STM32MP157 SO-DIMM
噗噗能 发布时间:2019-5-24 10:19
The Cortex-A7 incorporates all features of the high-performance Cortex-A15 and Cortex-A17 processors, including virtualization support in hardware, NEON™, and 128-bit AMBA®4 AXI bus interface.
4 ?9 o) [5 C3 q# m9 \. W        The STM32MP157A devices also embed a Cortex® -M4 32-bit RISC core operating at up to 209 MHz frequency. Cortex-M4 core features a floating point unit (FPU) single precision which supports Arm® single-precision data-processing instructions and data types. The Cortex® -M4 supports a full set of DSP instructions and a memory protection unit (MPU) which enhances application security.+ ]# |) E# \7 ?6 C9 d
        The STM32MP157A devices also embed a 3D graphic processing unit (Vivante® - OpenGL® ES 2.0) running at up to 533 MHz, with performances up to 26 Mtriangle/s, 133 Mpixel/s.: L, ?( t% {! |9 x0 Q
        The STM32MP157A devices provide an external SDRAM interface supporting external memories up to 8-Gbit density (1 Gbyte), 16 or 32-bit LPDDR2/LPDDR3 or DDR3/DDR3L up to 533 MHz.3 c/ }: {" c( o3 u$ D" o
        The STM32MP157A devices incorporate high-speed embedded memories with 708 Kbytes of Internal SRAM (including 256 Kbytes of AXI SYSRAM, 3 banks of 128 Kbytes each of AHB SRAM, 64 Kbytes of AHB SRAM in backup domain and 4 Kbytes of SRAM in backup domain), as well as an extensive range of enhanced I/Os and peripherals connected to APB buses, AHB buses, a 32-bit multi-AHB bus matrix and a 64-bit multi layer AXI interconnect supporting internal and external memories access.2 O$ f1 m7 R* A6 v3 F; a: ]! o/ x8 l$ E9 }
        All the devices offer two ADCs, two DACs, a low-power RTC, 12 general-purpose 16-bit timers, two PWM timers for motor control, five low-power timers, a true random number generator (RNG). The devices support six digital filters for external sigma delta modulators (DFSDM). They also feature standard and advanced communication interfaces.                / P& R0 s5 a5 S' R  J
赞 收藏 评论2 发布时间:2019-5-24 10:19
wangtwxt 回答时间:2019-5-24 10:43:43
请问在哪里能买到?
6 t! D# n4 F9 X' i) K  t
any012 回答时间:2019-5-25 08:42:45
https://www.stmcu.org.cn/module/forum/thread-620616-1-1.html
  h6 ]/ r+ p$ _7 a, ]& X1 E3 f这不是这个帖子里楼主展示的电路板吗?咂又换了个号?
