钟吧,使能在哪里?
确实是这条语句错了,这是复位 SPI3 的时钟不是使能SPI3时钟,使能是这条语句 RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
谢谢你的回答
haocheng996 回答时间:2019-5-10 09:58:28
edmundlee 发表于 2019-5-9 15:32
这种情况, 不外乎几个原因
一 spi时钟没Enable
二 spi 没便能
你说的对,要看看实际写进寄存器的是什么才是调试,我也看了很久,谁知道犯傻在使能时钟的语句写错了
谢谢你的回答
haocheng996 回答时间:2019-5-10 10:00:13
感谢各位的回答,问题已经找到了,谢谢各位
haocheng996 回答时间:2019-5-10 10:06:58
正真的原因是我看到 stm32f373x_spi.c 文件中的
                       ##### How to use this driver #####
        (#) Enable peripheral clock using RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE)
            function for SPI1 or using RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE)
            function for SPI2 or using RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI3, ENABLE)
            for SPI3.
然后就没多想了,也是自己没细心看
参与人数 1蝴蝶豆 +3 收起 理由
STMCU + 3 自给自足
Lee_Corle 回答时间:2024-9-27 22:38:25
你好博主,我是用hal库生成的代码,使用spi的时候系统会卡死在
if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_TXE)) && (hspi->TxXferCount > 0U) && (txallowed == 1U)),然后彻底结束运行,请问要什么解决方案吗?
